Old 09-02-2009   #21
4seasons69
4seasons69's Avatar
Re: Yep..another one.
looks good!
Old 09-02-2009   #22
Constant_Project21
Constant_Project21's Avatar
Drives: E36
It has it's problem spots, nothing too major.
Old 09-02-2009   #23
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
nice! looking good.
Old 09-02-2009   #24
Constant_Project21
Drives: E36
nice! looking good.
Come check it out and get that timing cover while youre at it lol
Old 09-02-2009   #25
tehehodi
Braaaaaaaap!
tehehodi's Avatar
well i don't have your number....
Old 09-02-2009   #26
cmspaz
Walls need hugs too
cmspaz's Avatar
Looks good.
Originally Posted by Trogdor
Old 09-02-2009   #27
Those are the stock GSX side skirts. The 1gb Talon had the skirts and door moldings that went all the way up to the body side molding. That's the same way my car is, but mine has the talon tail lights and bumpers.
Old 09-02-2009   #28
Constant_Project21
Drives: E36
So the timing belt keeps moving closer and closer to the block, fixed the oil leak today, but the timing belt is getting chewed up :/, any ideas on why this is happening?
Old 09-02-2009   #29
notsostockgalant
3g camaro owner
id check the crank pulley out that happend to my old one aswell. Pully got loose and the lower timing belt drive got cockeyed from the belts tension
notsostockgalant is offline   Reply With Quote
Old 09-02-2009   #30
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Did you drop a bolt down the timing cover or take the oil pan off? If you took the oil pan off, you likely put the bolts in the wrong holes. You might have a longer bolt rubbing against it. The previous owner did that to the first dsm we ever bought. Good thing we decided to take the top cover off once.
The crank pulley seperating doesn't mess up the timing belt. At least not in my experiences.
7/25/09
Old 09-02-2009   #31
There's a thin aluminum plate between the balance shaft pulley and the timing belt pulley that holds the timing belt away from the block, make sure that's still in place and make sure the large bolt holding those on is not loose. Another possiblity is that either the TB tensioner pulley or the TB idler pulley is worn and wobbling in there making the belt jump around.
Old 09-03-2009   #32
Constant_Project21
Drives: E36
My buddy says that he put the tensioner on backwards and it's pulling it towards the motor. Gonna tear it down again tomorrow and check things again. Just waiting on brakes and need to swap shifted linkages before it's ready to rock.
Old 09-03-2009   #33
john
Business as usual
john's Avatar
If James is right, you will see a line wearing on the outside of the timing belt. Not sure when my buddy/if he messed with the timing belt. It has ARPs I think so he must have replaced it.
97 Viper GTS
Old 09-03-2009   #34
Constant_Project21
Drives: E36
Haven't touched the oil pan, and the cover has been off 3 times now, so I know there's no bolts down there.
Old 09-03-2009   #35
john
Business as usual
john's Avatar
I guess what he is asking is if it looks like something is rubbing on the timing belt. On a car of mine, a prior mechanic put too long of a bolt in the oil pan and the timing belt rubbed on it creating a grove in the belt.
I am guessing it is not the issue here but that is what he is saying. I would look at what Steve (Goat Blower) is saying.
What was the oil leak, the oil filter housing gasket??
97 Viper GTS
Old 09-03-2009   #36
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
The belt was new. I did the HG and ARPs on it. Maybe had 2 minutes of running time on that T-belt. Too bad your buddy put the tensioner on backwards.
7/25/09
Old 09-03-2009   #37
tehehodi
Braaaaaaaap!
tehehodi's Avatar
saw your car today! looking nice! good luck with the timing belt issue and thanks for hte cover!
Old 09-03-2009   #38
jhaan_dude
jhaan_dude's Avatar
Drives: a car
damn tehehodi i must have just missed you! by like 10 minutes!
Old 09-03-2009   #39
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
Damn you guys get up early. Unless you meant to say yesterday.
7/25/09
Old 09-03-2009   #40
Constant_Project21
Drives: E36
John-The oil leak is from where one of the balance shaft pully bolts was, and since there isn't a pulley there, there was just an open bolt hole pouring oil out...haha.
Tehehodi-thanks, and youre welcome for the cover, isn't in the greatest shape. Sorry for not sticking around, I was wiped out from yesterday.
Julian-get a haircut
Slowbubblecar-yea they meant last night haha
Timing should be fixed today, waiting for my full brake set-up to come in from Iowa, should be here tomorrow or saturday.
