Old 04-20-2005   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Question Can a 2g alternator handle two amps?
I have a 97 GSX and I'm trying to add a sub to my system. I've already added an aftermarket head unit and the interior speakers are still using the factory amp. I was wondering if there is going to be power issues with the alternator and battery if I add a "1000" watt amp (It's not a true 1000 watt amp.. probably actually only 400 watts). Anyone know what the power rating is on the stock alternator for the 2g's? If you have any suggestions I'd love to hear them, thanks.
Old 04-20-2005   #2
Re: Can a 2g alternator handle two amps?
Ive been running 2 amps for ever since I bought my car. They put out about 600 watts total and the lights do not dim or anything. Im also running 90 watt headlights, those do bring down my idle a tad when they turn on
You shouldnt have a problem.
Old 04-20-2005   #3
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
I have the stock 75 amp alternator in my 1G and run a 800 watt RMS sub amp and a 200 watt RMS amp for my speakers and haven't had any problems. I also have a deep cycle battery though. But just don't pound on your system while it is idling, that is a huge draw on your alternator.
An easy way to determine if your alternator is safe is to add up your total amperage draw, if it exceeds 120% of your alternators output rating, you need a bigger alternator.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 04-20-2005   #4
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
cool, thanks guys!
Old 05-04-2005   #5
LightningGSX
Hellbound
Amp draw = watts / voltage.So, for example, 800 watt amp / 13.8 = 58 amps.And, unless you drive around at full volume with the amps' gain/sensitivity all the way up, take about 50%-75% of that, and you'll have somewhere in the ballpark of your average current draw.
-Nulli Secundus-
Old 05-04-2005   #6
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Yes, and not to argue, but the method I mentioned also covers it incase someone decides to sit in a parking lot with their car running at idle and pound the shit out of their system. But your method works well too.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 05-04-2005   #7
LightningGSX
Hellbound
I was just adding to what you said, so he would know how to calculate his average current draw.
-Nulli Secundus-
