Old 03-05-2006   #1
4Las90
4Las90's Avatar
Drives: Evo 8 RS
Send a message via AIM to 4Las90 Send a message via MSN to 4Las90
Headlights went out
Last night I started driving and my headlights wouldn't come on. I flipped them to brights and they flashed on for a second and went out. When I looked under the hood I could smell like a wired burned out or something. Can I get some help on where to start and what to check first? Thanks
4Las90 is offline   Reply With Quote
Old 03-14-2006   #2
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
Re: Headlights went out
check the fuse? my brothers gvr4 headlights go out randomly when the fuse wiggles out enough.
Old 03-14-2006   #3
stcloudgsx
stcloudgsx's Avatar
Send a message via AIM to stcloudgsx Send a message via MSN to stcloudgsx
Possibly your voltage regulator on the alternator went out. I had that happen with a brand new alternator. While your driving check and see if your dash lights appear brighter than normal, or even while revving the engine.
stcloudgsx is offline   Reply With Quote
Old 03-14-2006   #4
Have you checked...da da da dum....the bulbs? If they are still good look at the wires and fuses.
Old 03-15-2006   #5
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Mine did that too. There's wires behind the headlight assembly that were touching/grounding out. Check all that..., wrap anything up in elec. tape and replace the headlight fuse which is a green fuse.
'04 Honda Ricer: stock
Old 03-15-2006   #6
95tsiAWD
95tsiAWD's Avatar
Some salt and ice melting solutions the DOT puts out might have worked its way into the wiring harness and melted some wires. Underneath the radiator and near the ABS pump (on a 2G). Happened to me, cost me about $400
In certain extreme situations, the law is inadequate. In order to shame its inadequacy, it is necessary to act outside the law. To pursue... natural justice. This is not vengeance. Revenge is not a valid motive, it's an emotional response. No. Not vengeance. Punishment.
95tsiAWD is offline   Reply With Quote
