Build the X 17 56.67%
Old 03-01-2010   #1
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Dave's Evo X Build
Tephra is working on it for the X now. His is getting close I believe.
They've been 'getting close' on stuff for the X for the six months that I've had the car. I'm sure it's tough work to reverse engineer the ECU. I'll certainly send a few bucks whenever something is delivered.
Old 03-01-2010   #2
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
NLTS is the best thing ever! I would run a second slower if I dint have it! NLTS makes it possible for anyone to drive a car fast down the 1/4 mile.
Old 03-01-2010   #3
mike55112
mike55112's Avatar
Drives: 04 evo
NLTS can be a little tricky at first if you have never used it before,Kracka and schiedes witnessed my first attempt with it. But after some practice, its a very fun mod.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 03-01-2010   #4
It drops the RPM's by a user-set amount. I personally have mine set at 1000. Clutch in at 7500, RPM's drop to 6500; clutch in at 4000, drop to 3000, etc.
Old 03-01-2010   #5
t-revzr
FLOSSEN
t-revzr's Avatar
Is that usually the standard amount 1000? Thats what mine was too.
Old 03-01-2010   #6
I believe 800 is the default, but I generally set it to 1,000 on any car I install Tephra on. It really doesn't matter much since the actual RPM drop is ~1,500 (varies depending on gear of course); you'll only notice if you're a slow shifter. The only time I actually bounce off the limiter is doing a NLTS into 5th gear; I baby 5th so I don't get the common grind so so many people have developed.
Old 03-07-2010   #7
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Well my car goes through 1-4 gears beautifully.
However, last night doing a fifth gear pull (freeway passing)the clutch basically opened up completely, meaning slipped horribly.
It slipped and bounced all the way off the rev limiter. I let it cool down and its back to normal but the new clutch will coming soon now. I was thinking about doing a few things before it because it was holding up great. However I don't want to have to think about it anymore. So new clutch will be coming.
Old 03-09-2010   #8
wut? passing on the freeway w/o downshifting? zzomg!
Old 03-09-2010   #9
Murlo26
Murlo26's Avatar
No need to now, well there wasn't. Enough power in fifth to pass. When you are going 80 already, the gearing on the X is such that you are already building boost. So fifth gets used a lot for passing, at least for me.
Old 03-08-2010   #10
Haha I knew it wouldn't last very long.
Old 03-09-2010   #11
Murlo26
Murlo26's Avatar
1 week wasn't bad
Update, clutch wouldn't even fully hold 3rd gear on the entrance ramp today
NOw it's getting not fun to drive...going to order my ACT 6 puck very soon I am thinking. Maybe today.
Old 03-09-2010   #12
mlomker
*Resting In Peace*
mlomker's Avatar
Passing? I'm always in the right lane.
I hate 5th gear...at 45ish it is at a lugging rpm range.
Old 03-09-2010   #13
Haha with my DSM I never downshifted from 5th to pass. 16g FTW!
Old 03-09-2010   #14
Constant_Project21
Constant_Project21's Avatar
Drives: E36
This. 16g FTW indeed.
Old 03-09-2010   #15
Murlo26
Murlo26's Avatar
evox gearing ftw i guess since you are always above 3krpm.
However mpg ftl
Old 03-09-2010   #16
Get the Shep final drive.
http://www.sheptrans.com/transmissio...tm#final_drive
Old 03-09-2010   #17
Murlo26
Murlo26's Avatar
tempting, but awfully expensive.
Old 03-09-2010   #18
Yeah, that would be a part I would wait for the price to drop on, I can see that thing being about $3-400 in about 2 years
Old 03-09-2010   #19
Murlo26
Murlo26's Avatar
Id rather invest more in my head or even drop ins, rods/pistons, and rev the car out to 8500-9000rpms. Then get taller tires if need be. That way I wouldn't need this.
Old 03-09-2010   #20
mlomker
*Resting In Peace*
mlomker's Avatar
I plan to Shep my drive train if/when I manage to toast the six puck.
Tags
