Old 07-22-2014   #41
blackrosenova400
blackrosenova400's Avatar
Re: Shari's 2009 Raliart
I contacted and sent pictures of the failure to a Mitsubishi service manager. He is contacting and sending pictures to his service represenative but doubts anything will happen.
Very sad as parts availability is scarce and very expensive.
20g Mafia
Old 07-22-2014   #42
The SST is a great transmission, but the maintenance/repair/replacement costs for it are enough to make your cringe.
Old 07-22-2014   #43
Hopefully they do something to help out, but I don't thing anyone would be surprised if they don't. I've never driven an SST type transmission on any car but they seem pretty sweet.
Old 07-27-2014   #44
blackrosenova400
Transmission/transfer case are out
More epic failure pictures with the transmission/transfer case out
Transmission
Transfer case Teeth are gone
20g Mafia
Old 07-28-2014   #45
Wow! Not at all what you'd expect to see from DD use!
Old 07-29-2014   #46
cmspaz
Walls need hugs too
cmspaz's Avatar
Well, when there's an OE seal that's missing, chances are pretty high you'll find plenty of things you weren't expecting.
Originally Posted by Trogdor
Old 07-31-2014   #47
blackrosenova400
Well just for shits I asked for a parts quote for a new trans and transfer case.
10812$ for the transmission and 3619$ for the transfer case. Ridiculous to say the least.
I'm in the middle of disassembly of the transmission. I need a special spanner wrench to remove the clutch assembly.
20g Mafia
Old 07-31-2014   #48
Wat? Mind blown. I would expect that for a Ferrari transmission, not a Mitsu.
Old 08-01-2014   #49
Gross, I drove an SST in a 2014 legacy it was horrible.
Old 08-01-2014   #50
SST is a Mitsubishi dual-clutch transmission, and it is not horrible, especially with tuning. Are you thinking of Subaru's CVT transmission?
Old 08-01-2014   #51
cmspaz
Walls need hugs too
cmspaz's Avatar
Subaru doesn't have a dual-clutch offering. CVT, you're probably thinking of. And yes, they're horrible.
Old 08-01-2014   #52
polishmafia
Smells like cat poop
polishmafia's Avatar
Holy shit! Thats about 90% of the car's retail price.
I don't know how you feel about used parts, but on car-part transmissions and transfer cases are $1000-$1500 depending on mileage/condition.
Old 08-01-2014   #53
Mark Leasure
Mark Leasure's Avatar
I recommend that you still write Mitsubishi North America a letter with pictures and description of this issue. This is a major miss with their manufacturing process, your evidence demonstrates that it is clearly insufficient. Keep it positive; include your VIN and other purchase information. Also demonstrate your brand loyalty, ask if they are willing to do something for you. I would state that your car is outside of their warranty. However, you still have expectations that this issue is unacceptable even if the car is outside of warranty. Under correct MFG processes of having that O-ring it would not have happened in the first place.
www.maperformance.com
Old 08-01-2014   #54
My bad it was CVT. It was disgusting. Sorry I got mixed up.
Good luck getting this figured and thanks for sharing.
Old 08-01-2014   #55
CVT transmissions are horrible; the WRX got one too.
Old 08-18-2014   #56
blackrosenova400
Transmission is disassembled, waiting to decide how I am going to make repairs.
Parking pawl is ok
Front differential is removed
20g Mafia
Old 08-18-2014   #57
Holy complicated. Hope you can get it figured out and back on the road relatively cheap.
Old 08-18-2014   #58
Sorry not a tranny guy, can you point out what broke?
Old 08-18-2014   #59
blackrosenova400
The differential is damaged, which you cant actually see the damage in any of the last four pictures. The front differential is the big gear on the top left corner of the second picture, which if you look at the last picture you will see is gone along with 1,3,5 gear cluster.
20g Mafia
Old 08-19-2014   #60
blackrosenova400
Everywhere I turn with contacting Mitsubishi they have zero interest in the failure and zero interest in helping me. I hope this doesnt happen to anyone else or at least they catch it before there warranty is out, but I dont know how you would as there were no symptoms.
20g Mafia
