Old 06-24-2014   #1041
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Re: Project Lex
Well would ya look at that, new quote came through with a price much closer to where I thought it'd be So one of these is on order now
http://prosportgauges.com/blueWhite-fuel-pressure.aspx
Someday I think I may switch all my gauges to the AEM ones, seem like better quality, but for now these seem to be a good balance between quality and price.
Dude! This is the one I had, when you get it there is a sticker that has a resistance specification. Grab a meter and ohm it, I had 3 bad ones in a row. They never got back to me with a refund or any resolution. He said they are gonna try to find a different manufacturer of senders. It was about 10psi off of what my fuel pressure was actually set to, which at least to me makes the gauge useless.
Ohm the sender when you get it.
http://www.mitsustyle.com/forums/sho...rosport+gauges
Old 07-02-2014   #1042
Re: Project Lex
Just got the car back from DB. They buttoned up the rest of the exhaust. I was going for a subtle clean look, and as quiet as possible. They nailed it! So it's basically a 3" turbo back w/ a Vibrant Ultra Quiet resonator in the middle, and a Vibrant Oval Muffler in the rear, with a 4" rounded edge/angle cut tip. The sound is louder than stock but still very quiet. On the highway with the windows down I don't even hear it. Thanks again guys!
https://www.youtube.com/watch?v=5fbx...ature=youtu.be
http://www.youtube.com/watch?v=5fbxi9muYpU&hd=1
ID:	14529   Click image for larger version
ID:	14530   Click image for larger version
Old 07-02-2014   #1043
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: Project Lex
2jz.. lawds.. sounds good looks nice too.
Originally Posted by 311evo
Old 07-02-2014   #1044
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Re: Project Lex
Sounds nice and quiet enough to not wake the kiddos!
Old 07-02-2014   #1045
Re: Project Lex
It's perfect, seriously.
Old 07-02-2014   #1046
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Project Lex
Looks great. I need to come see this some time.
11.35 @ 120mph
Old 07-02-2014   #1047
Re: Project Lex
Good fitment and sounds great; excellent choice.
Old 07-02-2014   #1048
Re: Project Lex
Now it just needs a tune! Might try some street tuning first to get it to the point where I know it'll do clean pulls, then have to try and find dyno time somehow since it seems all the local dynos are pretty booked up.
Old 07-19-2014   #1049
Re: Project Lex
Well I ran some thicker gauge wire to the coils, the old wires I think were too small and were causing it to break up. New wires in and the break-up seems to be gone, however there is some sort of strange buzzing sound coming from the rear under hard acceleration. No idea what it is yet. I looked under there and everything seems normal. I drained the diff and there is quite a bit of fine metal shavings. The magnetic drain plug was pretty coated in stuff too. Wondering if something is going bad inside there. Here's a pic kind of showing the metallic flaking. I know some small flakes aren't totally abnormal, but this seems like a lot to me. The pic doesn't really show that well but you can see some of it. Thoughts?
Name:	Diff Fluid.JPG
Old 07-19-2014   #1050
Re: Project Lex
New exhaust sounds great! Fresh fluid in the rear end and let'r buck. Drain it after some more miles and check again.
You sure it isn't the exhaust you're hearing? Either a resonance or vibration under load (i.e. engine movement)
Old 07-20-2014   #1051
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Project Lex
+1 on a refill and running it more.
Originally Posted by Trogdor
Old 07-29-2014   #1052
Re: Project Lex
I refilled with some off the shelf diff fluid to see if it would make a difference. At first I thought it did but nope, the sound is still there. I should mention it's not only a sound, you can actually feel the cars acceleration back off a bit too, so it's not just a let r buck situation. I just got done dropping the diff, will be bringing it in to get looked at on Thursday. In the mean time, I have a spare one coming that I'll swap in to see if the sound goes away. Spare one won't have LSD but that's OK, it'll just be my spare for times like this or if I grenade one at the track or whatever.
Old 07-29-2014   #1053
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Project Lex
I approve of these implications.
Old 07-29-2014   #1054
Re: Project Lex
So in the mean time while I'm waiting for the new diff, decided to work on the rear brakes. The 16" FD rims I picked up as my poor mans drag setup didn't clear the calipers by a nut hair. So I ground a couple spots down on the calipers ever so slightly. Then primed and painted them to match the fronts I did a couple years ago. Here's how the sit now drying. Then they'll get the Supra stickers and some coats of clear, and then back on the car!
Old 07-29-2014   #1055
Re: Project Lex
Looking good!
Old 07-29-2014   #1056
Re: Project Lex
John deere!
Old 07-29-2014   #1057
Re: Project Lex
Stickers on and 5 coats of clear. All done, just gunna let em dry and throw em on in the next couple days when I have some time
Name:	Rear Caliper.JPG
Old 07-29-2014   #1058
19TsiAwd90
19TsiAwd90's Avatar
Re: Project Lex
open for street, and have the lsd welded and swap it in at the track. or rebuild the lsd and weld the open one for the track.
Old 07-29-2014   #1059
Re: Project Lex
I'm confused, why would I want open rather than LSD on the street? I just want one rear end installed, don't want to swap them out for street/track. Just one installed, and a back-up if it were to ever grenade.
Old 07-30-2014   #1060
Re: Project Lex
Rear Calipers back on.
The new diff showed up. I slapped a coat of primer then a coat of black on it to clean it up. Will try to get it mounted up in there over the next couple days.
Also just a quick snap of the FD wheels that will become my poor man drag wheel setup.
Name:	Rear Calipers 2.jpg
ID:	14631   Click image for larger version
Name:	Spare SC430 Diff.jpg
ID:	14632   Click image for larger version
Name:	FD Wheels.jpg
