Old 09-16-2011   #1
Re: Lucky #13...Back in the saddle....92 rt/tt
Looks like a fun project! Are you going to drive this all winter or do you use the truck for DD?
Old 09-16-2011   #2
Looks better already!
Good luck on the project dude and hope you hit your goals
Old 09-16-2011   #3
Cool. I'm not a 3si guy, so just curious, are there no other cost effective tuning options for that car which is why you're limiting yourself to an SAFC?
Old 09-16-2011   #4
After you buy a 3S, how much do you have to invest in total to get it to the power level ryans car was at?
Old 09-16-2011   #5
Hell no. Car doesn't even know what snow looks like as far as I know. It was delivered in CA, lived there for 5+ years, then moved to AZ, lived there for a few years. It has been in MN for about 10 months, mostly as a garage queen due to a few simple, but broken, parts.
Giant truck =daily driver in crappy weather, winter, when stealth is down.
Stealth = preferred daily driver when not being worked on and weather = good.
Essentially everything that works for a DSM (piggyback wise, no dsmlink) works for the 3/s, some better than others. The goal is to size the injectors larger than factory to compensate for the fuel difference, account for some headroom for the raised boost pressure, and pull signal to lean it out and bump up timing. Should prove to be entertaining and a challenge. Worst case scenerio is it doens't work, I sell the S-AFC and throw in an AEM.
The goal is as cheap as possible. Ryan's car was very simple from a modification perspective, except for the custom transmission work. Bolt on turbo's, bolt-on manifold, AEM EMS, fuel, clutch, exhaust, removed crap, FMIC, and pump gas.
My approach will be similar but trying to do it without the expense of the AEM for now. Eventually I'll go standalone, but I want to see what I can accomplish with minimal $$ invested.
Old 09-16-2011   #6
There are other cheaper standalone options other than AEM if you're ballin on a budget...
Old 09-16-2011   #7
Yea. Such as this?
http://www.stealth316.com/2-arc2tuning.htm
edit - nevermind! that thing is AEM priced.
Old 09-16-2011   #8
I know megasquirt is a possibility.
Old 09-16-2011   #9
The ARC is like a MAFT, it's going to have the same ignition timing problems as an SAFC. An AEM FIC 8 might work.
Old 10-03-2011   #10
Had my first loss in the car.
Ryan's Z06 > Swanny's Stealth RT/TT by a significant amount, LOL.
Maybe I'll add some goodies and try again spring 2012.
Decided to ditch the piggyback idea, rather have complete control with the AEM, it's a long term project and I can take my time buying the parts I want
Old 01-11-2012   #11
Starting to formulate the mods list for this project.
I scored a great deal on a rear 02 housing/ pre-cat eliminator. Anyone know where to sell my pre-cats (catalytic converters) for top dollar? Both are intact still.
Old 01-11-2012   #12
Adolphs is usually where I go, but i'm a couple of mins from there.
Old 01-11-2012   #13
Sweet. Any idea how much these bad boys are worth?
Old 01-11-2012   #14
93gtpeater
Drives: cbr 1000rr repsol
Proably 60 bucks mabe more. Back in the day I was getting 90 bucks per pre cat. Adolphs is the best place to go to get top dollar.
Old 01-11-2012   #15
Thanks!
Old 01-11-2012   #16
Speedfreak
Drives: four tires
I think Adolphs is down to $45 for that size?
Old 01-11-2012   #17
Still $90
Old 01-11-2012   #18
Nice, so you gonna compete in stock appearing class this year?
Old 01-11-2012   #19
Depends upon how much side revenue I can acquire.
My "next round" mods list should put the car around 450-500awhp on E-85 easily, which would be fun as it is using TD04 based turbochargers. However that list is expensive and only time will tell. Going to use E-85 and stock sidemounts (unless I can find a cheap FMIC setup) to keep it "stealth"
I am in no rush to complete the project, but some snow would be great for my plowing side job! Otherwise, hopefully there will be some additional tuning/building opportunities this spring as well to supplement this vehicle.
Otherwise, I will be at the proving grounds pit crewing for John's Galant VR4, either way I plan on going.
Old 01-11-2012   #20
Nice. The bar set from previous years says stock appearing will be 12.0 and quicker.
what you think you could run with that much power?
