Build the X 17 56.67%
Old 08-28-2012   #1
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Well, so just a little update.
So the whole reason I lowered my price $1,000 after a week was I found this while logging recently...
The first run was at half a tank...I logged it then I filled up the tank, ~7.5 gallons or so and did another run, perfect. So Jon and I talked and agreed bad fuel pump pickup. I have always been skeptical of my double pumper as it hasn't started because of "low gas" at like 1/3 of a tank.
So today I went ahead and bought a used OEM fuel pump hangar as my stock one is modified for the double pumper and I am going to redo my fuel pump system soon, maybe next week (aka drop it off at MAP).
They are going to do the following which is what Chris Carey is prolly going to do to his Evo X as well.
-Remove double pumper (sell for cheap with hangar)
-Wally 400 e85 version
-MAP fuel pump install kit, includes aluminum sleeve and flex hose
-DW hardwire kit to get battery voltage to it, get rid of fuel pump relay
-6AN fuel line for my feed from rail
-Turn current hard factory feed line into return line as its bigger in an effort to reduce fuel pressure as the fuel pumps flow more at lower pressures.
-Modify return line orifice to reduce fuel pressure drop
So hopefully with all of this Chris thinks it should be good for ~600whp on E85 and I tend to agree after reading several tests online.
I want to move back to a single pump to simplify my setup as I don't like the dual pump setup unless you really need to run it. Chris said when he ran the old 400 on his car he could do pulls until the gas light so I am looking forward to that big time.
My thoughts on future fueling needs if this isn't enough or I want a bigger turbo...run a BAP for easy mode or more likely, do a surge tank with big weldon like Lomker's setup.
More to come.
I will then re-raise the price on the car to $32,000 for sale and then if someone brings me the cash I will make a call, otherwise I am going to rock the car as its working well and I am enjoying it again! Then hopefully rock the car on the mitsustyle cruise again for more pumpkin smashing fun.
Old 08-28-2012   #2
timschot
timschot's Avatar
Drives: 2008 Evo GSR
Hell yeah man. A strong running car is damn hard to part with. Keep it!!!
I am going to follow along closely on your fuel system. I was hoping to just do w400 e85 version + hardwire + drill mod but figured the return line would get owned.
timschot is offline   Reply With Quote
Old 08-28-2012   #3
Murlo26
Murlo26's Avatar
I shall test it out and report back.
I want something that works down to the gas light on my car even though I rarely run it that low Just need consistency so I can not worry. Then I can turn up the boost again!
Old 08-28-2012   #4
Do you have some kind of BlaqOps hanger in there now?
Old 08-28-2012   #5
Murlo26
Murlo26's Avatar
It's the OEM hangar, blaqops just modified it to fit both fuel pumps. So I have two bulkheads on the top of the hangar. I could maybe reuse the blaqops one and change it back to stock but I don't want to screw around with trying to plug holes.
So I found a decent priced used hangar which I should be able to sell the blaqops one for more than I paid for it to offset the cost.
Old 08-28-2012   #6
I thought you had a sale pending?
Old 08-28-2012   #7
Murlo26
Murlo26's Avatar
I kinda did lol. The guy was going to split the cost of the fuel pump fix with me as a downpayment.
then all the sudden he asked, wait this is tuned on e85, I thought this was a pump gas car? I asked if even read my post and he said you have the 2010 WW evo x right? I said no I have the 2008 RR X...
Needless to say he was a tard, and messaged the wrong guy. I wasted like half my day of vacation last friday planning all the fuel pump stuff and working with the guy to get compression/leak down tests done and everything.
So after that I figured trying to sell the car with a bad fuel pump problem isn't going to work and I should fix it first and then sell.
The car is hard enough to sell for what I want let alone having a problem where you can't go WOT at 1/2 tank of gas. So we shall see what happens.
Old 08-31-2012   #8
Murlo26
Murlo26's Avatar
Not selling car now maybe?
