Go Back   MitsuStyle > Tech > The Good Stuff
Old 10-27-2005   #1
Re: Rod Ratios
Crane has all kinds of crazy grinds for the 4G63, but most of them require some work to make sure the retainers don't smash into the valve seals/valve guides and the valves into the pistons.
Old 10-27-2005   #2
Re: Rod Ratios
Indeed. Your cam isn't "hardcore" until your worried about putting retainers into seals .
And valves into pistons.
Old 10-27-2005   #3
Re: Rod Ratios
When people are cracking blocks, then you know the engine is going about as far as it can in a streetable form. 4g64's seem to be worse, and it makes sense because the block is thinner because of the bigger bores.
Old 11-01-2005   #4
Re: Rod Ratios
Read the new issue of D-Sport for a nice article about long versus short rod applied to Dart block Honda engines. The results are not what you'd expect. And they got a hell of a lot more difference than Hot Rod did doing the same test on a couple of V8's. Rod ratio doesn't seem to mean dick on anything but paper.
