Old 03-08-2005   #1
Onefast99gsx
Question Worst pain in the ass projects when working with dsm's
Last night i was replacing my master cylinder on my 99 GSX and i gotta tell you that is one pain in the ass. It got to the point where i said screw it and took the drivers seat out and still it's a pain. I said a few choice words in the process.
What projects would you consider the worst in addition to my list?
1) Changing master cylinder
2) Taking the 2g headlights out. The bolt under the light is one pain to get to.
3) Getting the tranny input shaft to slide into the clutch when bolting the tranny back up to the block. For some reason This is always as pain for me.
Old 03-08-2005   #2
ABV
ABV's Avatar
Re: Worst pain in the ass projects when working with dsm's
I helped swap out the clutch master cylinder on a fwd 2g in a couple hours. That was a while ago, but I don't remember it being too much of a pain. We had two people though.
But I do remember helping swap out a clutch on the same 2g, and everything went pretty smooth, except for one frickin bolt that goes through the rear tranny mount. I think it was cross threaded, and there's about 1.5" of room to work in to get that bolt started. I forgot what we ended up doing, but I remember it taking about as long to get the tranny back up and mounted as it did to get that one bolt in.
Other than that, I think that trying to get the timing belt tensioner set right when all you have is a set of snap ring pliers and a drill bit is a huge pain in the ass.
Old 03-08-2005   #3
Raptor
ConArtist
Raptor's Avatar
Manual conversion from auto. In the middle of one and it definately sucks.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 03-08-2005   #4
Its all seems the same for me. But the auto-manual swap sounds like a lot of fun.
Old 03-08-2005   #5
DSMPARTSGURU
Keeper of the lost toys!
Drives: 1977 pinto,1994 farm truck, 04 4-door mustang
Send a message via MSN to DSMPARTSGURU
just blame the parts... or me for that fact since i sold them to you...
cc
CHRIS
Wayzata Nissan
DSMPARTSGURU is offline   Reply With Quote
Old 03-08-2005   #6
the suspension was a bitch with no power tools and just me doing it. The front took like 8 hours and bleeding hands, the rear would have taken like 2 hours but i was missing a part, and something was messed up (dont remember what it was) so i had to get the rotozip out and cut the spring off of the strut.
I cant wait to do the manual swap sounds like fun to me.
OnefastGSX- did you put the bolts under the headlights back in? When i took mine out i just said fuck it and left the damn bolts out. what a PITA
Old 03-08-2005   #7
Onefast99gsx
I haven't put it back together but I don't think i'm gonna put them back in. I had to put tape along the bumper cover just to keep from scratching it all to hell. If you don't put the bolts back in, the headlight still has 2 other bolts. I say screw those 2 bottom ones. It's almost a scenario where you gotta take the headlight out to get the bumper cover off but you gotta take the bumper cover off to get the headlight out. What a PIA!!!
On another note: I'm glad my car is already a manual. Sounds like you're just better off getting car that's already a manual.
Old 03-08-2005   #8
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Right now Im in the middle off removeing my rear bumper. Notheing to hard so far. The pain in the ass would be the fact that Ive removed about 10 bolts so far and broke everyone. so after every bolt breaks I have to go over to the vice and get the bolt head out of the socket. I can't wait till I go to put it back on.
11.35 @ 120mph
Old 03-08-2005   #9
suspension techniques rear swaybar on a 1g w/ 4bolt rear end (actually putting the bar into position):
1 person: 1.5 hours
2 people: 5 mins
ahhh!
Old 03-08-2005   #10
Been there done that and definitely not fun. I ended up not securing the base of my bumper and only doing the sides and the top. It's a good thing I was using a cheap POS socket set because I damn near ruined a couple sockets trying to beat the heads out of the sockets.
Old 03-08-2005   #11
blageo23
blageo23's Avatar
Havent really done much to my car yet but Id say that one of the hardest was the 2G fuel filter. OOOO man! I tried it at my house and gave up (wrenches were flying) then I went to this shop that a guy I know works at and with the right tools and a little help it wasnt so bad.
