Old 04-09-2005   #1
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
fixing Bog?
My cousin's 92 eagle talon tsi awd has bog. Well, when ever he revs it high and clutches, the car shakes. He tells me its hard to explain what the problem is. When he drives it normally, nothing happens, but when he revs it and upshifts, the car shakes alot like you're having a seizure (sorry for spelling). He just got the Walbro 255 in and I was wondering if it had to do anything with the fuel/air regulator...or something like that, just some of my theories. My brother said that the fuel line is probably clogged and not enough fuel is getting in the engine? Thanks if any help! If not descriptive enough, I will reply back again ASAP. THANKS!
ლ(ಠ益ಠლ)
Old 04-09-2005   #2
awd-drifter
'2of9'
Re: fixing Bog?
Oh yeah...he says its coming from the engine, not the tranny.
ლ(ಠ益ಠლ)
Old 04-10-2005   #3
Re: fixing Bog?
uhh...try again? (with that description).
bog as in your slammed into the dash? bog as it stops reving? bog as it vibrates like hell?
Old 04-10-2005   #4
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
Re: fixing Bog?
Sounds like bad plugs or wires. I would guess the wires with the info given. When was the last time it had a tune up done?
Mine used to shutter under pinned throttle and around 3500-4000rpm when the plug wires were bad.
Old 04-10-2005   #5
awd-drifter
'2of9'
Re: fixing Bog?
I'll go to his house today, ride in it, see how it is and see or hear where the problem is. It's whenever you rev it high, upshift and right as you up shift, the car shakes alot. mostly seems like coming from the engine.
ლ(ಠ益ಠლ)
Old 04-10-2005   #6
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Re: fixing Bog?
Then I don't know what to tell you. I thought you meant that it did it under load. Or maybe I'm just not understanding what you are trying to describe.
Old 04-10-2005   #7
CarPsyco84
CarPsyco84's Avatar
Re: fixing Bog?
sure sounds like fuel starvation from the pump, but if it still doest it with a full tank, then thats out of the question, what about the BOV return hose, when I pull mine off and be ghetto, it will do that because you blow off a bunch of metered air, that doesn't make it to the engine, so it actually floods for a second, causing it to stop firing momentarilly
Old 04-10-2005   #8
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Re: fixing Bog?
I didn't even think about the recirc hose. If that is off of there it can cause drivability issues without proper tuning. But usually if you pin the throttle it will run fine. It's mid range with partial throttle that usually makes it buck if the recirc hose is gone and the BOV is vented.
Old 04-10-2005   #9
john
Business as usual
john's Avatar
Re: fixing Bog?
If the bov is vented, it doesn"t matter if you are at WOT unless you shift like me with the foot on the gas. It will always "bog" down when you enter the next gear.
97 Viper GTS
Old 04-10-2005   #10
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Re: fixing Bog?
Even if you speed shift there is a good chance the car will still bog, when I had a SSQV on my car even if I shifted with my foot on the gas the car would fall on its face for a moment then take off. Either way, it will hamper the performance of your car if you don't have the proper equiptment to vent.
CRAIG
Old 04-19-2005   #11
awd-drifter
'2of9'
Re: fixing Bog?
Okay, back with results, and as I thought, it's pretty damn hard to explain. He's not speed shifting. Okay, I'll try best to explain:
Okay, when pushing the car up to the 5000+ rpm range, up shift, the car shakes a little bit. I felt it, it felt like as if the car was lagging when ever shifting from high rpms, but when driving normally, it drives perfectly. Right as you shift from a high rev, the car seems to have a little shake right after the shift, seems like a little lag from just switching to gear, but its not the tranny, but it was a quick little shake when ever shifting. No rpm drop, no gear grind, no funny noises comming from engine, just has a little shake right after shifting from a higher rev. He didnt floor it, because i know how it feels like when it's floored, he was just driving it fast, but not flooring the gas pedal to the metal, just enough for me to feel the beginning power of the AWD, which was like (from a stop or roll) 1000 to 6000+rpm, shift, little shake, than goin fast. It's hard to explain, but just wondering if you guys ever had this issue.
ლ(ಠ益ಠლ)
