Old 07-28-2014   #81
Re: 2006 Noble M400 #141
Awesome! Bean field lol, glad no damage or walls to hit. Ill leave the racing to you! haha
Old 07-28-2014   #82
Very nice! Glad to hear your temps were rock-steady!
Old 07-28-2014   #83
SlowWhite
Been there, done that.
SlowWhite's Avatar
Very nice and glad to hear wasn't a wall you hit too.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 07-28-2014   #84
polishmafia
Smells like cat poop
polishmafia's Avatar
LOL @ bean field. Glad it wasn't anything harder that you ran into.
Why do you think the spoiler being higher would help? To get more air to it? I would think if you increased the angle to get more airflow across it, it would help keep the rear end down at higher speeds.
Old 07-28-2014   #85
It's below the roof line, in this slow/turbulent air going across the flat rear deck. Raising it up 2" into clean airflow will really add some downforce. Several wind tunnel tests done to show how poor the low stock height is for functionality.
OR, I could do a fastback conversion for mega bucks though:
Forgot to mention, it ate up maybe 1/3 qt of oil in 4 sessions, so 80 minutes of racing. In my last session on the long left sweeper I noticed my oil pressure would flicker as I got into the higher rpms exiting the turn. I was told to be careful on long lefts because they can oil starve. It was at the min line on the dipstick. So next time I have to bring oil with to top off between sessions, and I decided I'm going to do the oil pan baffles mod.
Old 07-28-2014   #86
Do you have a catch can full of oil or is it burning oil?
Old 07-28-2014   #87
Speedfreak
Drives: four tires
Anyone overfill a quart when tracking those? Reasonably common to do so on other makes. Not for oil consumption, but for oil starvation due to sloshing etc (no baffles).
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 07-29-2014   #88
cmspaz
cmspaz's Avatar
I bet those bean plants were softer than tires and concrete. Going off is a learning experience for sure.
Oil pan baffles are definitely a good plan if there's a starvation risk and they are fairly available.
cmspaz is online now   Reply With Quote
Old 09-25-2014   #89
Well, it turns out I have the latest model oil pan (there were a couple revisions), and mine already has a bunch of baffles, I just need to keep it at the full line and there should be no problems.
I have figured out my winter plans. Going to convert from the standalone MBE ECU to a Ford ECU, should improve driveability, this is what the Rossions came with, I just need a couple parts and the Rossion harness for the conversion. Going to Ohio sometime next Spring to do the conversion over a weekend. Also going to upgrade the GT28R's to the newer billet GTX2860 compressor wheels, should allow for more power since the GT28's top out around 18psi/500whp.
Also converting to E85 to max out the turbos and hoping for around 22psi and 550whp. I think I'll be the first Noble on E85, most of them have an aluminum tank, but I have an E85 safe fuel cell and all SS fuel lines so it should only require larger injectors, maybe swap out to my E85 filter as well.
Old 09-25-2014   #90
Badass!!
Old 09-25-2014   #91
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
550whp?!?!? That's going to be back to the future fast. Definitely want a ride in it.
Old 09-25-2014   #92
Siiiick
Old 09-26-2014   #93
cmspaz
cmspaz's Avatar
Yeah buddy!
Old 09-26-2014   #94
Oh, new diffuser installed too. I think it looks pretty sweet. Much better than some of the lotus ones that extend way back with huge fins.
Also installed an OMP Superquadro steering wheel, but I don't think I'm going to keep it. It's a bit smaller, but the bad part is the top is much shorter and blocks the tops of the gauges. I think I will probably get a Momo Mod 80 Evo in suede, which is very similar to the stock one, but slightly better grip and suede instead of leather.
Old 09-26-2014   #95
Wow that is sweet! Aero is so hawt but so spensive.
Old 09-27-2014   #96
Agreed on aero being hawt but expensive. Fortunately the diffuser was cheap because I helped the company make the Noble prototype and organized the group buy.
Next aero mods are some vortex generators, higher wing mount, and smaller profile carbon mirrors.
Totally different subject, it's super easy to get a kit car title in Iowa. I've heard many horror stories of NY and CA where you have to wait months for all these forms to be filed to get an OBDII exemption, smog exemption, etc. Next Thursday I have an appointment with a DOT inspector, and from what I heard they mainly just check that you have lights, seat belts, mirrors, etc, and then just want to talk about cars for awhile haha. Should have my Iowa plates in a few weeks, good bye sales tax money
Old 09-27-2014   #97
Looks awesome!! Great news on the title too, hope that goes smoothly.
Old 09-27-2014   #98
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Looking good! Bummer about the wheel.
Old 11-21-2014   #99
Big plans for the winter. A guy who builds/tunes these cars in Ohio is selling his entire setup and doing an LS swap. I purchased everything but the motor/trans from him, including two BW EFR 6258 turbos (rated 44 lbs/min each), full 3" v-band exhaust, 60lb injectors, full wiring harness + ford ecu, etc. This is from his personal car, so I know everything is in great shape.
The turbos have way more power capability than the stock GT28R's, with slightly quicker spool, win-win. The standalone MBE ecu that came on the Noble doesn't have the best street manners, the Ford ecu conversion should help a lot in this regard. This is what the Rossion Q1 comes with (the now US-made equivalent of my car), so it's all plug-n-play for the ECU conversion.
He is currently packaging it all up and sending it next week, I'll take a bunch of pics when I get everything, plus the install of course. Setup should be good for around 500whp on 16psi. Easily capable of over 650 with e85 and fuel upgrades if I ever decide to get crazy.
Old 11-21-2014   #100
very nice. so the ecu is already tuned for that set up so you dont have to do it?
