Old 04-02-2018   #1141
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Re: House Projects
So tonight I started sanding the edges by the wall with a small palm sander thinking it was no big deal. About 30 minutes into barely cutting into the wood and the sandpaper flinging off 5 times. I went to home Depot and rented their edge sander. That made quick work of almost all of the corners. The tighter corners I'll hit with a handheld detail sander.
I also took some more pics of the wall we are moving back to it's original spot. The previous owners hacked this whole house together. Glad to breathe some new life into it.
Also, my back hurts like a mofo.
ID:	17003   Click image for larger version
ID:	17004   Click image for larger version
ID:	17006   Click image for larger version
ID:	17007   Click image for larger version
ID:	17009   Click image for larger version
ID:	17010   Click image for larger version
Old 04-02-2018   #1142
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Re: House Projects
Not sure why the photos are turned.
ID:	17013   Click image for larger version
Old 04-02-2018   #1143
Speedfreak
Drives: four tires
Re: House Projects
That's a lot of work! Staying the same color(stain)? Or changing it up?
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 04-03-2018   #1144
Re: House Projects
Let the fun begin!! Good job workin that wood man.
Old 04-03-2018   #1145
Re: House Projects
Asian Bob Villa! House projects are fun!
Old 04-03-2018   #1146
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Re: House Projects
We love the "blonde" look so if we can find just a clear coat that would be what we would choose. The lighter wood lightens up the rooms.
The parquet flooring in the hallway is getting removed but the previous owners tore out the original hardwoods so we aren't sure what we are going to do there. We would love to put some hardwoods in there get as close as possible to the originals but i'm not sure if that's possible. The home depot guy suggested Bauer Brothers to see if they have salvaged hardwoods.
We are going to re tile the kitchen when we remodel that and I'm going to check the soffit to see if it's removable. There is a light in there so hopefully it's not going to be a very intrusive job.
Old 04-03-2018   #1147
Re: House Projects
I need to build cabinets for my garage as well. I sheetrocked the whole thing, installed all the LED cans, heat and A/C, then quit. Still needs mud, tape, paint and cabinets. I have to quit buying car projects and make the garage a great place to work first.
I'm a little hesitant to use particle board on the cabinets as it absorbs any liquids like a sponge, but I'm sure a good oil based paint would fix that. B-man, I'll have to swing over and check the progress one of these days, I need to light a fire under my ass.
Old 04-03-2018   #1148
Re: House Projects
Yeah plan is an oil based primer sealer. Then I'll use a,latex paint for the top coat.
Old 07-09-2018   #1149
Re: House Projects
You finish those cabinets up Brandon and get any use out of them?
I'm trying to figure out what to do to my garage and think the material you used would be awesome to save some coin and I would like to probably paint match to match the garage color eventually anyways.
Any more updates from Pat? haha I need some motivation to get out in the garage and organize/clean and come up with idears.
Old 03-17-2019   #1150
Re: House Projects
Been slow moving but i finally got the cabinets primed. Used oil based grey primer. Stanky stuff!
Old 03-25-2019   #1151
Re: House Projects
That looks beastly. Gonna be pimp opening the door to that.
Old 03-26-2019   #1152
Re: House Projects
Nice work Brandon!
Old 04-05-2019   #1153
Re: House Projects
Painting on the casings is complete. Went with a dark grey semi-gloss. Pretty happy with it. Now to start adding shelves.
Old 04-07-2019   #1154
Re: House Projects
Adding shelves to the inside
Old 05-03-2019   #1155
Re: House Projects
Been working on electrical lately. I have power strips mounted. I have the t5 fixtures mounted. One underneath to light up the work bench surface, and one mounted to shine towards the car for imoroved under hood lighting. Each on their own switch. Still buttoning up that wiring. Also i bought 4 in ceiling soeaker from monoprice ($35/pr). Have our downstairs receiver land sub out therr for testing out. I also bought a used 8" 150w sub off ebay (same as the one im testing out). Hopefully get these ceiling speakers mounted and wired soon. I can fit a max 43" flat screen on the shelf, so im just keeping an eye out for some kinda smokin open box deal at best buy for a 40-43" smart tv (hoping for something around $150).
ID:	17269   Click image for larger version
ID:	17270   Click image for larger version
ID:	17272   Click image for larger version
Old 05-03-2019   #1156
Re: House Projects
Looking good!
Not that you've used the bench or cabinets much but I see it looks like normal work bench already with tools and stuff sitting on them. How do they be seem to hold up on initial use?
Old 05-03-2019   #1157
Re: House Projects
So far so good. I figured I could start loading them up since all thats missing there are doors. You can see i made the shelves the perfect height to fit oil jugs
Old 05-03-2019   #1158
Re: House Projects
I did notice how perfect those oil jugs fit in those shelves lol. How'd you attach the shelving? Use pin holes or just some boards on the sides for support to rest the shelf on?
I've watched and read a little bit on making the cabinets like you have and keep going back and forth on what I think I'd like. You're turned out looking awesome though.
You'll have to post up how you like the speakers too. I've got just a bosch portable boombox sitting on the work bench or floor depending what I'm doing and it works good and has some decent bass actually since it has a sub in it. But speakers in the ceiling seems super clean and less shit out. Maybe someday I'll figure out what I want and just get a smart flat screen tv, get a sound bar and a little sub and call it good enough lol
Old 05-03-2019   #1159
Re: House Projects
Well i took the day off work to get stuff done. I got the ceiling speakers mounted and wired. They sound ok, plenty loud, but really lacking bass. But thats ok because the sub helps there. I tried a bunch of different sub locations and configurations. One of the small upper cubbies fits it perfect and is the best sounding spot i tried. I also grabbed this receuver for free from my buddy who has been helping me. I think this will be the final configuration. Because the receiver is so deep i cant put a door in this spot, so im just going to leave these spots doorless. With the sub, the sound is awesome!
Went to best buy to scope out any open box deals. Biggest i can fit on the shelf is 43". They had a 40" Sharp Roku TV open box for $167. I almost bought it! But i want the biggest i can fit so im gunna hold off for a 43. So no tv for me today.
ID:	17274   Click image for larger version
ID:	17275   Click image for larger version
ID:	17277   Click image for larger version
Old 05-07-2019   #1160
Re: House Projects
Looking good!
That shit looked pretty sweet when i dropped that book off the other day.
