Old 10-01-2010   #1
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Teh Dizzevo
Awesome. We'll see you tomorrow!
Originally Posted by Trogdor
Old 12-21-2010   #2
Re: Teh Dizzevo
Matt, I found your next mod
35+ mm wide fenders for Evo 8/9
There replacement wide fenders will work with your factory bumper while giving you the possibility of putting more rubber on the road while not adding extra weight compared to stock factory fenders.
Sold in a pair
Wheel size recommended: 18 x 9 +20mm / 18 x 9.5 +25mm
$270 a pair!
http://www.lancershop.com/customer/p...&cat=49&page=1
Old 12-22-2010   #3
Re: Teh Dizzevo
Oh my... If only the rear fenders were as easily modifiable.
The car needs so much maintenance work done on it right now it won't see any fun parts for quite a while.
-Front ball joints are shot, will replace with Whiteline Roll Center Kit
-Struts are quite bouncy all around, unsure what direction to go with that
-Right rear wheel bearing needs replacing
-Need to get rotors replaced, picked up a complete set of Hawk HPS pads off EvoMN
Old 12-23-2010   #4
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: Teh Dizzevo
I know this feeling all to well. Except for me its timing belt, and clutch
341hp/344tq E-85 FTW
Shane Tune@ DB
Old 12-23-2010   #5
Re: Teh Dizzevo
Yep, will be doing my timing belt closer to summer. 114,000 on the clock right now, did the last at 66,000. FWIW if your timing belt looks good then don't be in a rush to change it, I have no doubt that mine could have gone 100,000 miles without being touched.
Old 12-23-2010   #6
Re: Teh Dizzevo
I thought your rears were sitting decently flush with the rear fenders last I saw your car?
Anyways, try to find some Bilsteins!! You rode in my car with the Swift Spec-R's (same as you have) and Bilsteins. It's a real nice combo.
And look into Rotorpros for the brake rotors, thats what I plan on using, they seem to be good quality from the reviews. Plus, I like the fact they won't rust except on the contact surface.
http://www.maperformance.com/rotorpr...o-viii-ix.html
That's what I thought with Emily's Galant, then the belt went with only 39,000 miles on it
Old 12-23-2010   #7
Re: Teh Dizzevo
Inspection goes a long way but you can't predict freak failures like that. Consumer protection laws can't require maintenance intervals, but they can be recommended, which is where the 60k comes from.
Old 12-23-2010   #8
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: Teh Dizzevo
i would rather be safe then sorry. better to spend $500 now, then $2500 for a new head. Plus its in storage right now anyways. So perfect time to do it.
Shane Tune@ DB
Old 12-22-2010   #9
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Teh Dizzevo
Sounds like a solid day in the garage. Count me in!
Old 12-23-2010   #10
Re: Teh Dizzevo
I'd recommend the Centric Premiums since they use the known good 120 core. Rotorpros vary and can be either the 120's or the lesser 121 (C-TEK). The 120 cores are what Powerslot, Cryostop, and Stoptech use for their branded rotors.
