Old 07-12-2013   #521
4seasons69
4seasons69's Avatar
Re: my new project
So i drove the car to work yesterday. All seems to be good. There still seemed to be an exhaust leak on my way home so when I got there I was able to tighten up the vband quite a bit so hopefully that takes care of it.
Also the only other issue is that my oil pressure is really high. It's been just about pegged at 100psi cruising at 3k rpms. On my way home it was down around 75psi at 3500rpms so that's a good sign not sure if the oil pumps need to be broken in or what not. I have almost 200 miles on it since getting it running again.
So plans for this weekend are to port the oil relief valve in the ofh and switch to a good 40wt oil vs the 50wt I have in it now. Then check everything over to make sure it's ready for the dyno next Tuesday.
Old 07-12-2013   #522
Re: my new project
Sounds good, hurry up and port that housing!
Old 07-12-2013   #523
4seasons69
4seasons69's Avatar
Re: my new project
Will be doing that this Sunday
Old 07-12-2013   #524
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: my new project
What time is dyno?
Old 07-12-2013   #525
4seasons69
4seasons69's Avatar
Re: my new project
It's at 6pm
Old 07-12-2013   #526
Re: my new project
haha if you want I can try coming up and bring the go pro again!
Old 07-12-2013   #527
4seasons69
4seasons69's Avatar
Re: my new project
Haha. If you don't have anything better to do that's fine with me
Old 07-13-2013   #528
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: my new project
Ill try and make it.
Old 07-13-2013   #529
4seasons69
4seasons69's Avatar
Re: my new project
Awesome! Just let me know
Old 07-15-2013   #530
4seasons69
4seasons69's Avatar
Re: my new project
I ported the pressure relief valve in my ofh and it seems to be a success cold start oil pressure was 50-60 psi compared to pegging the gauge at 100psi before. Just gotta finish putting it back together and drive it and see how it is when it's warmed up
Old 07-15-2013   #531
4seasons69
4seasons69's Avatar
Re: my new project
So the oil pressure situation is in check. It used to pegging the gauge at 100psi at 3500rpms. Now I'm seeing 75psi at 5k rpms. I snugged up the bolts on the front case some and made sure all the fittings in my ofh were tight But there is still an oil leak. I think the front case will have to come off to fix it :-\. Nothing I can do about it now. I just have to drain the fuel fill it up with fresh e85 and swap to the 40wt oil I have then she's ready for the dyno tomorrow
Old 07-15-2013   #532
Re: my new project
Dang i forgot about this. Good luck tomorrow be positive and when in doubt
MOAR BOOST!!
Old 07-15-2013   #533
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: my new project
Shawn. I am very very drunk right now but please win at the dyno!
-Sebastian Vettel
Old 07-15-2013   #534
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: my new project
Good luck on the Dyno. What time is it going to be on? I drive past DB evey day on my way home from work. I wouldn't mind stoping in and watching a few pulls.
11.35 @ 120mph
Old 07-15-2013   #535
4seasons69
4seasons69's Avatar
Re: my new project
MOAR BOOST!!
Thanks! I'm doing my best to stay positive!
Haha I will do my best to win at the dyno! Have a few for me! Preferably something with whiskey ;-)
The appointment is for 6pm. Stop by if you want!
Old 07-15-2013   #536
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: my new project
Good luck man!!! You got this haha
2006 WW IX RS 396/404 - SOLD
Old 07-15-2013   #537
4seasons69
4seasons69's Avatar
Re: my new project
Thanks!
Old 07-15-2013   #538
Re: my new project
Best of luck on the dyno!
Did you take a picture of the OFH porting?
Old 07-16-2013   #539
4seasons69
4seasons69's Avatar
Re: my new project
Thanks!
And I didn't :-\. I should have. Idk why I didn't. There is a lot of info on tuners about it. I basically just used a small carbide bit and widened and elongated the hole.
It's pretty easy. If its something you're going to do and want a hand let me know
Old 07-16-2013   #540
4seasons69
4seasons69's Avatar
Re: my new project
Yet another trip to the dyno and yet another failure. Apparently the right rear axle was broken so we couldn't do anything with it today. I'm fed up with the car so said screw it and am just going to have db fix it. The next tune date is set for august 6th
