Old 06-02-2016   #61
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Re: Mark's Talon
Soo how's this look? 😝😄
BW8776, e-85
Old 06-05-2016   #62
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Well the engine might have to come out.. Didn't see the previous owner snapped a bolt in the carrier bearing on the block. Not happy. 😡 going to see if I can drill it out but it's a tight angle.
BW8776, e-85
Old 06-05-2016   #63
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Back out, gotta drill it
BW8776, e-85
Old 06-06-2016   #64
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Bolt came out, drilled and used an e-z out.
Got the engine back in. Just waiting on my manifold, then make an exhaust still.
BW8776, e-85
Old 06-07-2016   #65
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Manifold came! Got a couple days to throw it together and get some break-in miles on it
BW8776, e-85
Old 06-12-2016   #66
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Hoping to start it today!
BW8776, e-85
Old 06-13-2016   #67
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Got it started! Soo loud with only the downpipe on. Running a little rich (it's now on speed density) soo I'll have to lean it out a little. Only one oil leak from the feed line.
Gotta get some insurance on it again and go break it in!
BW8776, e-85
Old 06-13-2016   #68
Re: Mark's Talon
woot!!
Congrats
Old 07-09-2016   #69
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Had a little mishap happen.. Got on it and from the log the battery voltage dropped and caused it to go lean (11v on 30psi went to 13.5+afr).. #2 rod ended up snapping in half and breaking at the wrist pin, putting 2 holes into the block. Oil that shot out caught on fire and melted some of the wiring harness.. Thankfully had my fire extinguisher!
BW8776, e-85
Old 07-09-2016   #70
Dark2g
Drives: 2gb gsx
Re: Mark's Talon
Terrible
Old 07-11-2016   #71
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: Mark's Talon
Sorry to hear, that's terrible.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 07-11-2016   #72
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Good news.
Picked up a new block and some Ross pistons.
Started to pick apart the harness and see what all needs to be replaced, so far looks like the brake resivoir, knock sensor, speed sensor, injector resistor box, starter signal wire, blue black and brown plugs for timing ground and fuel pump test, and the ground on the intake manifold
Crank looks good and the head looks good.
Going to find some I-beam or x-beam rods, get the block assembled again and bring it in for a tune!
BW8776, e-85
Old 07-17-2016   #73
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
More carnage pics.. Harness is slowly getting put back to working condition.
BW8776, e-85
Old 07-17-2016   #74
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
What's left of #2 piston
BW8776, e-85
Old 07-17-2016   #75
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
#2 rod
BW8776, e-85
Old 07-17-2016   #76
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Hole 1 of 2
BW8776, e-85
Old 07-17-2016   #77
Re: Mark's Talon
damn sorry to hear. good luck getting it back together
Old 07-17-2016   #78
Mark Leasure
Mark Leasure's Avatar
Re: Mark's Talon
Sorry to hear, that sucks super bad! Get it back together! Nice setup too. Good luck.
www.maperformance.com
Old 07-30-2016   #79
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Little update.. Got the harness all done, just need to route it and put some wire loom on.
Got my new rods, went with the I-beams that Howard's Rods provides for MAP. Went with these as there is a pretty significant weight decrease over the turbo tuff I-beams I was debating between.
Can't wait to get back to boosting. Once the block is done and in the car I am hoping to put it on the dyno and have Shane work his magic. Really wanting to finish in time for proving grounds.
BW8776, e-85
Old 09-13-2016   #80
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Update: Haven't had much motivation the last couple weeks to get anything done. Car is most likely going to sit for the winter as of now.
Plans are..
Finish the block.. Still not sure on pistons.
Swap 1050's for 2150's or around there
Get rid of the single 255 and put in 2 Walbro 450's in a full blown dual pump in-tank setup.
Build a catch can and new coolant resivoir.
Repaint the firewall (fix fire damage)
New front suspension (control arms, knuckles, ex..)
BW8776, e-85
