Old 07-02-2013   #21
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: broke at pg project thread
found some sparkle in the oil and heres where im at. got the head off and everything actually looks pretty good so far. i will pull the rest tonight
Name:	2013-07-02 09.13.13.jpg
ID:	13760   Click image for larger version
Name:	2013-06-30 02.08.01.jpg
ID:	13761   Click image for larger version
Name:	2013-06-30 02.07.24.jpg
Old 07-02-2013   #22
dsmreck
dsmreck's Avatar
Drives: 98 gsx
ok 2 days later and everything is out. no matter how hard i tried I still ended up with a bag of bolts. I was happy to see the rods and pistons are absolutely perfect. head and cams looked good. I am getting a good deal on another 2.4 block and crank, but I really wanted to go 6 bolt 2.0. Oh well for now I can build on a budget and still end up with the same engine I had and save some money. If I get this thing going by pg2 I will be very happy...
Old 07-03-2013   #23
dsmreck
dsmreck's Avatar
Drives: 98 gsx
should have my next crankwalk block and crank tomorrow. I will be sure to reuse all the parts that had metal shavings back in my new block just like the moron I got my car from. I have a hard time understanding why someone would spend 6k on a rebuild just to reuse a few hundred dollars worth of new parts but neither here nor there. I can't wait to get started on this build
Old 07-09-2013   #24
dsmreck
dsmreck's Avatar
Drives: 98 gsx
i now have a block and crank to try out. need to do some measuring now
Old 08-06-2013   #25
dsmreck
dsmreck's Avatar
Drives: 98 gsx
some update pics on the engine
Name:	2013-07-28 00.26.52.jpg
ID:	13879   Click image for larger version
Name:	2013-08-02 01.13.30.jpg
ID:	13880   Click image for larger version
Name:	2013-08-04 19.45.33.jpg
Name:	2013-08-04 20.22.27.jpg
ID:	13882   Click image for larger version
Name:	2013-08-04 21.52.33.jpg
ID:	13883   Click image for larger version
Name:	2013-08-04 22.45.41.jpg
Old 08-06-2013   #26
Wow lookin nice! I like that valve cover
Old 08-06-2013   #27
dsmreck
dsmreck's Avatar
Drives: 98 gsx
thanks goodhart its looking like i should have it in the car soon.. 2.4 dohc 7bolt stock crank arp mains acl race bearings eagle rods weiseco pistons 87mm bore block and head decked cometic hg all oe gaskets and oil pump bse. 1g ported head ferrea stainless valves. sent my 3582r chra off to fuel systems in wi for the garret exchange 550 for a new chra. so far so good.
Old 08-06-2013   #28
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
+1. Definetly looks sick! Good job
Old 08-06-2013   #29
dsmreck
dsmreck's Avatar
Drives: 98 gsx
thanks nick i have a ton of pics just seemed boring to pist them all. been wirking my ass off on this one i assume the turbo will be here late this week or next week. coming down to get my drieshaft i hope to have it running by next week if all goes well
Old 08-13-2013   #30
dsmreck
dsmreck's Avatar
Drives: 98 gsx
got alot done. got my driveshaft, oem shifter, and 3rd diff mount after finding mine was completely shot...engine, trans, and transfer are now in their home goes toi easy with three guys getting the engine with trans mounted in the bay... need a few bolts that i cant seem to find to keep rockin out. turbo should be here late this week ir early next weej...
Name:	2013-08-07 21.08.37.jpg
ID:	13895   Click image for larger version
Name:	2013-08-09 20.39.38.jpg
ID:	13896   Click image for larger version
Name:	2013-08-10 17.22.49.jpg
Name:	2013-08-12 19.49.41.jpg
ID:	13898   Click image for larger version
Name:	2013-08-12 21.08.19.jpg
Old 08-13-2013   #31
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
lol at that last pic.
BW8776, e-85
Old 08-13-2013   #32
97gsexx
97gsexx's Avatar
Drives: 97 talon
hahah
97 gsx (sold)
97 talon tsi awd 🐼
Old 08-13-2013   #33
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Last picture = WIN. lol
Old 08-13-2013   #34
That's your problem right there. A severed human head in the engine bay is known to cause problems on these cars.
Old 08-13-2013   #35
dsmreck
dsmreck's Avatar
Drives: 98 gsx
thought a good tuner like shane would have found that on the dyno lol...figured you guys would like that one...
Old 08-15-2013   #36
dsmreck
dsmreck's Avatar
Drives: 98 gsx
got alot done last night it took me a while to fix and hide wiring a little better but everything is done up to needing my turbo for start up. i should be recieving my redline fluids today so maybe ill get the diff, axles, and driveshaft in tonight and put fuids in...
Name:	2013-08-14 23.23.58.jpg
ID:	13907   Click image for larger version
Name:	2013-08-14 23.24.22.jpg
ID:	13908   Click image for larger version
Name:	2013-08-15 00.17.38.jpg
Old 08-15-2013   #37
4seasons69
4seasons69's Avatar
Looks good! What turbo are you going to run?
Old 08-15-2013   #38
dsmreck
dsmreck's Avatar
Drives: 98 gsx
i sent in my garret 3582r in on the exchange program. 550 for a new chra. so i will be running that... seems like a good turbo. with shaft play surge and bad crank and bearings on the block shane made 525hp 425tq uncorrected. it was 611hp 496tq shootout mode...all that at 30lbs. there was also surge around 26/27 lbs.
Name:	2013-06-07 20.45.59.jpg
Old 08-15-2013   #39
4seasons69
4seasons69's Avatar
Ah gotcha very nice.
Old 08-15-2013   #40
dsmreck
dsmreck's Avatar
Drives: 98 gsx
thanks man...well i talked to jeff from fuel systems in wi today and he said he will be shipping the turbo tomorrow so bummer next week will be
first startup now...
