Old 06-03-2015   #1
Re: issues - stumped and need options
Check grounds for engine, sporadic tps signal and idle control motor tells me there could be a bad ground. Maybe just unbolt, scrub clean, and re-bolt to start?
Old 06-04-2015   #2
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Also jump on ecm forums and load up a log some time if you can or email one over.
Old 06-05-2015   #3
SlowWhite
Been there, done that.
SlowWhite's Avatar
http://www.ecmtuning.com/forums/showthread.php?t=84710
Thats my thread on ecmlink. I posted logs of car running rough.
I havent posted logs of the car not starting though.
Im going to work on the car some more tomorrow. Hopefully ill able to at least say one way or the other on the pump tomorrow when im done.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 06-06-2015   #4
SlowWhite
SlowWhite's Avatar
Went out and tried to start the car - car started up and as soon as i tapped the gas it shut off. (did that three times) and now its back to not starting.
I pulled the fuel line off the fuel rail and then turned on the pump via link and gas comes out the line (turned pump on and off 10 times) each time fuel came out and stopped accordingly.
So im guessing its safe to say its not the fuel pump. So now what? FPR?
Edit: after posting i went back out and put the line back on and then turned the pump back on and FPR pressure was back to normal. Car then started right up with out issue.
Let it warm up and then took it around the neighborhood and block for about 10min and no issues....with fuel...still have other stuff needs work.
Im going to let it sit for 30min and then try to start it again and see what happens.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 06-06-2015   #5
SlowWhite
SlowWhite's Avatar
k just tried to start the car again.
Car started roughly FPR gauge showed 30psi and then slowly lowered till it hit 15psi and car died. And wont start again.
Gauge is showing 15psi with key "on" but wont start. I posted a log on Link of car running then slowly dieing
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
