Old 01-26-2009   #1
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: 4b11t going into new RWD Hyundai coupe
Well 29psi would be "technically" as much as a 3 bar sensor would read so I would assume that's what they are going by. Interesting to see a higher compression ratio and a different rod. Almost looks to me like the Hyundai rod is more "beefy".
Originally Posted by shoutbox
Old 01-26-2009   #2
Yeah, I read somewhere that they're using 2.9bar map sensors.
Old 01-27-2009   #3
Speedfreak
Drives: four tires
So any solid word on when these will be at dealerships?
Old 01-27-2009   #4
I keep hearing late Feb early March, but no solid date yet. They're sitting in the ports on the west coast waiting to get shipped out though.
Old 01-27-2009   #5
I bet they are waiting for the website to be finalized with all the options and stuff.
Old 01-27-2009   #6
http://www.dpccars.com/car-videos-09...cial-shoot.htm
Video footage of the thing, and yea, I guess the commercial's gonna be in the superbowl.
Please note the camera car at 2:10, gotta have something nice and fast to stay in front of this thing
Old 01-27-2009   #7
I saw that video yesterday. I'm getting kinda pumped! One more thing, the 4cyl car is supposed to get around 30mpg stock!
Old 01-28-2009   #8
Found some pics of the car with the GT30, and PROSS tuning has already made a tubular manifold for it. The GT30 is top mounted, but it looks like there'll be plenty of room for those that want to go bigger. The PROSS manifold puts the turbo down in the stock location.
GT30
The GT30 manifold without the turbo
PROSS manifold
Old 01-28-2009   #9
man thats sexy.
Old 01-28-2009   #10
I think I'd almost want to go with a top-mount...longitudinal motors were meant to have a turbo sitting right next to the valve cover, and a big, sexy SMIM on the other side
Old 01-28-2009   #11
It may be shiny, but the design is far from optimal. It is a 4-2-1 design, they put 2 runners together before it gets to the turbo, which you may not have noticed. Also the angles where that happens are poor, as is the entry angle for the bottom pipe going in to the turbo. Packaging looks tight so I am sure they had to make some concessions, but they could have made the angles better at least. As we have seen with turbo stuff though, it will probably work nearly as good as a perfectly designed one.
Old 01-28-2009   #12
I'm thinking a top mounted GT3076 will be plenty for what I wanna do Also, my last post was edited to add one more pic I forgot to post.
Old 01-28-2009   #13
Kevin, if you talk me into buying one of these, Anna is gonna fuking kill you!
Old 01-28-2009   #14
Hahaha I'm not talking you into anything It's not my fault if you decide to get one!
Old 01-28-2009   #15
I am in the market for a new car... Hmm. Brand new around 20k, means lots of money left for mods... haha
Old 01-28-2009   #16
Any word on how good/bad the chassis and transmission are?
Old 01-28-2009   #17
They don't look as good in recent pictures I've seen on google, but probably because they have massive wheel gap. Maybe the front end reminds me of a Tiburon.
Old 01-28-2009   #18
Hmm it does look kinda bland. Dished wheels and a massive drop would help.
Old 01-28-2009   #19
Looks like a mix between a Pontiac and a Toyota.
Old 01-28-2009   #20
Not much word on the drivetrain yet. Though the flywheel/clutch on the 6 speed will definitely be a weak spot due to the 2pc. flywheel. The chassis is supposedly pretty stiff. They used a lot of high carbon steel, to make it as stiff as possible while keeping weight as low as possible. I forget exactly what the numbers are, but it's supposed to be something like, 20% stiffer than an M3
