Old 05-07-2013   #181
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 2G auto S/A daily
Also picked up a new car. Not sure the plans yet but either a for sale thread or project thread may pop up.
1996 5pd awd with 97 conversion. Thing is clean!!!
Already have a running 6 bolt for it and put on some rims.
Old 05-07-2013   #182
4seasons69
4seasons69's Avatar
I got my catch can and my new comp cover is also sitting at Joel's.
Gotta pick up my gsc cams tomorrow and order up some injectors. Hopefully next week ill be breaking this bitch in.
Looking good! Can't wait to see this thing done!
Old 05-07-2013   #183
93gtpeater
Drives: cbr 1000rr repsol
Quit buying cars. You need to finish one now...
Old 05-07-2013   #184
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
::If you only knew. Bought the car cause it had things I needed like link v3 ,full exhaust, FP mani.
I here what your saying though. But why not have two that run?
Old 05-07-2013   #185
93gtpeater
Nothing wrong with having 2 that run. How many dsms you have now?
Old 05-07-2013   #186
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
2 two many. Lol
Old 05-07-2013   #187
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Nice!!! I have an issue with cars too
2006 WW IX RS 396/404 - SOLD
Old 05-08-2013   #188
You have an extra motor? I may need one....
Old 05-09-2013   #189
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Got the gsc s2 installed and the timing set! Coming along now.
Also got my an fittings welded on my valve cover today.
Also got some injectors off tuners today so I know have everything I should need to get running.
Old 05-09-2013   #190
Definitely want to see this car at proving grounds! It will probably be one of the fastest stock appearing DSM's I've seen. Good work.
BTW, what dyno number are you hoping for, both hp and tq, and at what rpm for each? I know it's not about peak, just curious.
Old 05-09-2013   #191
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Thanks
I'm not sure on #s. since its through an auto and on Shane's dyno.
Biggest concern is that it's actually all works nicely together.
Old 05-09-2013   #192
Big baller! Looking good!
When you think you'll get it on the dyno?
Old 05-09-2013   #193
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Date is set for may 28th at noon
Old 05-09-2013   #194
Tachyon
Tachyon's Avatar
Drives: Icarus
Where did you get your A/N fittings attached at? I need to also do this before the PG.
-Sebastian Vettel
Old 05-09-2013   #195
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I dropped off a bumper for twisted964 (Nate) at map. They welded the fittings on the VC, catch can, and they also welded up the tial bov flange to my upper ic piping.
Old 05-09-2013   #196
Tachyon
Tachyon's Avatar
Drives: Icarus
Oh Sure... I always forget Map does work like that. Thanks!
-Sebastian Vettel
Old 05-09-2013   #197
S2's! This thing is officially legit now!
Old 05-09-2013   #198
4seasons69
4seasons69's Avatar
Or talk to John (pushit2.0) he might be able to.
Looking good nick!
Old 05-09-2013   #199
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Also got my 18G comp cover machined to fit my wheel. Not sure what this does for classing. I just didn't want to shell out 2k plus on a t3 setup right now so this thing should cure all the flow issues that may come up with the 16G comp cover.
Thanks goodhart for sending me the groupbuy link on the carbon fiber sunroof.
http://www.dsmtuners.com/forums/vend...group-buy.html
Old 05-09-2013   #200
Sweet! How much weight you think it will shed?
According to last years rules, that comp cover would put you from SA to SA/U I'm pretty sure.
