Old 11-25-2013   #541
Re: Mark's 1G Winter Projects
Man, that is light, not much more than Brent had with his 2G, and that was stupid light.
Old 11-25-2013   #542
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
What other things have you done for weight reduction to get it that light?
Style's automotive engineer
Old 12-03-2013   #543
Mark Leasure
Mark Leasure's Avatar
I got these off of Vassil yesterday! They look sick.
www.maperformance.com
Old 12-23-2013   #544
Mark Leasure
I got out to the garage a little this weekend. Installed the hydraulic e brake. It works great, super cheep on ebay. The only down fall is that I needed to make one of the tube nut fittings that interfaces the hydraulic cylinder. The thread count was non standard, for brake applications. The handle sits where the factory one was.
Next up is the half radiator install.
Old 12-23-2013   #545
Always something badass!
Old 12-23-2013   #546
How much was it? Will you be using that as a staging brake then?
Old 12-23-2013   #547
Mark Leasure
Yes, I will be using it as a staging and parking brake. The price was around 45 bucks!
Old 12-23-2013   #548
Wow thats pretty good. If I were to get one it would be without the locking button, so just for launching and burnouts
Old 12-23-2013   #549
Because holding the button in is tough?
Old 12-23-2013   #550
Mark Leasure
That's the way it's setup, no button. To use it as a parking brake you need to flip a lever.
Old 12-27-2013   #551
dogwhistle
dogwhistle's Avatar
I was honestly thinking of buying this on eBay when I was cruising through brake stuff. I'm impressed!
-Adam
aneujahr@maperformance.com
Old 12-29-2013   #552
Mark Leasure
Just wrapped up my half radiator installation. It was cheap on Ebay, I think around 80 shipped. Its a 3 row out for a Civic application. I modified the inlet and outlets to increase the size up to 1.5", chopped off the filler neck and covered it up, fabricated new mounts, added a petcock valve, and to wrap it up made a new overflow tank.
Weight savings ended up being 17+ pounds. Kind of crazy, more than what I expected. I weighed both radiators filled with water to make the comparison. Some of the weight was due to removing the extra radiator fan too.
Old 12-29-2013   #553
Looking good sir!!
Old 12-29-2013   #554
The built in overflow is pimp
Old 12-29-2013   #555
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
8s??
2006 WW IX RS 396/404 - SOLD
Old 12-29-2013   #556
Very nice.
Old 12-29-2013   #557
cmspaz
Walls need hugs too
cmspaz's Avatar
Legit.
Originally Posted by Trogdor
Old 12-30-2013   #558
4seasons69
4seasons69's Avatar
Looks good Mark!
Old 01-10-2014   #559
Turbo
Drives: 92tsi(sold)
Awesome work, looks VERY nice!!
p.s. had to clean keyboard after i drooled looking at your turbo set up
Turbo is offline   Reply With Quote
Old 01-18-2014   #560
Mark Leasure
Thanks again for the feedback.
I purchased one of those frontline fab rear end covers at the end of September and just received it earlier this month. I got a little advice from Mondale on how to install it, thanks.
I also took the opportunity to take a touch of weigh out of it. The cover was a little heaver than the stock so I tubed up the rear brace to turn it into a net loss of weight. I used 1.25" 4130 .096 wall.
I have a couple of little projects and I will be ready for the season. I need to wire up the launch solenoid, send my injectors out to FIC for clean/balancing, drop the oil pan to take a peak at bearings, and get my turbo back from PTE(It was starting to leak oil into the exhaust housing).
