Old 11-22-2012   #681
Re: Project Lex
I thought you were going to use por15?
Old 11-22-2012   #682
Re: Project Lex
I think powder coating anything possible is a great idea..we have a great local and reliable resource for this and cost is low enough to make it worth it.
Looking good man!
Old 11-23-2012   #683
Re: Project Lex
Exactly, while it's out might as well just get everything coated that I can.
I did considered por15, but just decided to use Rustoleum. Don't think I ever said that I was 100% set on the stuff.
Old 11-23-2012   #684
Re: Project Lex
I've been doing research to undercoat my civic and apparently por15 is pretty spendy and needs a lot of prep, for something that you plan on not seeing any salt it looks like you went the right way.
Old 11-23-2012   #685
Re: Project Lex
This is super random but I had a dream last night about you and your car. You got the trans and rear end in a rush to make an appointment with Shane and you threw it in and turned up the boost w/o changing anything else and made 599...you were flipping outwith excitement!
Old 11-24-2012   #686
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Re: Project Lex
He didn't mention you are naked throughout the entire dream.
Converted to LS
Old 11-24-2012   #687
Re: Project Lex
Lol, Scheides you must have gone back and read posts 578 - 586 or something...
Anyhow, no huge updates, but I did get 2 coats of paint on the rear diff. Looks much better I think compared to the old!! Going to give her one last light coat and call it good.
ID:	13075   Click image for larger version
Old 11-25-2012   #688
Re: Project Lex
Haha no homo!
Old 11-25-2012   #689
Re: Project Lex
Shot a light coat of black on the wheel hubs and rear axles to clean them up and prevent rust. Put the last coat of black on the diff. And shot the areas under the car where I put the rust inhibitor. The paint already feels pretty solid so I think it'll be good.
Depending on how much they end up quoting me for that rear subframe, I may listen to you brownman and just shoot it with this stuff too, I'm liking it so far!
I also just purchased a pair of new rear brake rotors (slotted, zinc coated) off ebay
ID:	13084   Click image for larger version
ID:	13086   Click image for larger version
Old 11-26-2012   #690
Re: Project Lex
Took the rear subframe to AA Driveshaft in Anoka, they were able to press out the old bushings. They said getting the new ones in may be tricky though. Amazing how hard it is to find a shop that can do this stuff.
Anyway, here some pics. Old bushings out, new bushings arrived and will be going in once I get the subframe cleaned up / coated
Old ones out:
Rear subframe ready for cleaning / coating:
New bushings from Curt at Elmhurst Toyota:
ID:	13108   Click image for larger version
ID:	13109   Click image for larger version
ID:	13111   Click image for larger version
ID:	13112   Click image for larger version
Old 11-27-2012   #691
Re: Project Lex
Just purchased a 2006 350Z (CD009) trans with 47k miles! Picking it up on Thursday
Old 11-29-2012   #692
Re: Project Lex
Subframe is dropped off at PowderKeg to get coated.
Picked up the trans today.
Name:	350Z CD009_1.JPG
ID:	13127   Click image for larger version
Name:	350Z CD009_2.JPG
ID:	13128   Click image for larger version
Name:	350Z CD009_3.JPG
Old 11-30-2012   #693
Re: Project Lex
New chinese special eGay rear rotors showed up today. Slotted / zinc plated. Not too bad for $79 shipped
And since I know someone is going to ask, I did not buy these because they were slotted. I bought them because they were zinc coated. If I could have found blank/solid zinc coated ones for a reasonable price I would have chosen those. I plan on getting these same ones for the front as well.
Name:	Rear Rotors 1.JPG
ID:	13140   Click image for larger version
Name:	Rear Rotors 2.JPG
Old 11-30-2012   #694
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Project Lex
New chinese special eGay rear rotors showed up today. Slotted / zinc plated. Not too bad for $79 shipped .
Nice Ive been looking at zinc plated roaters ever since you posted about them before. That day I looked at mine and the hats were totaly rusty I think if nothing else it would be worth the zinc coating to prevent that.
11.35 @ 120mph
Old 11-30-2012   #695
Re: Project Lex
Yep, that's pretty much why I wanted zinc.
Old 12-02-2012   #696
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: Project Lex
that transmission looks pretty beefy, looks very similar to a STi 6speed, minus the front diff. how much does it weigh do you think?
Originally Posted by 311evo
Old 12-02-2012   #697
Re: Project Lex
No idea on a number, but definitely more than your standard dsm awd trans. I was still able to load/unload it from the truck by myself, but it wasn't easy.
Old 12-02-2012   #698
19TsiAwd90
19TsiAwd90's Avatar
Re: Project Lex
i know the STi 6speed in around 100lbs more than a wrx 5speed, hopefully it doesnt have any issues putting down the power you want like i said it looks big and stout
Old 12-02-2012   #699
Re: Project Lex
If SP can push 1200hp through theirs with several drag passes & dyno pulls, then I think it'll handle anything my little 61mm dishes out.
Old 12-02-2012   #700
Re: Project Lex
Don't act like you aren't a beefcake!
650+whp
