Old 07-17-2013   #461
Re: 2G auto S/A daily
Isn't it nice to actually drive your cars?!!!
Old 07-17-2013   #462
whachutalkinboutwillis?
Car moves good thanks for dropping that fiddy off for me. Maybe sat. we can get some more time into getting the car ready for dyno.
Old 07-17-2013   #463
55lbs @ 25psi is a damn good amount of air. That car definitely has some 10's in it!
Old 07-17-2013   #464
How are you reading airflow? If you aren't running a stock unhacked 2G MAS then the lbs/min readings are not going to be accurate. The GM MAF setups on DSMs are far from accurate.
Old 07-17-2013   #465
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I'm running a 4 bar omni map sensor no gm maf/ stock maf in my setup.
This # was just logged in link.
Old 07-17-2013   #466
Tachyon
Tachyon's Avatar
Drives: Icarus
How accurately can one log airflow using pressure?
-Sebastian Vettel
Old 07-17-2013   #467
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Sorry I'm a newb when it comes to this stuff.
Old 07-17-2013   #468
Same as a virtual dyno?
Old 07-18-2013   #469
Without an airflow sensor, you can't read airflow.
Old 07-18-2013   #470
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Gotcha!
Old 07-24-2013   #471
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Tomorrow is my tune at noon. Gonna change plugs and oil tonight and hopefully that's it and I'm ready to go.
Weather is looking nice and cool!
Old 07-24-2013   #472
93gtpeater
Drives: cbr 1000rr repsol
What did you do about your waste gate?
Old 07-24-2013   #473
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I had to just fix it. What happened was the mount came loose and moved the rod forward. So when we tapped it with the hammer it couldn't move cause the arm was fully depressed. As soon as I took the cotter pin and wastegate arm off the flapper closed completely. I've put 500+ miles and no hang ups.
I contacted a few shops and none could have an external setup done in time and I couldn't purchase one and have it in time either.
Old 07-24-2013   #474
Too bad the tune is at noon, otherwise it'd be fun to swing up there and watch!
Good luck!
Old 07-24-2013   #475
Good luck!
X2!!
Boost leak test too!
Old 07-24-2013   #476
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Just went through DB's checklist.
No oil leaks, fans in operating condition, coolant system bled.
Just need to zip tie a few lines to the boost controller, and zip tie the dipstick after oil change.
Should I gap my plugs to .24? I'm running bpr7es goal is to get over 30 psi.
Old 07-24-2013   #477
93gtpeater
Nice that it was an easy fix. I gapped mine at .24. It wouldn't be a bad idea to have an extra set of plugs. Good luck tomorrow
Old 07-24-2013   #478
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Yeah I have a few new sets sitting here and I always keep a spare set in the glove box.
Old 07-24-2013   #479
True DSMer! I always had a spare set of plugs in the glove box too lol
Old 07-24-2013   #480
Tachyon
Tachyon's Avatar
Drives: Icarus
I had to go down to .018 on mine before it stopped blowing out with this setup. I was on stock coils, however, BPR8ES plugs.
-Sebastian Vettel
