Old 09-06-2013   #61
97gsexx
97gsexx's Avatar
Drives: 97 talon
Re: 97 gsx build
Originally Posted by dogwhistle View Post
Do you mind sending me a copy of your current Link settings or files before SD so I can get a general idea for your timing? I am running the same cams, 2.3L, e85, garret 60-1 and many other similar parts. I am deleting my translator for a cable straight from the MAF and I understand my timing will need to be completely redone. Deleting the A/C is worth the weight savings if you ask me btw.
I am pretty much at stock timing, just slightly modified. If you want to pm me your email I can send you my current settings in link.
97 gsx (sold)
97 talon tsi awd 🐼
Old 04-01-2014   #62
97gsexx
97gsexx's Avatar
Drives: 97 talon
Re: 97 gsx build
Haven't updated this a while soooo..
Last weekend I dipped the wheels:
[IMG][/IMG]
My plans for this spring are to:
-fix oil leak
-delete a/c
-delete cruise control
-clean up engine bay
-get a fricken alignment (too low to fit on a normal jim bean etc.. so I need to figure something out)
-convert to speed density
-get a tune by shane (already have a $150 down payment)
-new oem slave and master cylinder
Hopefully nothing breaks so I can make it to proving grounds for the first time!
97 gsx (sold)
97 talon tsi awd 🐼
Old 04-30-2014   #63
97gsexx
97gsexx's Avatar
Drives: 97 talon
Re: 97 gsx build
Hey guys, little update for the build. Yesterday Mark and I started to shave the bay by deleting my a/c and power steering. It looks a lot better without the lines and pump on the driver's side and the battery dropped on the rear subframe.
Next I plan on getting a non cruise cable, put in my speed density setup, new clutch master cylinder, and fixing oil leaks.
BEFORE:
[IMG][/IMG]
AFTER:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Here is everything that we removed:
[IMG][/IMG]
97 gsx (sold)
97 talon tsi awd 🐼
Old 04-30-2014   #64
Re: 97 gsx build
Looks a lot cleaner, nice work!
Old 04-30-2014   #65
97gsexx
97gsexx's Avatar
Drives: 97 talon
Re: 97 gsx build
Yeah it definitely cleaned it up some.. My coolant temps are lower as well since I removed the condenser. For some reason my stock oil pressure gauge isn't reading since I removed everything last night. I checked the oil filter housing and it's still connected to the sender. I checked and I didn't lose any oil..
97 gsx (sold)
97 talon tsi awd 🐼
Old 04-30-2014   #66
97gsexx
97gsexx's Avatar
Drives: 97 talon
Re: 97 gsx build
Just switched to Speed Density! It was a lot easier than I anticipated. I used the SD cable from ecmtuning and am glad I did! Here is a pic of the new setup (haven't mounted the MAP sensor yet and still need to tuck the cable)
[IMG][/IMG]
97 gsx (sold)
97 talon tsi awd 🐼
Old 04-30-2014   #67
Re: 97 gsx build
Nice, I'm working on switching to SD as well.
The plugin cable is tits!
Old 04-30-2014   #68
97gsexx
97gsexx's Avatar
Drives: 97 talon
Re: 97 gsx build
Yeah it is, so worth the $40.
97 gsx (sold)
97 talon tsi awd 🐼
