Old 01-08-2014   #121
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Borg Warner Turbos
It's a X. stock turbo = 390 tq. fp black = 390 tq. LOL
Its tapered on purpose, and its not all about peak torque, its powerband and sustained torque that are "FTW".
Again, stock block here, with weak ass noodle rods.
Old 01-08-2014   #122
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
^^ that makes more sense. guess i didnt see the stock motor part. derp reading defeats me once again.
Originally Posted by 311evo
Old 01-09-2014   #123
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Murlo - youre hoping for low 11s I'm guessing?
2006 WW IX RS 396/404 - SOLD
Old 01-09-2014   #124
Murlo26
Murlo26's Avatar
Hoping...10's.
Realistically anything in 11's will make me happy. Even more realistic, getting to the track and driving down it will make me happy whilst not breaking.
Old 01-11-2014   #125
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Me too, I'm hoping for 10s but low 11s would make me happy, should be completely feasible. I should make 525/500 at map with this setup, turbo will limit everything
Old 01-12-2014   #126
URV8SUX
URV8SUX's Avatar
Hoping...10's.
A good day at the track is driving the car back on the trailer!
I think it will have a high 10 in it with a good short track!
Old 01-16-2014   #127
Murlo26
Murlo26's Avatar
Maybe if you own a trailer/tow rig lol
High 10 is longer term goal. short term, get car running again and get mid 11's. Then try for good time when I learn to drive it better at the track.
Old 01-19-2017   #128
Been a long time since I wrote anything in here, but figured it's worth an update.
Since the launch of the EFR line, BW has also now launched their SX-E line. The SX was their off the shelf standard turbo offerings, and what many came to know as the Sxxx series turbos (i.e. S256, S362, S366, etc). The SX-E (SX Enhanced) is their new standard turbo line. It builds off the SX line and the EFR line. They used a lot of the R&D that went into the EFR compressor wheels, and applied them to the new comp wheels for the SX-E turbos. The SX-E also got a totally new center section with a new bearing design (still journal). It also got updated compressor covers that are supposed to be more optimized than the SX line. They also got new turbine wheels (inconel). The SX exhaust housings still work, so the SX-E turbos are sold as super-cores (no exhaust housing) as they will swap right into your existing housing for anyone upgrading their SX turbos. So in a nutshell, they're basically a half breed of an SX and an EFR. And the best part, they are still extremely affordable! And anyone happy with the old SX turbos (which are still a great turbo), they are an even better value now that they sell for less. See this link below, you can see how affordable these SX-E's are ($700 price range from Jegs for a Super-Core, add $150 for a turbine housing and you're still under $1000).
http://www.jegs.com/p/BorgWarner/Bor...40656/10002/-1
Here's a little tick list of the improvements of the SX-E over the SX
- New improved billet compressor wheels (based off EFR compressor wheels)
- New compressor cover that was supposedly more optimized.
- New center section (new 360* bearing design over old 270*) which I've 'heard' has drastically improved their responsiveness
- New improved turbine design.
- Turbine Housings remain the same from the SX line.
- Pre machined spot for comp wheel speed sensor.
So I've been looking at these for several months, talking back n forth with Geoff from Full Race more than he probably wished to. Today I made 'a mistake' lol. I picked up one of the 8776 turbos from them (6467 in PTE speak).
My goal is to have the car running this spring. And sometime eventually swap this turbo on and try my best to do a before and after dyno. Talking with Geoff, we're predicting very similar spool, but with much better top end. How much who knows, but I wouldn't be surprised to see almost 100hp more. Limiting factor for me though might be my .91 Exhaust housing, may prove to be a bit of a choke on this turbo, but we'll see.
SX
SX-E
Old 01-19-2017   #129
97gsexx
97gsexx's Avatar
Drives: 97 talon
Great write up, thanks for the info! If I decide to go t3 I would definitely go BW. Would love to see the Lexus in action!
97 gsx (sold)
97 talon tsi awd 🐼
Old 01-19-2017   #130
That's what I ran on my dsm. S362 in a BEP t3 housing. That was a long time ago.
Old 01-19-2017   #131
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
I love my 8776 SX-E! Good write up indeed.
BW8776, e-85
Old 01-19-2017   #132
97gsexx
97gsexx's Avatar
Drives: 97 talon
Mark does like his SN pale ales !
97 gsx (sold)
97 talon tsi awd 🐼
Old 01-19-2017   #133
Haha great choice! What's your goals? I'm hoping I can get high 700's, and 140+ traps.
Old 01-19-2017   #134
mark4g63t
mark4g63t's Avatar
Looking for around the same, 700's with low 10s at least.
BW8776, e-85
Old 01-19-2017   #135
Nice. I will say the results I've seen on supras with these turbos are sort of all over the place. Mainly the 66 & 69mm version though. I still think PTE has the edge on HP for the size, but I personally still prefer the BW built like a brick shit house stuff for my own personal reasons.
Old 01-20-2017   #136
BW is the shit. My new Borg turbos flow 50% more than my old Garretts with quicker spool. Can't complain about that.
Old 02-05-2017   #137
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Cool, i personally went with a bw sxe 364.5 so far so good had to send it back for some minor oil burning, fixed and on its way back already 30 psi moves pretty good tho spool isnt bad either at all!
Old 02-05-2017   #138
What exhaust wheel and housing?
Old 07-26-2017   #139
Well might as well update this with my dyno graph. It's actually pretty similar to the graph I posted earlier of a 2JZ with the same turbo.
SC300 2JZGE NA-T
S300SX 84-75 (61mm) / 0.91AR T4TS
30psi tapering off by redline.
709hp / 665tq
Old 07-26-2017   #140
Nice.
