Old 08-16-2013   #21
Re: 3/4 cylinders
Just take the head off.
+1.
Cylinder #3 has 0psi and a wierd looking spark plug, so something is obviously fucked up. I'd skip the bore scope and leak down test. The head pretty much has to come off at this point so just take it off and inspect for damage.
Old 08-16-2013   #22
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Re: 3/4 cylinders
Now to leave the manifolds on or take them off? I've heard its easier to leave them on for a place to grab.
BW8776, e-85
Old 08-16-2013   #23
mark4g63t
mark4g63t's Avatar
Re: 3/4 cylinders
Decided to leave them on. Going to start pulling it off after I make the tension tool. It's a 8mm x 1.25mm thread pitch and should be at least 8 inches long correct?
BW8776, e-85
Old 08-16-2013   #24
Re: 3/4 cylinders
Diameter and pitch sound right, not sure on length.
Old 08-17-2013   #25
mark4g63t
mark4g63t's Avatar
Re: 3/4 cylinders
Took the head off and BAM a chunk of the exhaust valve on #3 is gone!
ID:	13919   Click image for larger version
BW8776, e-85
Old 08-17-2013   #26
mark4g63t
mark4g63t's Avatar
Re: 3/4 cylinders
What should my next step be? Think I should get new valve guides?
BW8776, e-85
Old 08-17-2013   #27
Re: 3/4 cylinders
Was that an exhaust valve? I would be trying to find that piece, get the head checked out, and check you turbo if that's an exhaust valve all for starters.
Old 08-17-2013   #28
Re: 3/4 cylinders
Take the head to a shop, have them fix it. Try to find the missing piece. Put it back together. Let r buck.
Old 08-17-2013   #29
Re: 3/4 cylinders
Is there any cylinder wall damage?
Old 08-17-2013   #30
mark4g63t
mark4g63t's Avatar
Re: 3/4 cylinders
No cylinder wall damage. Still have crosshatching in them. It was a #3 exhaust valve. Taking the o2 housing off now to put my external setup on and will see if there is damage to the wheel.
BW8776, e-85
Old 08-17-2013   #31
mark4g63t
mark4g63t's Avatar
Re: 3/4 cylinders
What could have caused this?
Taking the head over to Marks tomorrow to take the valves out and pick up a set of Jackson Auto Machine std size valves. Then the head goes to Gosh on Mon. to see whats up with it and reassembly.
BW8776, e-85
Old 08-17-2013   #32
golden763
Drives: 95talon tsi
Re: 3/4 cylinders
just a burned valve does it look broke or like it was cut with a torch
Old 08-17-2013   #33
mark4g63t
mark4g63t's Avatar
Re: 3/4 cylinders
Hard to say. Will know once it's out.
BW8776, e-85
Old 08-17-2013   #34
golden763
Drives: 95talon tsi
Re: 3/4 cylinders
im gonna assume its a burnt valve don't usually just break little chunks off
Old 08-17-2013   #35
mark4g63t
mark4g63t's Avatar
Re: 3/4 cylinders
what causes a burnt valve? lean?
BW8776, e-85
Old 08-17-2013   #36
golden763
Drives: 95talon tsi
Re: 3/4 cylinders
that or to little valve clearance sticking it open a little for some reason seems not possible with hydrolic lifters but who knows happens to saturns all the time
Old 08-17-2013   #37
mark4g63t
mark4g63t's Avatar
Re: 3/4 cylinders
My injectors ohm tested fine and look perfectly clean.
BW8776, e-85
Old 08-17-2013   #38
mark4g63t
mark4g63t's Avatar
Re: 3/4 cylinders
The valve does have jagged edges where it broke.
BW8776, e-85
Old 08-17-2013   #39
golden763
Drives: 95talon tsi
Re: 3/4 cylinders
than maybe a bad lifter pumped up and held the valve open a bit. what happens in saturns is there supposed to be adjusted and when people don't do it enough they wear out of clearance and hang a valve open and they burn just like that.
Old 08-17-2013   #40
mark4g63t
mark4g63t's Avatar
Re: 3/4 cylinders
The cam cap bolt was a little loose.
BW8776, e-85
