05-14-2005
#21
Drives: a pos
Re: Drop the freaking wrench already!
Sounds like this motor came from the same guy I got one of my cars from... Some people just shouldn't try when they clearly have no clue or concept of what to do.
05-16-2005
#22
Hates Everything
Drives: Neon
Wow, seems like a real garage mechanic to me. I bet they didnt use a torque wrench at all, just "eh fuck it, snug um up reely good'n it'll be yall rite".
And Mike, about what you were saying about staggering the rings, have you noticed them being un-staggered when pulling motors apart. From what I have seen, it seems like after break in, the rings would stay pretty close to the part of the cylinder wall that they broke in on in the first place. I know that now machining tolerances are very close, but you would think that the rings would wear in to a point and kind of lock themselves where they are? I dunno, just an observation.
420A > LS1 > All Else
I > All else
05-16-2005
#23
ConArtist
Nice thought, doesn't quite work that way. They don't wear enough of a groove in the cylinder wall to maintain a position relative to their install. They actually do have a tendency to line up to some degree, not always, but it is common to find them in a row on a motor that has run for a while. The main point is that they are completely free to spin in any way they choose and there is little short of pinning them that will stop it. It is good practice regardless to stagger them and for that reason it should be done. I always have and always will. If there is any chance they will maintain position, it is worth the few extra seconds
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
05-18-2005
#24
Hates Everything
Drives: Neon
Interesting, then I have another question!
What is a modern break in actually doing then? If the rings dont "wear into the cylinders" then what is a modern break in actually doing? Assuming all the Machine work is correct and true, then what is actually "breaking in" on the motor that manufacturers and even professional race engine builders still suggest a break in? Assuming that the rings will always turn inside (havent seen anything proving they do or don't) then all that the rings and cylinder walls are doing is smoothing themselves out. In that case, I only see a break in procedure lasting 10-15min of 2000rpm and then a few times under load and the motor should be 99percent "broken in". Hmm, time to do some more research for me.
(And yes, every motor I have/will ever build will get the rings staggered)
I > All else
05-19-2005
#25
The rings do seat against the cylinder walls, but it isn't anything that would wear a groove in the cylinder wall. That is the main thing that happens on break-in.
05-19-2005
#26
ConArtist
As mentioned, the primary reason for break in is getting the rings seated in. Before modern plateau honing methods, it took considerably longer as it was the rings job to level off the peaks left by the honing process (microscopic) Of course that wears the rings considerably more as well. Now days the rough honing is followed by a much finer hone that levels the peaks off so most of that process is already finished. In cases where plateau honing is used, the break in period is very quick almost as soon as the engine is warmed up. definately after the first few pulls. The main point is that in either case, the rings do not effect the cylinder wall nearly enough to leave any "guide" or retaining type ridge for the ring gaps to maintain a stagger. Just doesn't happen. In fact like I mentioned, they have more of a tendency to line up. I pulled another stock engine apart this week that 3 of the 4 pistons came out with all the ring gaps lined up. It had over 150K on it.
BTW, it is worth checking with whoever does you machining to see if it has been plateau honed so you know what is appropriate for break in. It seems like there are still quite a few shops that don't use it. They really all should.
651-488-7774
05-19-2005
#28
ConArtist
Funny man E. That book just showed up, and like I expected, there were a few valuable bits of info in it. No one person knows everything, it should be everyones goal to be the best they can at whatever they may be trying to do which means lots of research in every concievable area. That specific book is a good reference regardless.
But more direct to the honing thing, that info has been in my old brain for more than a few years
651-488-7774
05-19-2005
#29
On Randys motor I just built we did a compression test after warming the car up for the first time, so 5-6 min of run time and already had 175 across the board. And checked on the dyno after 45miles(and 500+whp at the time) and it was 190 so I would say breaking in a motor would have somthing to do with how long it will last, not just to get compression and hold power.
05-19-2005
#30
ConArtist
As usual, this thread has gone way off topic, so considering that it sounds like there is enough question as to why breakin is important and what it's primary reasons are etc maybe we should start an engine building basics thread in the tech area and hit all these topics. People obviously need the help, this week we pulled apart 90LaserRST's motor and of course found stupid mis-informed mistakes on it as well. (Not done by him I am told)
but none the less if people are going to insist on doing this stuff themselves, maybe they should have a resource where they can get the info to do it right and understand why.
651-488-7774
05-19-2005
#31
Building engines is your business.
Every business has their secrets... but also some businesses don't have morals and are greedy.
You informing us on your secrets proves what part of the small % of the businessses you fit in.
