02-27-2006
#1
Re: A million and one DSM problems.
Originally Posted by notnormal
ya well.....bad caps can allow a lot of gheyness to occur. Lightning gsx can tell if your caps leak, and if that is the case, fix it for a VERY reasonable price.
I just went through a leaky cap incident. Caused many strange things to happen! Lightening GSX was no where to be found, so I had Steve off Tuners fix it for me. He did a great job!
02-27-2006
#2
How much did he charge you??
Ok, I went out to do a compression test, I got everything all setup. And now it doesnt even want to crank over. Fuel pump kicks in, but it wont even crank over at all.
4G63 0, Charlie 3
02-26-2006
#3
Originally Posted by TheBlizzard
Yes. Line up the mark on the crank pulley and then check the cam gears.
Okay, I lined up the mark on the crank pulley with the "T" mark, and checked the cam gears. The marks were lined up, just like in the pic above.
4G63 0, Charlie 3
02-27-2006
#4
Won't crank over as in the Battery is dead?
02-27-2006
#5
Dont think so, because everythign else works, Ill recharge another battery I have, and see what happens.
4G63 0, Charlie 3
02-28-2006
#6
Well I tapped the starter with a hammer and it kicked right in. lol.
then I hooked up a timing light, heres where the timing mark on the crank pulley was, when it was hooked up to the #1 cylinder spark plug wire.
http://img.photobucket.com/albums/v2...tiontiming.jpg
that seems way off to me, isnt it supposed to be right on the "T''?
Should I try to adjust the CAS?
Edit: I adjusted the CAS and fixed the timing.
4G63 0, Charlie 3
02-28-2006
#7
Well, I fixed the timing, and it seemed to help quite a bit. So I drove it around the block, and it actually rev'd all the way up to redline, still no boost though.
And then this hapened.
http://img.photobucket.com/albums/v2...e/P1010245.jpg
Amazingly, I was still able to drive it home.
4G63 0, Charlie 3
02-28-2006
#8
Shit! Wow man, well atleast you know what the problem was now... the engine!!
02-28-2006
#9
Yup!! It sure does make diagnosing the problem a lot easier!!
4G63 0, Charlie 3
02-28-2006
#10
That's shitty though man. You haven't had the best of luck with these cars have you? Do you have any plans? Drop in another stock engine, or a built one or anything?
02-28-2006
#11
No, I definatly havent. I dont know why I keep trying, but I do!!
I destroyed 2 6-bolts, 1 tranny, 1 turbo, and 1 clean 92 laser shell. Ive also spent quite a few thousand dollars. But I would do it all over again, if I had the choice!!!
I know of a non-running GVR4, that I might be able to get, so Im going to try to get that, and I know of someone looking for a clean black 1g shell, so Im probably going to sell my shell, and try to get a GVR4.
4G63 0, Charlie 3
02-28-2006
#12
And the curse of the black 1g from hell continues.
Sorry to read about your misfortunes.
02-28-2006
#13
Indeed it does, how many motors did you go through with this car?
I heard it was around 6.
4G63 0, Charlie 3
02-28-2006
#14
Hey when can I come check out the shell???
02-28-2006
#15
Just 2.
02-28-2006
#16
What about the car Steve's selling? Pick that thing up cheap!
Good luck with it though, hopefully things start going better!
02-28-2006
#17
yeah, I saw that one too, I want to see it, but I just dont have the cash for it yet.
4G63 0, Charlie 3
02-28-2006
#18
WTF man... All that work.
Originally Posted by Tachyon
02-28-2006
#19
Whenever your available, call me at 612-703-1186, I dont work, all week or this weekend.
Yeah, alot of work = alot of learning.
4G63 0, Charlie 3
02-28-2006
#20
Atleast you have a good additude about this. MattD, maybe you should take a page out of his book?
