03-11-2012
#41
Re: Carl's 98 auto AWD project Black Magic
wat? nlts + auto = does not compute. lol
Originally Posted by scheides
03-11-2012
#42
Drives: 98 Eclipse GSX Auto
Its not really NLTS but uses the NLTS function durring stalling/launching
03-11-2012
#43
Drives: You crazy!
So your using for 2 step? More info
03-11-2012
#44
Yes you use the brake switch because it reacts faster then the speed sensor. then you actually use the anti lag feture to pull enuf timing that you dont blow through the brakes at the line. when you let off the brake pedal timeing instantly comes back on and off you go.
03-11-2012
#45
Drives: You crazy!
Nice! I'll have to look into that. I heard the autos pull timing, and you can switch to a 5 spd. ecu but I thought that was a 1G issue only.
03-12-2012
#46
I forgot about doing that, I'm gonna wait till I can actually make some consistent track visits or get time to work on the car.
03-12-2012
#47
Yeah I wasnt planning on doing it but the relay was still there from before. Just had to run a wire up to the brake pedal and plug it in. Thanks Todd
I was planning on haveing the turbo in today after work but my gasket kit didnt come in yet.
03-17-2012
#48
Had the whole day to my self today so I got alot done and it is almost ready for the road. I got the turbo installed Tursday after work , and got the FMIC mounted up last night. I spent most of today Swapping in my HSK 272 cams and installing MAPerformance High performance Head studs. Both wen in better then I exspected.
I still need to finish plumbing the intercooler. And I am picking up a radiator (mine started leaking) and 1000cc injectors from TKR on monday
03-17-2012
#49
Nice work. What method u use to switch cams?
The good old leave the belt on and pull the gears off? or the whole T-belt job way?
03-18-2012
#50
I had adj cam gears so the whole T-belt way. I kept the old belt so I just marked the belt where the notches were on the cam gears and marked the crank pully so lineing everything up was easy.
04-01-2012
#51
I got the car out on the road today on stock injectors and wastgate pressure . Over all everything seams to be working good. I still need to do a boost leak check since spool seams a little slow and boostest in link is about 5psi high. So I'll probly pick up a 2.25" cap for the turbo this week and do that before I do mutch else. Full line pressure shifts are working good. wideband and gauge are functioning like they should. car is running pig rich on stock maps right now so the car feels prety slow compaired to what I'm used to but already better then the t25 with ALOT left in it.
Injectors , E85 and 30PSI to come.
04-01-2012
#52
Drives: 98 GSX, 04 is300
NICE! congrats on getting it on the road!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
04-02-2012
#53
Great job! Seeing all these cars get back on the road makes me sad.
04-02-2012
#54
Nice work!
04-02-2012
#55
Get working on yours!
I need to update my thread too, finally touched it.
Nice work carl.
04-02-2012
#56
Awesome!!
04-02-2012
#57
Originally Posted by Halon
Awesome!!
It is awesome. Even at wastgate pressure the car is fun to drive.
I did a boost leak test after work and found and fixed alot of leaks. Aparently some of the T-bolt clamps I got with the FMIC were to big for the pipeing. I knew they were all the way tight but I thiought they would seal. I thought wrong. I had 3 leaks at couplers. Got those fixed alog with a new O-ring on the biss screw. I think it should be alot better now. I dont know If I'll get the car out for a test run tonight or not.
04-06-2012
#58
I took the car to run a few erands this afternoon. The car drives amazing. idles dead on no surge very good street manors. I did a few WOT pulls at wastgate pressure and the car pulls pretty good and shifts firm. I did notice that the car needed to be completly floored to downshift and that the loged TPS in link was only around 90%. so when I got home I adjusted the TPS per dsmlink directions and I now get a true 100% TPS now so hopefully it wil kick down a little easer now. The stock injectors are completly maxed even at wastgate pressure so I will be picking up some 1000cc or bigger injectors and adding some E85 soon.
04-06-2012
#59
Man, if you're ever cruising around Blaine, gimme a shout I want a ride!!
04-06-2012
#60
I'm sure I'll be out that way. Aarons always trying to get me out there too. I think this car will do more cruising then the old one.
I always forget to add to my other updateds that the AC blows Ice cold too. A must have for a black car with leather interior.
