Old 06-04-2014   #61
Speedfreak
Drives: four tires
Re: Anyone interested in Cobra adapter brackets
So the bracket will be sandwiched or will some of that be threaded?
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 06-04-2014   #62
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
That is a great idea! I could thread 2 of the holes..
Style's automotive engineer
Old 06-04-2014   #63
Speedfreak
Drives: four tires
Lol, I'll take credit, but that isn't what meant. I'd actually rather have it sandwiched, as the aluminum threads could pull when at operating temp on a track.
GSX - 571whp/490wtq
Sienna
Old 06-04-2014   #64
s1ngletracker
Drives: A BMW
Good point. I think i'm going to make some in stainless steel anyway, and i'll include that feature.
I could probably do a threaded steel insert in a hole... but probably not worth the effort.
Old 08-22-2015   #65
Time to bring this one back. So I finally got all my brackets, rotors, hub centric rings and rebuilt my 3kGT VR4 calipers and they don't fit my +42mm RPF1's, F^%#. I love the 13" rotors, so I guess the Cobra calipers are in. Any word on these brackets?
Old 08-22-2015   #66
Speedfreak
Drives: four tires
I wonder what if your setup will fit my rota's?
GSX - 571whp/490wtq
Sienna
Old 08-22-2015   #67
What offset wheels are they? I would think +35 or less would fit. I'll test my rear RPF1 to see.
Old 08-22-2015   #68
They stand proud of the rotor surface by 1.75", I didn't realize how huge they were.
Old 08-22-2015   #69
Damn iPhone pics.
Old 08-24-2015   #70
I think he's pretty close to having them made now. Sounds like track testing on the aluminum ones went well.
Old 08-24-2015   #71
s1ngletracker
Drives: A BMW
the aluminum adapters are rock solid. Well over 15 hours of track time and wheel to wheel racing, and enough heat to craze 13" rotors, but adapters are still flawless. Don't even have brake ducts yet (probably should do that..)
I need to make one small change to the design to make sure you don't have to modify knuckles (had to grind a ridge off mine) but I do want to have a run of them made. I wonder how many people would be interested? My kit would also come with hubcentric spacers. The rest are just nuts and bolts and the cobra stuff, easy for anyone to source and i'd provide part numbers, etc for all that. Maybe DB could stock them for me? Avoid shipping charges to MN.
Super busy prepping for another race this weekend at Gingerman in MI. They'll get further testing there, and i've got heat paint on them to really get a good feel of the range they reach.
Doing road race prep on this car has only expanded my list of DSM road race upgrade parts I really would love to see made and available to the masses.. Is there even a market for this stuff? I want to make a lightweight active toe eliminator kit, and a few other things.
Old 08-25-2015   #72
s1ngletracker
Drives: A BMW
So, turns out you can even clear GSX 17s! (needed a 1/8" spacer, not a huge deal)
Old 08-25-2015   #73
OEM 17's are pretty narrow, so they should fit with almost any other wheel.
Old 08-25-2015   #74
s1ngletracker
Drives: A BMW
FYI - just followed up on a local machining lead, and I should be good to go once i get him the models.
Old 09-19-2015   #75
s1ngletracker
Drives: A BMW
Sorry guys, we decided to do one more race so this is yet again on hold. For sure after mid october i'll be back on this
Old 10-22-2015   #76
s1ngletracker
Drives: A BMW
Okay, I'm back on this. I'm actually ordering a 3d printer today so i can really refine and iterate on the design. I'm actually going to attempt to integrate brake duct mounts/adapters as well, as this is something we need on our car.
I also need to make a few clearance tweaks and ended up having to modify my knuckle to make the other ones fit. I don't want other people to have to do that.
More news soon, hopefully at least a few will be interested. i also will be printing my own rotorcentric adapters. I bought some off the shelf (ABS) ones and they actually did okay with the heat from racing at a track with really really heavy braking zones (Road America) so i'm fine enough continuing to use them. I'll print them in ABS.
Should end up being a pretty sweet and affordable kit. I have a CNC lined up for the work, as well.
I'm working on another part for the car which I've never seen before, not 100% sure it'll work out (won't know until I really get deep into the design) but it might appeal a lot to hardcore road race people. Most people probably won't give a crap though.
Old 10-23-2015   #77
Though I don't have a dsm any longer, I'm really glad people like you are still doing part development for the community. Keep it up!
Old 10-23-2015   #78
You know I'm in for a set.
Old 10-26-2015   #79
s1ngletracker
Drives: A BMW
Steve, if you want some to try out before that happens, I can send you my extra set of prototypes. You might have to fight Goodhart for them, but I wouldnt' mind getting someone else to try them out.
Not sure who would try them out first
Old 10-26-2015   #80
I can bolt them up, but I'll be storing the car the minute the snow flies. Of course, that just might be in December.
