Old 05-24-2005   #1
xluciusx
Send a message via ICQ to xluciusx Send a message via AIM to xluciusx Send a message via MSN to xluciusx Send a message via Yahoo to xluciusx
Throttle body boost leak
So I have a boost leak that is coming from the gaskets on the throttle body. Would it be stupid to just put some RTV on around the outside where the gaskets are?
xluciusx is offline   Reply With Quote
Old 05-24-2005   #2
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: Throttle body boost leak
Yes!
Take her to the limit!
Old 05-24-2005   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
You could try it but it will be ugly and might not work. I used rtv instead of a gasket before and it worked fine but it would be best to just replace the gasket as they aren't hard to replace.
7/25/09
Old 05-24-2005   #4
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Some of the reason our car get a bad rap for being unreliable, is people half assing things like this IMOP.
Old 05-24-2005   #5
It probably isn't much of a leak around there. I wouldn't worry about it. If it is big, there are some o-rings or also gaskets you can buy to put in there. The gaskets are a bit better, but harder to find.
Old 05-24-2005   #6
xluciusx
From what I can tell it doesn't seem to be a very bad leak thats why I didn't really want to replace the gaskets but I probly will rather than doing something the ricer way.
Old 05-24-2005   #7
Living up to your name again I see...
Old 05-24-2005   #8
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
I pulled the bad gasket off and used only rtv instead of one before until I could get another one since it was late. Are you saying it would have been better to use a leaking gasket than rtv for a day until I could get another???
What else are you talking about. Nobody can say anything about you because you never had a car that ran right?
7/25/09
Old 05-24-2005   #9
FORSFED
I'm guessing that if it had been leaking for some time, one more day of a little leak probably wasn't going to hurt anything...
FORSFED is offline   Reply With Quote
Old 05-24-2005   #10
MD340327 inlet elbow side of TB
MD192535 intake mani side of TB
Both are available from Mitsu.
Spray copper coat and put them on. No leaks.
Old 05-24-2005   #11
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
Actually it was just after being put back together and swanny was coming over to help tune later in the night so it just was noticed and needed to be fixed.
7/25/09
