Old 07-01-2013   #501
4seasons69
4seasons69's Avatar
Re: my new project
So back on the dyno or just drive it?
It definitely needs to go back on the dyno. It's still pretty much untuned. Even if it doesn't do what I want I would still rather play it safe than sorry
Old 07-01-2013   #502
4seasons69
4seasons69's Avatar
Re: my new project
Motor runs good time for boost!!
Boost will come as soon as I can afford to get it back on the dyno!
Old 07-01-2013   #503
4seasons69
4seasons69's Avatar
Re: my new project
Alrighty so I already have a new axle and I ordered control arm bushings that should be here wednesday. So I will replace those parts wednesday at my work and just check the car over again. Then it's just putting some miles on it and making sure all is good to go.
Tentatively I'm trying to get a tune scheduled for the 15th or 16th so we'll see what happens. Otherwise they're booked out till like the 28th :-/
Old 07-02-2013   #504
4seasons69
4seasons69's Avatar
Re: my new project
Alrighty round 4 on the dyno is set for the 16th. Hopefully some of this luck I've had recently will continue on!
Old 07-02-2013   #505
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: my new project
Nice, now don't blow it up!
-Sebastian Vettel
Old 07-02-2013   #506
4seasons69
4seasons69's Avatar
Re: my new project
I'm not making any promises on that one! Hahaha :-D
Old 07-02-2013   #507
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: my new project
Sweet glad to see it going back on.
Old 07-03-2013   #508
Mark Leasure
Mark Leasure's Avatar
Re: my new project
Sometimes you get a little lucky with these cars! Good luck on the tuning, did you get your fuel issue all sorted out?
www.maperformance.com
Old 07-03-2013   #509
4seasons69
4seasons69's Avatar
Re: my new project
Yes sir I did get the fuel issues figured out. It was one of the rubber lines in the tank had ruptured. Last time it was on the dyno we seemed to get all the bugs sorted out and were finally able to get to the actual tuning
Old 07-05-2013   #510
4seasons69
4seasons69's Avatar
Re: my new project
Well with the exception of losing my hood today was a relatively successful day. I replaced the control arm bushings, drained the oil, then hooked up our engine flush machine and flushed the sucker out so if there was any metal in any of the oil galleys there shouldn't be any more. I changed the oil filter, changed the inline filter for the turbo oil feed.
I put new plugs in it, shortened the coil boots, put bolts in places that were missing bolts, (fenders, t-case, flywheel inspection cover, etc) and just cleaned up as much stuff as I could.
Also I removed the rear crash bumper should be about 32lbs removed from the car. Which will bring my total weight savings since the got the car to around 47lbs.
ID:	13778   Click image for larger version
ID:	13779   Click image for larger version
Old 07-05-2013   #511
Re: my new project
Nice!!
So it doesn't make any weird noises anymore?
Old 07-05-2013   #512
4seasons69
4seasons69's Avatar
Re: my new project
Kinda. Sounds like something in the drivetrain might be clunking at times. But i think Ihad one of my carrier bbearings on upside down so I flipped it around. we'll see if that helps. Plus my carrier bearing bushings are definitely shot. They will have to be replaced eventually. I'll know more after I drive it back to its parking place
Old 07-05-2013   #513
Re: my new project
Remember what I said about replacing those, its not a simple swap job.
Old 07-05-2013   #514
4seasons69
4seasons69's Avatar
Re: my new project
Oh I remember! The car seems better than before. No more weird wobble on the highway. Less noises. There are a few things that seem off. There a noise like a vibration on decel. Sometimes when starting out Ithink I hear something in the driveline clunk. 3rd gear felt funny shifting into sometimes. Idk I could be overly paranoid right now ha
Old 07-06-2013   #515
Re: my new project
You should of brought it out last night. We had a good match for you. 6.0 & 76mm at 10lbs.
Old 07-06-2013   #516
4seasons69
4seasons69's Avatar
Re: my new project
Still no tune, no laptop, plus the last time it was on the dyno it had e70 in it ;-). Fun shall be had after the 16th if all goes well!
I ended up having to help me buddy move since he's nice enough to store my car for me for free
Old 07-06-2013   #517
Re: my new project
I had power inverter and laptop.
It's all good that's only 2 weeks away.
Old 07-06-2013   #518
4seasons69
4seasons69's Avatar
Re: my new project
Then fail on my part lol
Old 07-07-2013   #519
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: my new project
Good luck on the 16th man!! I hope the car treats you good this round
2006 WW IX RS 396/404 - SOLD
Old 07-07-2013   #520
4seasons69
4seasons69's Avatar
Re: my new project
Thanks! I need all the luck I can get!
