Old 08-15-2013   #41
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: broke at pg project thread
Looking good. Now just gotta get Andres done so we can rep 2Gs and pg
Old 08-15-2013   #42
dsmreck
dsmreck's Avatar
Drives: 98 gsx
thanks nick.. DRE'S car is an idk... the machine shop has been taking forever and it will be cutting it extremely close...If there is a chance even a slim one I will have his car done and hopefully he will go. we would be deff have a bad ass group of 2g's
Old 08-21-2013   #43
dsmreck
dsmreck's Avatar
Drives: 98 gsx
got it all done and no start P0355 i believe it was. crankshaft position sensor malfunction... damn ill try and get one and post up
Old 08-21-2013   #44
dsmreck
dsmreck's Avatar
Drives: 98 gsx
ok i had the sensor turned the wrong way so it should start. here are some turbo pics
Name:	2013-08-20 17.57.05.jpg
ID:	13924   Click image for larger version
Name:	2013-08-20 17.22.52.jpg
ID:	13925   Click image for larger version
Name:	2013-08-20 18.27.31.jpg
Name:	2013-08-20 18.38.06.jpg
ID:	13927   Click image for larger version
Name:	2013-08-20 21.06.52.jpg
ID:	13928   Click image for larger version
Name:	2013-08-20 21.06.23.jpg
Old 08-22-2013   #45
That's a hell of a nice setup you've got there
Old 08-22-2013   #46
dsmreck
dsmreck's Avatar
Drives: 98 gsx
thanks goodhart...
well the crank sensor was bolted on backwards the guy who installed is a jackass. wait i did all that... anyways car fired right up and everything looked good after 20min i shut the car off and looked under it for the 10th time and there was somr oil. it looked like the back of the block because it was driping between block and trans by the slave. so last night i pulled the trans. looked like the oil galley bolt was leaking. so i put rtv on it and reinstalled everything. will give it another try today or tomorrow
Old 08-22-2013   #47
what turbo is that?
Old 08-22-2013   #48
haha, at least you are humble enough to admit mistakes.
Which oil galley bolt?
Old 08-22-2013   #49
dsmreck
dsmreck's Avatar
Drives: 98 gsx
turbotalon lol you are messed up. its my new stock appearing secret turbo. jk its my new chra gt3582r...
goodhart it was the main oil galley plug in the rear. its behind the starter plate. what a freekin nightmare place for an oil leak on a fresh installed build. so yes my cracker ass took the trans and all out last night to find the leak and put it all back together again. got to bed around three and up at 630 to go to work. my body feels like crap now but i use the shop at work so had to get done after i started.. knocked out 4 windshields before lunch and now i have a lax afternoon. ill put the intercoiler piping back on and senso
rs and give it a go...
Old 08-22-2013   #50
dsmreck
dsmreck's Avatar
Drives: 98 gsx
btw anyone with a garret bb chra i recommend fuel systems in WI. ask for jeff. my brand new chra cost me 565 shipped under the exchange
Old 08-22-2013   #51
dsmreck
dsmreck's Avatar
Drives: 98 gsx
seems good so far. no more leaks. drove it tonight and it seems good so far...i have to adjust one of my belts and get that power steering feeling less notchy. other than that ill just take it easy for a while... oh wait the lifters or maybe injectors sound a bit louder than i remember?
Old 08-24-2013   #52
dsmreck
dsmreck's Avatar
Drives: 98 gsx
drove the car around 20 miles or so today. no leaks or signs of any real problems. I did have a p0300 code on startup when leaving dre's. cleared the code and that was that for now. I should get some new plugs. I noticed when that happened the wb showed pretty lean at idle but everything seemed to clear up when i left. It's hard not to boost the car lol. I think I will change the oil out soon to inspect and to put some brad penn in there.
Old 08-27-2013   #53
dsmreck
dsmreck's Avatar
Drives: 98 gsx
car is great so far, must be my boost leak thats causing it to be lean at idle. as long as thats the case she is sweet
Old 09-11-2013   #54
dsmreck
dsmreck's Avatar
Drives: 98 gsx
update car is tits. have it @25 psi using close to my old tune with 700 miles on it. no pg redemption this yr as i failed tech for no battery shut off switch and they didnt car for my marine battery box.
