Old 03-29-2014   #1
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
Re: Project Black ValentNine
What 4-points do you have? Unless they have some way to prevent submarining under the lap belts it's not the best way to go.
Old 03-29-2014   #2
cmspaz
Walls need hugs too
cmspaz's Avatar
Schroth. ASM strap FTW.
Originally Posted by Trogdor
Old 03-29-2014   #3
Like spazzy said, I got a scroth rallye4 harness. It's got ASM tech on it, I did a bit of research and got Brandon/toothy's approval before pulling the trigger.
Old 03-29-2014   #4
bramagedained
Drives: EVO IX SSL
I kinda figured you would have researched it first. Just thought I'd ask.
Old 03-29-2014   #5
2.0? Boo. /thread
Old 03-29-2014   #6
I have a pair of Schroth ASM 4-points for sale that I had in the Evo, if anyone needs some.
Old 03-29-2014   #7
What color? Maybe I should do a second set in this car.
By pair you mean one set of harnesses or two full harnesses (enough for one seat or two?)
Old 03-29-2014   #8
Black. Enough for 2 seats.
Old 04-05-2014   #9
So, engine is all assembled, clutch and trans are all sauced up, and while cleaning out the stock IX turbo Ron discovered some excessive shaft play...bearings must have gotten killed with the motor which suuuux...I was really hoping to do STS on this car but oh well. Everything is ready to go back in but now this road block, ugh. I want this thing done really bad now!
I looked around at options...rebuilding this turbo into an ef3 was my first choice but MAP is a few weeks out (it is spring after all). I found a few stock turbos nationally but nothing I could pull the trigger on quickly. So I decided to scoop up a local FP white...it's local, mint (3k miles), comes with a few extras I may need and the price was right.
So close....
Old 04-05-2014   #10
Getting there
Old 04-05-2014   #11
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Excited for you Scheides
2006 WW IX RS 396/404 - SOLD
Old 04-05-2014   #12
Pics pics pics!
The FP White is a stock Evo9 turbo with an upgraded compressor wheel only, stock TD05H turbine wheel. Compressor is a HTA68 which is a 7-blade wheel the exact same size as a stock compressor wheel but lighter and more efficient. If it performs exactly like a stock turbo, I'll be happy. If it increases spool by 10rpm and/or produces an extra 1whp then...gravy baby All will be perfect for what I intend to do with this car.
Old 04-07-2014   #13
Mark Leasure
Mark Leasure's Avatar
Pics pics pics!
Love the turbo in a bag, ghetto as hell.
www.maperformance.com
Old 04-05-2014   #14
Woo
Old 04-06-2014   #15
Mark Leasure
You're going to love this setup. You cannot go wrong with the hd's, turbo tuff's, and the exedy twin. Spring is the perfect time to finish a project. Hey I might be tempted to join you in the turn style racing, give me a heads up when you plan on starting.
Old 04-06-2014   #16
Thanks, I'm pumped to get this thing fired up and boosting!
May 2nd is the first event I'll attend.
http://www.evomn.net/forums/showthre...vent-at-DCTC-1
Old 04-07-2014   #17
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Looking good. that block looks soo minty fresh.
Old 04-07-2014   #18
So fresh!
Old 04-07-2014   #19
Mark Leasure
How much was it again, do you owe any favors?
Old 04-07-2014   #20
MorningWood
Drives: Evo 8, 2014 Silverado
Wednesday night Drags may 7th?
MorningWood is offline   Reply With Quote
