Old 01-18-2014   #561
b00sted_spyder
Re: Mark's 1G Winter Projects
Front line makes badass products! I see you used grey silicone. Much better than the black stuff.
Old 01-18-2014   #562
Very nice. I want to get there vc for the evo 3
Old 01-18-2014   #563
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
wow, that is pretty
2006 WW IX RS 396/404 - SOLD
Old 01-19-2014   #564
Dayum, shiny!! What's the purpose of the rear cover, more fluid, higher fill hole, more bling? Strength? Either way, hotness.
Old 01-19-2014   #565
Strength I believe.
Old 01-19-2014   #566
Fejery4491
Fejery4491's Avatar
Drives: 97 Mitsubishi Eclipse GSX
Its for strength. But definitely offers a touch more of the bling factor than a factory cover haha
Fejery4491 is offline   Reply With Quote
Old 01-19-2014   #567
b00sted_spyder
The stud keeps the differential caps from backing out if it ever happens.
Old 01-19-2014   #568
Mark Leasure
Mark Leasure's Avatar
It helps avoid bearing cap deflection on the ring gear. It keeps the ring & pinion mated properly, that's the theory. I broke a rear end last year, I'm hoping this will help.
www.maperformance.com
Old 01-19-2014   #569
Did you break it on the launch? What was the 60' or estimated 60'?
Old 01-27-2014   #570
Mark Leasure
I suspect I hurt the rearend launching it, it broke right after shifting into second.
I picked up a couple of vibrant clamshell clamps. I keep bending ic pipe with over torquing t-bolt clamps, causing boost leaks. These should solve that issue.
Old 01-28-2014   #571
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
How much are those? I bent my AMS IC pipes a bunch as they were aluminum with my tbolts.
I didn't have as many issues, none really, with SS piping. But maybe these are on option.
Old 01-28-2014   #572
Makes me want stainless piping again. Electric impact on IC pipes FTW!
Old 01-28-2014   #573
I've always preferred aluminum to save the weight plus dissipate a little extra heat. Use a 1/4" driver and don't go gorilla-mode.
Old 01-28-2014   #574
That doesn't always work when you're running Leasure boost though haha
Old 01-28-2014   #575
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
I never lost a coupler with the big setup the evo had.
I'm kind of surprised Mark didn't do this earlier since it seems everything he does is an engineering masterpiece it seems.
Old 01-28-2014   #576
Although I don't run the same boost levels as these guys, I've never popped one either.
Old 01-28-2014   #577
Murlo26
Murlo26's Avatar
I popped my UICP a few times before I had tbolts, running ~38psi.
But once I had the tbolts it stayed together. I think what Mark is saying is that the tbolts worked fine they are just easy to dent the piping with...which is what I did too. It's easy to over tighten.
Old 01-28-2014   #578
cmspaz
Walls need hugs too
cmspaz's Avatar
I've had the stock woven piping blow off before, but never a silicone coupler.
Originally Posted by Trogdor
Old 01-28-2014   #579
Probably time for a set of these, or Wiggins clamps to handle Leasure boost without torquing the t-bolts to 100 ft/lbs.
Old 01-28-2014   #580
Or just use SS pipes?
