Old 06-15-2009   #1
silow_gsx
FS 1G and 2G parts at Great Prices!
All prices are firm, it's already heavily discounted.
PTE SCM50 50 trim turbo with Mitsu cut divider housing. No internal wastegate actuator. Includes oil feed and return lines. Used for 10k miles with minimal shaft play. - $150 SOLD
http://i242.photobucket.com/albums/f...s/IMG_0861.jpg
http://i242.photobucket.com/albums/f...s/IMG_0862.jpg
http://i242.photobucket.com/albums/f...s/IMG_0863.jpg
http://i242.photobucket.com/albums/f...s/IMG_0864.jpg
1g head. Cleaned and blasted by Motors by Gosh. Stock vavles cleaned and lapped. Stock springs and retainers. Stock cams. Includes roller rockers and matching cam caps. No lifters. - $150 SOLD
http://i242.photobucket.com/albums/f...s/IMG_0834.jpg
http://i242.photobucket.com/albums/f...s/IMG_0835.jpg
http://i242.photobucket.com/albums/f...s/IMG_0836.jpg
http://i242.photobucket.com/albums/f...s/IMG_0837.jpg
1g valve cover with new gaskets. - $10 SOLD
http://i242.photobucket.com/albums/f...s/IMG_0842.jpg
http://i242.photobucket.com/albums/f...s/IMG_0843.jpg
FIC 850cc fuel injectors. Includes 2G fuel rail. Used < 5k miles. - $175 SOLD
http://i242.photobucket.com/albums/f...s/IMG_0839.jpg
http://i242.photobucket.com/albums/f...s/IMG_0840.jpg
2G Fluidyne Radiator with stock AC fan and slim fan. - $200 SOLD
http://i242.photobucket.com/albums/f...s/IMG_0845.jpg
2G 7 bolt long block from my 95 GSX with 105k miles. Pulled because it started to rod knock. [B]Comes with Comp2 cams in it. - $100 SOLD
http://i242.photobucket.com/albums/f...s/IMG_0866.jpg
2G TEIN Flex coilovers with pillowball mounts. 1 of the rear shocks is leaking and should be serviced with TEIN. I was told it would be less than $200 to repair. - $400 SOLD
http://i242.photobucket.com/albums/f...s/IMG_0865.jpg
6bolt virgin crank. Journals are still within spec and it's been micropolished. - $100
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0851.jpg
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0852.jpg
6bolt cut crank. Rod journals are in spec, mains are cut .010 as seen in the 3rd pic. - $50
http://i242.photobucket.com/albums/f...s/IMG_0847.jpg
http://i242.photobucket.com/albums/f...s/IMG_0848.jpg
http://i242.photobucket.com/albums/f...s/IMG_0850.jpg
6 bolt AWD ACT2900 with street disk and ACT lightweight flywheel. Used < 2k miles. - $250 SOLD
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0853.jpg
7 bolt AWD ACT2600 with street disk and Fidanza flywheel. Used for 20k miles but still has life left. - $50
http://i242.photobucket.com/albums/f...s/IMG_0854.jpg
7 bolt AWD stock flywheel. $10
http://i242.photobucket.com/albums/f...s/IMG_0855.jpg
2G SSAC FMIC kit (28x10x3.5). Never used. - $200 SOLD
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0833.jpg
2G Generic FMIC kit. Street Imports core (smaller one). JCWhitney mandrel bends. Dejon upper intercooler pipe. Turbo XS blowoff valve. Used for 20k miles - $100
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0825.jpg
2G AWD exhaust system. 2.5" RnR aluminized 02 eliminator to 3" Thermal R&D exhaust. Used for 20k miles. - $100 SOLD
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0829.jpg
Cast T3 manifold with external wastegate flange. New. - $125
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0831.jpg
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0832.jpg
SBR cast 2g manifold with external wastegate flange. Used for <5k miles. - $125 SOLD
http://i242.photobucket.com/albums/ff278/xai_guy/dsm_parts/cast_sbr2gmani1.jpg
http://i242.photobucket.com/albums/ff278/xai_guy/dsm_parts/cast_sbr2gmani2.jpg
2G Intake Manifold complete with Ignition Module, coils, throttle body, TPS, IAC, FIAV, etc. - $50 SOLD
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0846.jpg
2G T-Stat. $10
2G Starter. - $15 SOLD
http://i242.photobucket.com/albums/f...s/IMG_0856.jpg
2G Misc. including tensioners, driverside mount, pulleys, sprockets, gears, etc. - $5 each
http://i242.photobucket.com/albums/f...s/IMG_0857.jpg
http://i242.photobucket.com/albums/f...s/IMG_0858.jpg
2G Alternator. - $15 SOLD
6 bolt oil pickup tube - $5
http://i242.photobucket.com/albums/f...s/IMG_0859.jpg
2G NGK Blue spark plug wires. Used for 20k miles. - $10 SOLD
http://i242.photobucket.com/albums/f...s/IMG_0860.jpg
6 bolt Front Case. New. - $50
6 bolt Front Case used unknown milage. Free
http://i242.photobucket.com/albums/f...s/IMG_0841.jpg
6 bolt Water Pump. New. - $40 SOLD
7 bolt Water PUmp used < 5k miles. - $20
http://i242.photobucket.com/albums/f...s/IMG_0844.jpg
1G throttle body - $10
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0826.jpg
1G T-Stat - $10
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0828.jpg
1G Intake Manifold (bare) - $10
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0830.jpg
2G Ebay Front Camber kit - $10 SOLD
http://i242.photobucket.com/albums/ff278/xai_guy/parts/IMG_0827.jpg
silow_gsx is offline   Reply With Quote
