Old 04-17-2014   #841
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: Big Brown's Automagic - The last episode in my DSM story.
holy hole in the oil pan bro. seems awfully big to me but i guess we will see. The oil pickup mod looks pretty decent for sure. hope it holds…deff cool seeing you try and make your car bad ask this year
Old 04-17-2014   #842
It's a big hole, but I can fill it. Got it welded last night, now just need a bung for the IAT and I should everything apart from an intake pipe that I need.
Old 04-17-2014   #843
Fejery4491
Fejery4491's Avatar
Drives: 97 Mitsubishi Eclipse GSX
Giggity!
Fejery4491 is offline   Reply With Quote
Old 04-17-2014   #844
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Worthless without pics
Old 04-17-2014   #845
Pics have not been approved for posting, I need to finish it up.
I forgot that I need to find some -4an line for the turbo feed too.
Old 04-29-2014   #846
dsmreck
dsmreck's Avatar
Drives: 98 gsx
done yet?
Old 04-29-2014   #847
Not yet, going to redo the pan fitting.
I need to:
get a barb for the MAP sensor
O2 housing gasket (2 bolt, 2.5")
Install exhaust, t-case, fluids.
Then I should be good to go.
Boost will be set at WG pressure for now.
Old 04-29-2014   #848
Mark Leasure
Mark Leasure's Avatar
Nice work and skill jump taking on the the metal fab work. I have watched the tig testing & growth. It should be inspiring for all members here. Next growth step...chop off the front, or t3 manifold for that next 62 gen2 beast?
You going to get it out to the proving grounds in June?
www.maperformance.com
Old 04-30-2014   #849
I need to:
This reminds me, can a guy run a omni 4 bar or similar map sensor on the stock 2g intake in a 1g? Or is that too much of a pain in the ass? I've been wondering that with my car since I also have a 2g head. Is there enough inputs with a 1g ecu w/ link?
Old 04-30-2014   #850
Why not? I'm running one with an Evo 3 IM.
Old 04-30-2014   #851
That's good to hear. I assumed he was running a GM style MAP sensor if he was looking for a barb fitting for it.
Old 04-30-2014   #852
dsmreck
dsmreck's Avatar
Drives: 98 gsx
I would think ud still have to remote instal the omni with vac line
Old 04-30-2014   #853
Thanks, I do want to drop as much weight as possible out of this car assuming someone doesn't want to buy a much loved 1G.
Next plan is to mod the T4 TS DNP, so that it functions correctly as a TS manifold. I do want to front half a car though.
I have to remake my UICP and make an intake for this setup, along with an exhaust system for the car instead of the one that is on there now.
I have a few other projects for friends lined up too, so hopefully I keep getting better.
Old 04-30-2014   #854
I won't be making PG in June, I have my 2 weeks of annual training for national guard over this event and the chicago 1/2 mile too.
Old 05-17-2014   #855
Track day tomorrow?
I keed I keed. Nice to finally drive this around a bit, a lot more pleasant well in a way than I remember.
Old 05-17-2014   #856
Track day tomorrow?
Old 05-17-2014   #857
So it's in the road now?
Old 05-17-2014   #858
On it yes. Went for a drive last night. Need some more plugs to finish the tune.
Boost is set and will stay at 28psi.
Need to get the car solid and plan some tall track days
Old 05-17-2014   #859
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Where's the rest of the wing? Or is that cool on a 1g? Sorry I'm new to that.
Old 05-17-2014   #860
Cooler than vanilla Fucking go ninja go ice.
Also the clips are super rare in good shape and brittle so anyone that has them seems to have them break on removal just like I did.
Getting the car running has been a priority over the wing.