Also right now im trying to get the engine out and I cant get the damn CV shafts out. Damn things are rusted. Taking the headlights off ant to to hard. just take the bumper off. 4 bolts hold it in and then its easy as hell. But the fact that you have to do that is stupid.
Old 03-08-2005   #12
LightningGSX
Hellbound
I second that, it sucks big time.
Fixing electronics stuff installed by morons tops my list of PITAs.And there's definately no shortage of idiots trying to install shit
-Nulli Secundus-
Old 03-08-2005   #13
Taking old suspension bushings out to replace with Poly suspension bushings - NOT fun and its a harsh ride but its not so mushy anymore.
Diagnosing a bad clutch but removing the tranny once to find out its the the fork or ball but the Clutch PP. Also replaced master, slave, welded pedal assembly (getting that out is a PITA). Fun stuff.
I replaced almost all bolts and nuts in front clip like you guys did with the rear... all of them broke off and I had to tap new holes. Going to be doing the rear bumper this spring... Yay. Not too bad of a deal though.
Old 03-08-2005   #14
92.5Talon
I have the same problem every time.
-Putting the bolts for the water pump pulley on when the motor is in the car sucks, can't fit my hand in there too well.
- Taking the factory fog lights out (on the a 1st gen).
92.5Talon is offline   Reply With Quote
Old 03-08-2005   #15
Tearing trannies apart and rebuilding them is probably the biggest PITA I have run into. Specifically redoing the shims on the races that are in the case. Getting out broken turbo bolts ranks up there too.
Getting a 7 bolt head on/off 6 bolt studs was fun too, that is when Nash broke out the "import monkey!".
Old 03-08-2005   #16
Onefast99gsx
I forgot about the fuel filter project. I did that about 2 years ago when i had my GS-T. I was cussing so much that my landlords kid next door said something to me something on the lines of settling down. I can't remember now which was the hardest the top or the bottom on the fuel filter. It was a bitch because you got wire, hoses, brackets, throttle body and all kinds of other shit preventing from any kind of decent 'throw' on the wrenches.
Oh yeah- the fogs on a 1g. I had an old '90 1gen that i parted out on the trader and a guy wanted the fogs. This was a few years back and i can't remember it all but bottom line was i ended up cutting the front bumper cover pretty much off with a cut off wheel to get at the fog mounts. The car was somewhat smashed but dammit when you're parting a car out, you don't make shit for your time so anything sometimes is better and faster than figuring out the right way to do it.
Old 03-08-2005   #17
JustROLLIN
SpunBearing
JustROLLIN's Avatar
I really didnt think those 1g foglights were too bad.
I do remember the fuel filter being such a PITA that I left the damn thing in the car. BTW, if anyone needs a brand new Fram fuel filter I have one laying in my tool box.
Old 03-09-2005   #18
Emcee gsxtc
Emcee gsxtc's Avatar
Talking Re: Worst pain in the ass projects when working with dsm's
I don't know about you, but my front bumper is 5 bolts and a zip tie by each fender. It takes a grand total of 3 mins to take off and put back on, which I have done easily over 100 times in the last 2 years. But still FUCK THE HEADLIGHTS, its takes a damn good reason for me to take them out.
On the other hand engine/tranny work is simple. I just take it to QPR.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 03-09-2005   #19
Nash
Nash's Avatar
I think I remember doing that, and the master cylinder wasn't all that bad. And I got pretty good at pulling the tranny out, and putting it back in before I finally sold it.
Old 03-09-2005   #20
Raptor
ConArtist
Raptor's Avatar
Stupid manual conversion is pretty much done now, overall it is a huge project, but breaking it down section by section it gets easier. Putting the pedal assembly in with the clutch master cylinder is likely the biggest hassle. Swapping rear ends is also as always a PITA, but the rest of it isn't bad at all. It is however not on my list of favorite things to do.
651-488-7774
