Old 06-06-2013   #1421
Re: beaterX project thread
Nice job! Impressive that you can get all that stuff done with how much you seem to work
Thanks guys! Yea, make no mistake this endeavor was completed in 20 to 60 minute increments. Sometimes I'd get lucky and get a few hours in a row but not often. Even yesterday I put the engine cover, manifold heat shield, and strut tower on in my work clothes on my way to work
Next weekend I'll change over to synthetic and hopefully have some virtual dyno plots (maybe some real ones?) to post
Old 06-06-2013   #1422
Andrew could definitely use a lesson in productivity from you!
Old 06-06-2013   #1423
INDEED
Old 06-06-2013   #1424
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Scheides youre a madman!!!
2006 WW IX RS 396/404 - SOLD
Old 06-13-2013   #1425
only 250 miles on this thing, I was hoping to be to 450 by now....too much work and too close to the office, I'm moving at a snail's pace! Going to have to plan a few shopping trips this weekend or something to try and attempt to get close to 500 before leaving for PG....otherwise I'm going to have to change my dino oil at the track and tune on the drag strip...
Old 06-13-2013   #1426
I can drive it for you!
Old 06-13-2013   #1427
^What that guy said!
Old 06-13-2013   #1428
simulatedwood
Drives: 08 Evolution X
I know a guy in Hastings that could use some help replacing a timing chain.
Old 06-13-2013   #1429
Problem is it's my DD, so I need it all day every day I drive it to work, then to datacenter, then customer site, then back to office, then customer site, then home...trouble is these have all been like 2 mile drives lately...silly inner-city businesses :P
Working with a customer down in edina today/tomorrow/next week so I think with a few social outings and maybe a dedicated drive or two I may be able to get'r'done.
Game on I am still hoping to do my rear diff fluid and rear brakes this weekend too but I could let those slide until after PG.
Old 06-13-2013   #1430
I have a car to trade you, its a sweet honda that gets mad MPG.
Old 06-13-2013   #1431
I'll trade ya the Gaylant for a few days!
Old 06-13-2013   #1432
I've got a frs I'd trade for a few days too
Hope you can get some time to get some more miles on it and ready to rock for proving grounds!
Old 06-13-2013   #1433
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
Drives: 06 EVO, 92 TSi AWD
Swap with the FRS, do ettttt!!!!!
Old 06-13-2013   #1434
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Haha you got more miles on it then I do. Mines still sitting on jack stands in the drive way. I'm driving the 100 miles tomorrow though then dropping the oil and heading up to park rapids for part of my 1k break in.
Hope you have it done for pg.
Old 06-14-2013   #1435
Fine I'll trade the BMW
Old 06-16-2013   #1436
Bombed around the city thursday/friday/saturday running errands, taking the wife out for fun, and visiting Shawn C in Hastings (helped him swap on a new non-stretch timing chain on his X) to click the new motor's odometer over 500 miles. Went to about 550 miles actually, vacuum pulls and such as much as I could.
Car drives really really nice and today I gave it some final love before next weekend:
-fresh rear diff fluid
-girodisc rear s/s brake pads
-ATE Super Blue brake fluid, fully bled system (thanks for pumping that brake pedal spazzy!)
-AMSoil 10w40
-yanked valve cover, everything looks peachy! Bolts are tight and clearances are in spec
-fixed ripped-out 3-port BCS harness (oops my bad--during disassembly )
-fresh OEM spark plugs gapped to .018"
-full tank of E85
-boost!
Started her off easy ~25psi and the car feels great. More boost this week, keep watching for leaks, and few more little things before heading to BIR!
Lots of clunking coming from the front, I'm going to order new strut mounts/hats as it is getting really annoying.
Also I have a loose endlink on the rear sway bar. It's not terrible, but might be causing a clunk here or there. Just annoying because I the bolt is basically frozen on the endlink and doesn't want to budge...might be sawzall time
Old 06-16-2013   #1437
After looking at logs, realized BCS was plugged into the wrong plug--oops! Corrected it for a flatter boost curve going forward
Old 06-17-2013   #1438
simulatedwood
Thamks Scheides for your help on Saturday. The car is mostly back together finishing up assembly tonight. You car sounded so good when you pulled up, gotta love a fresh rebuild!
Old 06-19-2013   #1439
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Any updated charts for viewing pleasure? It looked like you are ripping at 32psi now?
Old 06-19-2013   #1440
No real charts, decided to save it for this weekend. Car is making about 550 whp @32-tapering to 30 according to Virtual dyno which is identical to what it was making last fall before making 599@MAP. So, numbers are with a grain of salt, if I can just have fun with it this weekend ill be happy! Car just revs and revs, power is fantastic above 7500rpm.
