Old 08-08-2017   #81
93gtpeater
Drives: cbr 1000rr repsol
Re: Back into the big leagues: Project FRC
My car has slp maf, air filter, bbk throttle body, deleted cats and magna flow exhaust. I hope i can trap 110 mph and run some 12s this weekend. Just hope the clutch holds up. Lol. Going to bring a cooler full of ice and ice the intake manifold in the pits. I know the car has a 160 stat in it but the fans weren't adjust for it. If iam free that weekend maybe I will come out again. Pending on my clutch.
Old 08-08-2017   #82
what clutch you get?
Old 08-08-2017   #83
Good luck! What year is your car?
McLeod RST Twin Disc and McLeod flywheel (steel). Added ARP Flywheel bolts, new GM Slave cylinder and pilot bearing and a remote bleeder line. Should hold the power as the clutch is rated to "800hp", so I figure this will hold the end goal of 500/500 at the wheels. When I start to spray the motor years from now I'll have to send this in to get it upgraded to a RXT with Ceramic plates so it'll hold 1k hp as I don't think the organic material will like a nitrous spray; I'll cross that bridge when I get there.
Old 08-08-2017   #84
Cool. What remote bleeder did u end up grabbing? I'm running the one from Speedway.
Old 08-08-2017   #85
Tick Performance.
Everything *should* be here for a August 19th evening - 20th install. I figure the girlfriend flies to Grenada that day so I need something to keep my mind off not seeing her for the next 4 months (last time).
End goal for the season is to crack a 12.5. At 2500rpm I didn't even have enough clutch to get the tires to spin. I could dump it and get them to hop (did that once, whoops), otherwise if I fed it any clutch at all they would grip and I would roll out. As my girlfriend said "you leave really slow"
Launching a RWD manual car is COMPLETELY different than my grip it and rip it days of AWD turbo cars.
Old 08-08-2017   #86
Reviewed logs. After looking at the torque curve versus the mph plot over engine speed, I am very confident the clutch was slipping the entire time. Boost is timing advance in power graph. The line that drops down like a spoon is an exaggerated torque curve. The other is mph versus RPM, it should be linear, not jagged like it is.
I can't wait to see how much power it makes with the clutch in it, haha. I wouldn't be surprised if it makes 350/350.
Video.
https://youtu.be/M69zeqWzvbw
Name:	12.877 @ 110.42 mph 3rd gear pull.jpg
ID:	16664   Click image for larger version
Name:	mph versus torque.jpg
Old 08-09-2017   #87
93gtpeater
Mine is a 99.
Old 08-09-2017   #88
Mine is a 99.
Awesome! Good luck and lmk if you need a tune
Old 08-09-2017   #89
Are you signed up for the "Team Tick" sponsorship savings program? If not you should see if you can. Some good savings on some stuff. I'm signed up!!
Old 08-09-2017   #90
Im happy with my Monster LT1 twin disk clutch and standard steel flywheel and it looks like its cheaper than the RST. Flywheel comes with it.
http://monsterclutches.com/c5-corvet...reet-c5-clutch
Nice runs at the track!
Old 08-09-2017   #91
Thanks! I was going monster but Amazon has the rst for $675 and flywheel for $281.
Old 08-17-2017   #92
Well my Sunday and next week are going to be busy.
Clutch and goodies are here. A "while I'm at it" bug bit me hard on this one, so I'll be designing and fabricating (with the help of a good friend) a "anti-wheel hop" differential brace using SS rods and heim rod ends as well as tying together the transmission and differential. That way when I put the entire assembly back up I won't have to touch it again until I build a differential and am really running sticky tires.
Progress and photos to come this weekend as I tear out the entire drivetrain.
Name:	lots of fabrication needed heim link.jpg
ID:	16682   Click image for larger version
Name:	clutch and brace main parts picture.jpg
ID:	16683   Click image for larger version
Name:	precision heim link.jpg
Old 08-24-2017   #93
It's been slow going but making progress.
Flywheel was in on Monday with long tubes still in place.
Quite a pain to get it past the long tubes, yes they are unbolted but it is just that tight in there.
Clutch was installed next.
First disc installed:
Using the 2nd disc to ensure everything aligns on torque tube
Twin disc in and torqued:
And now the current state. Waiting on some heim rods to be welded up for my custom transmission/differential brace as well as my anti-wheel hop traction setup:
Otherwise drivetrain is ready to go back home. I need to install torque tube + transmission + differential in one pass, subframe in a 2nd pass:
Hope to have the fabrication parts done tonight and maybe even the drivetrain in and installed.
Old 08-24-2017   #94
93gtpeater
Looking pretty good. We might have meet up and do some rolls.... lol
Old 08-24-2017   #95
I like that idea!
Old 08-24-2017   #96
Man, I hope I never have to tear into my drivetrain, but I'm sure the bug will bite me to upgrade something as well.
Old 08-27-2017   #97
Let me know when that roll action happens!
Old 08-28-2017   #98
Doing some serious work this weekend I saw!
Old 09-07-2017   #99
Clutch is in and almost broken in. Had to pull apart some of the car again to re-balance it externally. A little math and trial and error and the car is mostly vibration free. Slight vibrations that are from the solid differential setup around 1750 rpm for a brief window (and then around 650rpm, but doesn't do it again at 2850 or 3950 so its a resonance issue, not clutch).
Old 09-07-2017   #100
93gtpeater
Time for some fun runs