#32
ConArtist
I appreciate the comments E. I am actually more concerned that if people are going to do this, that they do it correctly. The "secrets" that matter for making more power and doing things at a higher level, still get reserved for customers. I really don't do "stock" rebuilds so me helping people with understanding the correct methods and what they should and shouldn't do and why won't effect my business in a negative way at all. I want to give to the community, but at the same time, there has to be a good reason why people bring their stuff to me, if I told everyone what I do or all I know, they would have no reason other than my overly careful practices. Regardless of what past employees and friends have seen over the last couple years, I only let them see what I want them to see, I keep the stuff I don't want to share pretty much to myself. There has been nobody up to this point that has utilized all the little tricks I know, there are a few in the very near future that have agreed and are willing. BTW, the options are only thrown out there for consumption after I find out what the goals the customer is after. Some stuff, if it isn't needed to reach the goals they set, just isn't brought up. They are all overbuilt anyway
651-488-7774
05-20-2005
#33
Br0k3N
Originally Posted by EclipseGST
LMAO! ARP moly as lube. What could be better?!? Gotta love the newbies. I have done some pretty stupid things before but damn, how can you be that stupid? This isnt small engines class in highschool anymore where your messing with $50 motors. Some people need to get a clue!
Then maybe you should explain to me why we found moly lube on the bottom half of my ARPS going into the block? Im pretty sure that is absolutley worthless and noob like. Maybe you should go back to small engines class, you clearly shouldnt have passed. Also, maybe you should go back to 1st grade english class. That is where they teach you to read ( Cough :: DIRECTIONS :: cough).
I barely passed small engines myself, and no the briggs didnt ever run!! haha, thats why I pay mike to build my engine
- Josh L.P.
05-20-2005
#34
Last I checked one right plus one wrong doesn't equal two rights. Congratulations that the ARPs were installed correctly. Get off your horse.
Originally Posted by Tachyon
05-20-2005
#35
..good thing you built my motor, huh raptor? I think it's overkill at the moment though..I think a bigger fmic, turbo and injectors are in order..
-A. Swift
05-20-2005
#36
ConArtist
Overkill is good isn't it  Much less in life to worry about.
651-488-7774
05-20-2005
#37
..very true..I just gotta fix the oil leaks, and fix the exhaust, and wait for that fuel rail, then tap the exhaust mani for the egt probe..arg..projects these days..lol
-A. Swift
05-20-2005
#38
OVRKILL
pretty good liscence plate!
my engine is so frickin bulletproof. :|
05-21-2005
#39
I am looking at the little piece of paper that comes in the ARP box...
First off, it says: Use ARP moly whenever possible... So considering its possible to use it in the block threads, I used it.
Second: Since most studs extend into the water jacket, coat threads with oil or ARP moly lubricant and screw in hand tight ONLY. NOTE: If permanent mounting is preferred, Loc-tite may be used, You may also use high temperature RTV silicon. Whatever product is used, it is imperative that the cylinder head is installed and torqued to the proper level. Install the gasket and head, then lubricate washers and nuts with oil or ARP moly prior to their installation.
Thats what it says on the little piece of paper that I just pulled out of a brand new box of ARP studs.
Like I said... I am not perfect, I dont know everything and I have done some stupid things before. Shit I do stupid things all the time. So if they are saying to install them wrong then I guess I am a fool for following directions and also doing what they taught me in school (Tech). I dont remember you being around much when I was puting YOUR motor in YOUR car. Oh wait you were sleeping, thats right! When you knew I was doing all the work for free to help a fellow DSMer out who needed to get his car running. Then you got pissed at me cause I couldnt make it up one weekend and you really wanted your car done. Then when I got the car running, what happened? You stopped talking to me... Never called anymore, wouldnt return calls, not even a Thank you. You did help me get that turbo from Peter (Eclipseturbo I believe it is) which I appreaciate very much since I was in pretty much despirate need of a turbo. But it seems as if you just were going to use me and didnt give a fuck about anything once your car was running. You must be too good for me, sorry I am not a professional engine builder and I was the cause of your motor going to shit. Also, I would like to know how that affected your motor? What did it do to it? Cause I guess I cant do it right, might as well learn from it.
05-21-2005
#40
Br0k3N
Sounds like you took that to heart jakey  Too bad I was just screwin around. Its not like putting the moly lube there is bad, it just doesnt do anything lol. And since you love to give me shit I decided to give you some. And for the record, i still talk to your ass lol. And you werent the reason the engine went to shit! It was from sitting too long and the cylinder walls were pretty fucked  You need to calm down. I thought your original post was funny.. that was where this came from.
- Josh L.P.
