Old 07-15-2008   #1
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: the evo 3 swap parts are coming
got the spacers done for you today... will drop them for you at old chicago if i make it out tonight..
Old 07-15-2008   #2
Powder ordered.
Old 07-15-2008   #3
thanks mike I can bolt them all on now
brandon just let me know what it is I will get you some cash. I will stop by to get the rail some time this week
Old 07-15-2008   #4
Sounds good man.
Old 07-16-2008   #5
thanks to mike he finnished a set of spacers for me they are also 1/2 thick. so no the brembo can be bolted on with a full bracket now
Old 07-16-2008   #6
rose0529
rose0529's Avatar
Drives: a red car
Sorry i only got you one... i forgot about a second set!!... looks good though!
Old 07-16-2008   #7
that is ok I still have to clean the fronts sand them and paint them blue
Old 07-17-2008   #8
got more done today on the car with the help of my dad Ken. We got the water bottle mounted after cutting a big hole in the sheet metal to the top of it so it can be filled easy. Got the boost pressure switch installed and set to 20psi to come on and stay on till 27psi. Had to take off the front bumper to get the 2 oem evo III water sprayers in. Als fixed the front bumper with some alum rivits to hold it were it has to be. The bumper did not have the tabs on it when I got it and has been lose sense it went on the car. last thing we did was take out the amp rack and put in the rear cusco tower bar.
water jets
hose routing w/pressure-vol nipple
were the hole was cut right by the P.S. resvore
the bottom were the evo abs was to start with that never went into my car(pic before brackets were made)
with the bumper back on
Old 07-17-2008   #9
were the bumper was reatached
cusco rear tower bar that sits behind the amp rack
Old 07-17-2008   #10
Sweet. Is the boost pressure switch independant from other systems?
Old 07-18-2008   #11
it is seprate
Old 07-18-2008   #12
polishmafia
Smells like cat poop
polishmafia's Avatar
do the water jets spray the IC to drop the temperature of it? sorry, noob question!
Old 07-18-2008   #13
Yes, water evaporating helps to dissipate the heat. The charged air can only be cooled to atmospheric temp so the water sprayers are only useful if the intercooler is unable to fully cool the charge by itself.
Old 07-18-2008   #14
polishmafia
ah ok, next noob question.
why would an IC not be able to cool the air enough (down to the temperature of the air outside)? would the IC not be big enough - not letting the air spend enough time inside it to cool down?
Old 07-18-2008   #15
High boost and multiple runs gets everything pretty hot and water would help then. A bigger intercooler would help too but I think you're pretty limited on space right Mark?
Old 07-18-2008   #16
With my big intercooler it still gets hot to the touch on the hot side and a few inches in on the core after only a few 40-70 second autocross runs. I can only imagine what it would be like if the core was smaller. I haven't yet felt the need to spray it after a run because the IC piping and intake manifold are still able to be touched.
Old 07-18-2008   #17
Shoulda done an aquamist alky injection instead More effective than this sillyness
Old 07-18-2008   #18
with out moving a ton of stuff I can put anything bigger on for a fmic.
no alky for the car. It will be on e-85 when v3 link comes out for evo 1-3.
Old 07-22-2008   #19
got the big alen head bolt today and got them in and they work alot better than the bolts that were cut.
also got one of the front brembos painted. it is a heavy metal flake blue that is close to the cusco blue. The pics dont do it any favors. it was sanded down with some 400. 1 layer of primer,3 coats of blue,hi temp brembo sticker,3 coats of clear
Old 07-22-2008   #20
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Lookin good, now put them in with the new wheels!!
-1990 Mitsubishi Cyborg 4WD-
