Old 02-23-2017   #1441
Re: Project Lex
Thanks man. It's actually called Fine Texture Black. Kinda like the OEM looking black plastic stuff that has a very fine texture to it. I like it cuz it's just subtle, easy to keep clean, and just hides things better (welds, little casting flaws, things like that). No more polished crap for me, I want this to be easy to keep clean lol.
Old 02-23-2017   #1442
Re: Project Lex
Looks good! Who did the powder work??
Old 02-23-2017   #1443
Re: Project Lex
Twin Cities Powder Coating. I think it's Lino that they're in, just up 35W from us. I like the black. The other color I'm not that excited about, but it is what it is at this point. Would rather find a guy who just does it out of his garage to be honest lol. They weren't particularly fast, or particularly cheap.
Old 02-23-2017   #1444
Re: Project Lex
So nice and clean!
Old 02-23-2017   #1445
Re: Project Lex
Seems like none of them are. Time to start up jkodis again!
Old 02-23-2017   #1446
Re: Project Lex
^^ Haha, that PC'ing system is long gone. If I had like a little hobby shop in a commercial area, it'd be a fun little thing to have off to the side. But never again in my home garage!
Old 02-23-2017   #1447
Re: Project Lex
So we are starting to turn the boost up from the WG pressure (12psi) we were running before. Did a pull / log at lunch today and sent it in. I quick looked it over for myself. Looks like 24psi at about 4800rpm. Then boost gradually tapers down to 20psi as we reach a nice conservative redline of 7300rpm.
Car finally feels like it woke up too! I'm paying no attention to the HP / TQ curves on this graph, but it does look like we're starting to touch 70lb/min airflow out of this little 61mm (and still at lower boost levels!). Looks like he has the AFR pretty safe at 11.0 and timing is still pretty conservative (10*-11* most of the time in boost, but peaking at 15* at redline).
Anyhow, the fun part is finally underway!
Old 02-23-2017   #1448
Re: Project Lex
You must have some real garden hoses to only be at 41 IDC!
Old 02-23-2017   #1449
Re: Project Lex
Yeah they are FIC 2150's. I'm actually getting some smaller ones. These will be up for sale. I'm going to switch to FID 1600's. Should be able to support 1000hp on e85 safely, and idle better being smaller. So the FIC's will be up for sale in probably a month.
Old 02-23-2017   #1450
Re: Project Lex
Pretty rough idle and low-speed drivability right now?
Old 02-23-2017   #1451
Re: Project Lex
It's actually pretty good on e85. But on pump, yes idle was not all that great. I'll probably make money in the end off this switch, so it was a no brainer. They are sized better for me, so will idle and drive better (especially on pump), they still leave plenty of head room, and also will be less prone to e85 corrosion than the 2000 sized ones are.
Old 02-23-2017   #1452
Re: Project Lex
Cool tuning logs! Wish I had a log like that from when I had my tune. I received the tune file but it doesnt show results like that.
Old 02-28-2017   #1453
Re: Project Lex
Little Update. Got the updated tune in. He turned up the duty cycle on the boost controller and didn't make any difference at all. So I started to wonder what spring (or springs since these can have up to 3 springs installed) did I actually have in my WG. Looked in my tool box and found the 7psi spring that originally came in it, and I found the 5psi spring that I bought along with a 10psi spring, that I thought I installed together. Also found an 11psi spring that I didn't even know I had.
SO I pulled the WG off and cracked it open. Only one spring was installed (assume it's the 10psi spring). Damn, this whole time I've been thinking I had both the 10 and 5 in there so I had 15psi of spring in there. Dumb mistake
What I find very interesting is how it tapers down to 20psi, and they always say the general rule of thumb is you can only go about twice your WG spring. So that pretty much seems right on the money in this case.
So I'm going to hit up Vlad to see what he prefers I put in there. With the springs I have, I can combine them to make 15psi, 16psi, 18psi, or 21psi. I'd like to just throw the 21psi combo in there because why not I don't plan to boost lower than that. But I think Vlad wants less because he'd like to have a safe pump gas tune which would be closer to the 16-18psi range.
So Andrew you had asked why the boost is tapering the other day, this might be the smoking gun!
Old 02-28-2017   #1454
Re: Project Lex
You could use a vacuum puller to determine exactly what you had, but makes sense on the 10psi spring. Something like 16lb spring makes sense if you want run 30 or less on e85, but I get the desire to run a higher spring if you're only running ethanol going forward.
Old 02-28-2017   #1455
Re: Project Lex
I have no idea how to do the vacuum puller thing. But I went back in this thread to way back when I bought some of these parts. You can clearly see on the WG package that this came with a 7psi spring. Then you can see photos of the new springs I bought (10psi and 5psi). So I think it's pretty clear to me now.
I'd like to be able to turn it up to 35psi if possible. So that has me leaning towards the 18psi combo since the "multiply by two" rule of thumb keeps me in that range. I'm guessing Vlad will want the 16psi combo for safer pump tune. But truth is this car will never see pump. In the extremely extremely extremely extremely rare case I have to fill it up with pump, that'd probably be some situation where it's some sort of long road trip and there's not e85 around, and so I have no choice. And in that case, I'll just stay out of boost.
That's my thoughts for now at least
Old 02-28-2017   #1456
Re: Project Lex
Just run the highest spring possible in that case if you're staying out of boost on pump. Why even get close to the 2x rule imho, easier on your WG if the spring is higher.
Old 02-28-2017   #1457
Re: Project Lex
I'll have a dial that I can turn boost up and down with. So I suppose it'll work fine if I have it set to lowest setting all the time and that's around 18 psi. All the way up is like 35psi or so. Seems like a nice range, and I'll probably just cruise around with it on the low setting all the time because plenty of fun to be had and fish to catch at 18psi, and easier on the car in general.
Old 03-06-2017   #1458
Re: Project Lex
Got a couple pulls in today. So my latest tune we're now up to 25psi. Haven't done a pull with it yet but the car is feeling good. Too good cuz 3rd gear is about useless so I'm having to do my pulls in 4th gear (No Jail Preeze).
Also, got my new injectors today. FID 1600 high-z. Going to wait a little while to install them as I want to keep moving forward with the progress we're making on the logs/tune for now.
Name:	2JZGE 1600_1.jpg
ID:	16430   Click image for larger version
Name:	2JZGE 1600_3.jpg
Old 03-07-2017   #1459
dogwhistle
dogwhistle's Avatar
Re: Project Lex
Was nice to see you! I'm excited for the results.
-Adam
aneujahr@maperformance.com
Old 03-07-2017   #1460
Re: Project Lex
Yeah same. Thanks again!!
PS - I ran into Chris in the parking lot on the way out. Took me about 3 double takes before I realized it was him!!
