Build the X 17 56.67%
Old 05-10-2012   #2081
Ya, just don't let your car sit and idle for 40 minutes at a time :P
Old 05-10-2012   #2082
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I would never idle the car longer than 20 mins for any reason honestly. I can't think of one at least.
Old 05-10-2012   #2083
Christening the car with a lady?
Old 05-10-2012   #2084
Murlo26
Murlo26's Avatar
Car can be off for that, duh.
Unless we want the rumble there for vibrating murlo
Old 05-10-2012   #2085
A/C to unsteam the windows son!!! Or heater if it's too cold for little Murlo
I do like the vibrations idea though, poly mounts FTW in this case.
Old 05-10-2012   #2086
Murlo26
Murlo26's Avatar
Steam = privacy that with my tint and its a no peep show venue. LOL @ heater.
Indeed, poly mounts!
Old 05-10-2012   #2087
Well I was busy last night doing logging and forgot the gopro needed to be charged, I will try and test it out tonight for fun.
I came to a realization though, I know why tuners hate DW injectors!!!! Because they suck to tune lol.
I am on revision 8 now for scaling/latencies and have done ~45 minutes of logging for each, that is over 5 hours of scaling lol. Still not dialed in yet. Ugh. I remember why I pay people for this shit, but I am learning a lot. I will get my trims under +/- 5% yet! The best I have seen so far on these is +/- 8%.
I have 0 problems with my DW 1000's in my AEM car
Old 05-10-2012   #2088
Turn off the o2 sensor and run it open loop. No fuel trims anymore... Your big MAF is going to make the car more inconsistant and have bigger swings than a stock sized MAF car with stock injectors.
Old 05-10-2012   #2089
Murlo26
Murlo26's Avatar
I am on the stock intake/MAF though right now. So in theory it should run fine correct? Assuming injectors are decent and not piles of crap?
Maybe I could just run open loop instead...hmmm, who knows. I am about 2 steps from ordering the 2150's and being done with it and just running open loop. I have talked with several people and on E85 people seem to get the 2150's to work perfectly fine.
Old 05-10-2012   #2090
Do you feel the car bucking or something?
Old 05-10-2012   #2091
Murlo26
Murlo26's Avatar
Not really, once I put my stock MAF back on to try and tune the DW injectors, regardless of the scaling/latency the car has felt super smooth.
I am just trying to get my trims to stay somewhere normal.
Old 05-10-2012   #2092
Get the 2150s and be done with it, plus we know you are going to go bigger.
Old 05-10-2012   #2093
I love my High-Z FIC's (similar to ID1000's). Pretty much a High-Z fanboi now. 1000's or 2150's is probably all I will ever run.
Old 05-11-2012   #2094
Murlo26
Murlo26's Avatar
Yea I have heard very good things about the FIC 2150's. All the guys I talked to said no surprises tuning them and on E85 they drive pretty damn good.
So I might order these today, we will see if the mood strikes me right.
Old 05-11-2012   #2095
Murlo26
Murlo26's Avatar
So it looks like a few people have suggested I may have a leak pre O2 sensor causing my issues.
Does anyone have stock X injectors I can borrow for a few days?
Old 05-11-2012   #2096
Is anyone running 2150's on the stock X ecu successfully yet? I thought about putting them in my car but didn't wanna mess with them at the time...I'm sure someone has done it by now (and hopefully shared their results).
Old 05-11-2012   #2097
Murlo26
Murlo26's Avatar
Yea, plenty of people. On pump gas they aren't really recommended. But I just spoke with Golden and he has tuned two on E85 on the 2150's and he said they idle fine at like 800rpms and drive perfect.
You don't have your stock injectors do you by chance?
Old 05-11-2012   #2098
I usually run the 2150s in open loop, because the "small" swings that factory ECUs do around stoich during closed loop are huge swings with the 2150s. They tune amazing with standalones, you have to put up with some quirks on stock ECUs, since stock ECUs often don't work the best at very low pulse widths.
Old 05-11-2012   #2099
Nope I do not. Would love to see what all he did to get them to run nicely, as I'm sure there's some tweaks that are needed (esp per shane below)
I wonder if there's a way to narrow that 'sweep' that's made during closed loop....I'll talk to tephra & mrfred.
Old 05-11-2012   #2100
Murlo26
Murlo26's Avatar
If you want, PM me and I can give you his email if you want to ask him a few things. I am not sure of all the details, but he didn't seem to have a problem dialing them in. I assume open loop for sure.
Or you can try a PM on EvoM or Evoxforums, name is Golden.
Tags
