Old 10-19-2016   #81
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Re: Mark's Talon
update: picked up a 97 GSX and while looking at it, I thought I've seen the car before.. Turns out it's Blakes old one! Guy he sold it to blew it up, then sold it to a guy who did a 6 bolt swap but couldn't get it started.. and now I have it!
Plan is to swap my stock block in and put the head from this one on, throw link at it and drive it though the winter or sell it.
BW8776, e-85
Old 12-10-2016   #82
97gsexx
97gsexx's Avatar
Drives: 97 talon
Re: Mark's Talon
So funny you bought my old car
97 gsx (sold)
97 talon tsi awd 🐼
Old 12-24-2016   #83
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Well I have all the parts needed to finish it up! Block goes to the machine shop this week I'm hoping. I also picked up a new resonator and tip for the exhaust to hopefully get rid of some of the rasp and quite it down.. also installed my launch control device and HBC in the cockpit. Got my new bov welded on and picked up a 2gb eclipse front bumper (since I love the way they look) and a set of 2gb headlights to go with equipped with hids.
Can't wait to start putting it together!
BW8776, e-85
Old 12-26-2016   #84
Re: Mark's Talon
moving along nicely
Old 04-13-2017   #85
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Little update.. Took everything to work and got every last bit of the fire extinguisher powder off. It made a mess and was in every hole/ crevasse. I also decided to get a Kiggly main girdle this go around with a new (reman) 150amp alternator. Just waiting to hear back from the machine shop so I can order my pistons and injectors.
BW8776, e-85
Old 05-12-2017   #86
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Block is still at the machine shop. Got my alternator wired up with some 2gauge awg and a 150amp breaker. Next is the inline fuel pump with a Hobbs switch.
ID:	16532   Click image for larger version
BW8776, e-85
Old 05-26-2017   #87
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Almost assembly time! Machine shop is honing the block then I can order pistons. Until then I have started to build a new coolant reservoir and catch can.
BW8776, e-85
Old 05-30-2017   #88
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: Mark's Talon
Looks good!
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 06-02-2017   #89
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Injectors and pistons showed up today! Went with the 2g wiseco hd's with the e85 coating and a set of FIC 2150's. I believe I now have everything to get it back on the road!!
ID:	16558   Click image for larger version
BW8776, e-85
Old 06-05-2017   #90
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Re: Mark's Talon
You have a week and a half!
If you can't afford to buy an EVO, might as well beat an EVO
Boomdeeze is offline   Reply With Quote
Old 06-05-2017   #91
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Lol not going to happen. Maybe by the spring one.
BW8776, e-85
Old 06-05-2017   #92
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Re: Mark's Talon
2018 spring? Or did you mean this fall? You going to the one in two weeks?
Old 06-06-2017   #93
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Block won't be done until the beginning of July so possibly this fall one we will see how the tuning process goes.
BW8776, e-85
Old 06-18-2017   #94
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Coolant reservoir done. Still debating on if I want to dump the catch can to atmosphere or if I want to add a Venturi tube/ hose to the exhaust to help with suction.
BW8776, e-85
Old 06-19-2017   #95
Re: Mark's Talon
If that's the route you want to go, Vibrant makes a kit.
Otherwise, I'd go to the intake/turbo inlet if it's a baffled or filtered catch can.
Old 06-19-2017   #96
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Catch can is baffled.. I know a few people who have gotten the vibrant one and I have made the conclusion that they don't put it at a big enough angle so it doesn't create much of a vacuum effect. I don't have an intake yet and not sure if I will have one made by this fall, that and I'm not to fond of going back to the intake pre-turbo. Even the thought of going to the exhaust scares me a little bit with fuel vapors.
BW8776, e-85
Old 06-20-2017   #97
Re: Mark's Talon
With a properly baffled catch can you shouldn't have any issues at all going before the turbo. I'd much rather pull a vacuum on the can than just venting. There's a reason why lots of the big V8 drag racers run crank driven vacuum pumps to their valve covers.
Old 06-22-2017   #98
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Not sure how well the baffles will work. I am going to be upgrading to -10an fittings on the next can I make with -10's on the front of the valve cover. By then I should have an intake setup made and will probably run it to that.
BW8776, e-85
Old 08-02-2017   #99
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Finally heard back from the machine shop and the block is said to be done this week! I can not wait much longer now knowing it's getting close! Hoping to put it together and get a good base tune on it in time for the cookout.
BW8776, e-85
Old 08-10-2017   #100
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Machine shop called back and unfortunately had more bad news.
My brand new MAP Howard rods don't fit into the Wiseco pistons because the pin bosses are too wide. How does this happen?!? Anyways I will be contacting MAP before anyone else gets screwed.
The fix is to machine the rods down to fit into the pistons.
Block should be done next week if everything else goes as planned.
Unfortunately I won't be making the cookout
BW8776, e-85