Because...broke? Sigh...FML
Never ever had a P030X code that wasn't p0300, this can't be good...
Sounds like this...I haven't seen an evo x have a specific cylinder misfire code ever without actually having a problem that wasn't good.
http://www.youtube.com/watch?v=drG6qIkCHrU&hd=1
Car running like poo poo...2.4L time maybe.
Last edited by scheides; 08-31-2012 at 10:21 AM.. Reason: fixed u tube lank for moar pretty imbeddad wab payge.
Old 08-31-2012   #9
simulatedwood
Drives: 08 Evolution X
Before jump off the cliff, thinking new motor bandwagon, a compression test and coil swap is in order. PM me... I can bring some tools over to diagnose.
Shawn
Last edited by scheides; 08-31-2012 at 10:21 AM.. Reason: fixed ewe tube link and ditched extra quoted crap :P
Old 08-31-2012   #10
Sounds like a tractor.
Did you check spark on cylinder #4?
Edit: Your youtube link is broken.
Old 08-31-2012   #11
Wtf man? Idle sounds gnarly and nice to me! :P
Go through the basics as shawn said, move injectors, coils, run tests etc.
Old 08-31-2012   #12
Murlo26
Murlo26's Avatar
I just found it very weird that on Monday when I drove the car it was running perfect. Then I went out of town for a few days for work, start it, and bam yucky running evo!
I am just a pessimist with the evo now, but I was planning to do all the basics or moving coils/plugs etc.
I did check my injector plugs, that was it, just to make sure none had come loose.
More to come soon. Shawn, sent a PM buddy.
Old 08-31-2012   #13
If it was running fine, then the next day started like shit, it's probably just something stupid. I've never worked on an Evo X, but apparently we live in the same hood so holla if you need an extra hand. If I'm around I can try to help.
Old 08-31-2012   #14
Check logs on your MAF sensor....mine started running like ass and the sensor was not dead but was reading inaccurately....died a week or two later. You can borrow mine if you want to test it but quickest thing is to compare voltage at idle and see where it's at.
Old 08-31-2012   #15
Murlo26
Murlo26's Avatar
Sounds good, I will put that on the "to check" list.
I'll shoot you a text if I need to borrow it. But if shawn comes over maybe he will drive his evo to swap stuff.
Old 08-31-2012   #16
Sounds like what happened to my car when a spark plug broke. Was running fine, started it back up and it was idling like shit and threw a misfire code. Yanked the plugs and found 1 of the 4 to be broken.
Old 09-01-2012   #17
Murlo26
Murlo26's Avatar
Car fixed!
Here is the plug from #4.
No idea honestly why it was causing issues, it looks fine. But we swapped the 4 spark plug before anything else and bam, problem solved. Threw in one of my older plugs and she runs great again. Also, we made sure they were all gapped at .022", so we are good there.
I came back and do have a leak somewhere in my fuel assembly, maybe part of the fuel pickup problem? Don't know. There was a small patch of gas that I think came from when I prime the lines before starting, I always turn the key with the clutch out and I am guessing one of the lines out of the tank, maybe around my check valve is leaking. We pulled the fuel pump assembly too and looked at all that, and it looks good. Made a few adjustments and tightened everything down.
Bottom line, car runs all pretty again! Yay. Now my new OEM fuel pump hanger will be here soon and then I am on to moving back to a single pump. Game on.
Thanks a ton again Shawn (simulatedwood), you da man.
Old 09-01-2012   #18
Eat poop shawn, you never visit me!
Glad you got it figured out! ON with the sale!@ :woot:
Old 09-01-2012   #19
simulatedwood
Yeah, I know Aaron! WTF.. you never need my help! TPAL!
I am just glad this was easy, last thing we need is Dave selling the Evo at a fire sale price.
Old 09-01-2012   #20
I'll always take the help of anyone, especially a car guy.
X2 on the fire sale, that would blow.
Tags
