Build the X
17 |
56.67% |
No one wants a $60k evo with high monthly payments, get out now and buy a 9.
13 |
43.33% |
04-17-2013
#1
You should get a fuel pressure gauge on there, that is the second most useful gauge for tuning besides a wideband. It's easy to cover up fuel pressure issues in a tune on purpose or accident and hard tell when it's happening. More advanced standalones and many of the Ford ECUs use a fuel pressure input also to be able to modify fuel injector pulse width to compensate for non-linear fuel pressure problems.
Are you running a single or dual pump system now? What you are describing often happens when 1 pump in dual pump setup fails.
04-17-2013
#2
I had a similar issue happen last year when my alternator started dying on the dyno. Towards the top of a pull we would get a huge voltage drop that would cause fuel pressure to drop a lot.
04-17-2013
#3
Drives: 17 Honda Accord
Not running anything for power, getting into boost at 10psi it goes crazy lean and pop pop pop and backfiring, jolting etc.
I have a fuel pressure gauge in the engine bay, but not in the cabin.
I am running a single wally 400 e85 version hardwired to battery voltage now.
Found some oil and maybe coolant mixed in on my garage floor today
UGh...I don't know what the hell to do now...cruise readiness looking not good. Its coming from the passenger side of the car. at least that is where it is located under the car, who knows where its dripping from.
That coupled with unknown fuel pressure issues (we think), and then my boss yelling at me for even taking vacation for how busy we are and wondering why I am not working 50+ hour weeks...FUCK ME! Helluva week...
Shane, don't suppose there is a chance in hell you guys have an hour or two to help me look at this stuff this week? Tonight even? lol  I have friday off for vacation and could stop by too. Just tossing it out there. I haz money to pay
04-17-2013
#4
Sorry, I don't have time. I am booked on the dyno and then leaving on Friday at 6am for a race.
Does the car have a Fuel Lab regulator on it? I have had multiple failures with their FPRs and sometimes you can take them apart, then put them back together and they start working again, but I sure wouldn't trust an FPR that fixed itself like that. Your slightly broken fuel line idea makes sense though too, I have had many many cars with a fuel line leak for one reason or anything inside the tank and ran fine until some boost level.
04-18-2013
#5
Nope, AEM regulator.
Good thing MAP has openings I guess, sucks i have to drive a bit further but hopefully Friday is productive. Thanks Shane.
Wow, rough night tonight. Got my SSP catchcan installed. Started at 730, finished at 1am. That included a trip to Orieleys and Autozone for parts to plug my manifold spot that isnt used and also helping knoxville install his strut bar. Also some drinks, so not a terrible install, but kind of a PITA, I hate removing the front bumper.
Few pics:
For whatever reason the car feels WAY smoother now, just from this. I am thinking I had some sort of an issue before, but this feels great now. Maybe I jarred something loose on install, but its feeling better now. Now if only I can figure out my fueling...
Ok, bed now, tired. Tomorrow pull fuel assembly.
edit: Oh, few issues on installing...One, there was no self tapping screw for the ground horn, I improvised. Pictures on install notes could've been more clear. Unless I missed something, I had to trim a plastic piece on the bumper (routes air to oil cooler) quite a bit aside from the necessary one attached to the bumper beam...it was hitting my catch can. Also the catch can needed to push against the AC line quite a bit to get into place. Not sure if that is from a motor install issue or what not but threw it all outta whack. Not huge issues but slowed me down for sure.
04-17-2013
#6
Kizashi!!!
#7
That or the corvette maybe...
Evo is not ruled out yet, I aint going to give up til the last second. But its not going to be easy.
04-17-2013
#8
Boost leak test?
Originally Posted by turbotalon1g
04-17-2013
#9
Originally Posted by scheides
Boost leak test?
What for? You mean to see if fuel pressure regulator is working or something?
I think my regulator is working, it changes fuel pressure when I pull the line to it.
04-17-2013
#10
Do you have a hose with NPT fittings and you can run the mechanical gauge to the cabin through the hood and window or something? That's what I did when I was having fuel pressure problems in the Cadillac, mechanical gauge through the window.
I went to fastenal and made a 10 foot section of hose with NPT fittings for like $10, it was sweet and in the spirit of DSMs.
04-17-2013
#11
Almost sounds like your fuel pressure isn't going up with boost too. AFPR is hooked up and working correctly?
04-17-2013
#12
You've bypassed the fuel pump relay, correct?
#13
Pump is hardwired to batt voltage, so yes.
04-17-2013
#14
Drives: 2008 Evo GSR
It's not a big deal to pull the pump assembly out with the tank near full. You just spill a little gas on the ground. If you're careful and put a towel or something around it, you won't even do that.
That said, when I ruptured my in-tank line, it wouldn't even start. Mine was completely split in two though, perhaps yours just has a small hole.
2008 GSR SSS WW
RS motors built
454/388 mustang dyno on winter E70
ERL sleeved block, MAP rods, Wiseco pistons, MAP EF3, Exedy Twin HD
04-17-2013
#15
So I did install the new fuel rail and FIC2150's a bit ago too.
So it could be something with that install, the in tank stuff or something clogged.
Yea, it sounds like fuel pressure isn't rising with boost. This thing feels like it wants to hit hard though lol  Can't wait to get it working.
Good news...I scheduled time with MAP on Friday at 9AM to get leaks looked at and fixed then I am going to hit the dyno there I think for some troubleshooting. I was going to try DB since they are closer and try and do it before friday as I was hoping Friday could be a tuning day but I will try and get Jon working on it Friday while I am at MAP. I guess the good news is MAP should have a bunch of parts there if I need to replace or add anything.
Tonight I am going to install my SSP catch can instead of messing with anything else.
04-17-2013
#16
I am not convinced its the in tank line, just something i have to check.
But my car starts HARD for sure. Like it struggles and needs gas pedal action every time.
But that could be tuning still, not sure.
I will get what I can done at MAP Friday. Anyone who wants to join me there let me know, could prolly use some help
04-18-2013
#17
Looks good! Any chance you had some loose injector clips or something? Do the 2150s fit the stock plugs or do they have adapters? I had a bunch of issues when I got my 1680s but I had gotten them used and didn't have the latest adapters...FIC sent me new ones and no issues since.
04-18-2013
#18
Drives: 09 G8 GT
Keep on wrenchin'!
2009 G8 GT
04-18-2013
#19
So what about the coolant/oil mix you reported?
04-18-2013
#20
2150's are plug and play, no adapters. I am wondering if its something with the line from my fuel rail to my AFPR. It's a little bent/kinked now as it was too long since I switched fuel rails. It was setup for stock rail.
Originally Posted by Knoxville
Keep on wrenchin'!
Indeed, long ass night last night. I am burnt out right now...way too late of a night. I did get Taco Bell on the way home that made me feel good
It is just oil I think. I put a cardboard box under the car while at Knoxvilles (you can kinda see above) and it had maybe 10 drips on it after 6 hours. Oil level is still fine right now so its not significant.
I am heading to MAP friday morning to get it looked at and fixed.
