View Poll Results: Block color?!
Semi-gloss black 5 100.00%
Green "Metallics" *pics of can posted* 0 0%
Cummins beige 0 0%
Purple 0 0%
Cast Iron 0 0%
Metallic Gold 0 0%
Paint By Numbers 0 0%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Old 11-30-2014   #1
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: 95 Talon TSi AWD
I'm bored so why not let the cat outta' the bag.
2.3L, Big-Borg., 2150s...the things.
$40 head that has yet to be touched.
This'll be fun.
Old 11-30-2014   #2
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Forgot my newest "toy".
Old 12-05-2014   #3
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Oliver Billet Extremes and Wiseco HDs ordered. They should be there by the time I get back from PRI. So much goodness coming out of this December. I don't know what I'm going to do with myself.
Old 12-09-2014   #4
Damn. Gonna be a hell of a build.
Old 12-09-2014   #5
DSMINMN
Mitsus for days!
DSMINMN's Avatar
I got teased today while at the AETC conference here in Indy. Can't wait to get back and make shit happen.
Old 01-08-2015   #6
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Pictures are kinda' isht. Didn't realize my phone was focusing on the background so I tried fixing it. Anyway..parts are here. I'm just waiting to get back to school next week and start doing some work! Gotta' order the rest of the junk too. Yikes..
I've also been trying my hand at this wire tucking business. I think I've kind of tackled this backwards though. Oh well.. Now if I could just find my damn soldering iron!
That's all the updating I have for now. Thanks for looking!
Old 02-03-2015   #7
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Old 02-04-2015   #8
DSMINMN
Mitsus for days!
DSMINMN's Avatar
I decided to bring everything into school today so the ball will be rolling, finally!
Old 02-19-2015   #9
DSMINMN
Mitsus for days!
DSMINMN's Avatar
The crank I had was showing some signs of oxidation and had a gouge on the front main seal journal. Rather than waste more money, play the guessing game and whatever else, I just did what had to be done.
Rough stroker clearance.
Still have to get the oil passages done up like my GS-Ts block.
Old 03-08-2015   #10
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Ran into a little issue with the Evo.III block. This pretty much explains it all.
It's my fault for not spinning the block around on the align hone. Here's a question to machining minded people: what is the best way you've found to take down all the caps on the girdle? How about the block? I've been using a 12" file for the block and our flat sanding block for the girdle. The flat sanding block is so damn short though that it gives me about an inch to move it back and forth. Not to mention I don't have a long enough piece of sand paper to fit under all of the caps.
I'm very close to grabbing a spare block of mine and starting over. Just seems unfortunate to jump ship with the E.3 block being its such a better casting and has oil squirters.
Thanks for any advice in advance!
Old 03-19-2015   #11
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Since time is of the essence and I was given no other choice than to sand the girdle and start over I decided to just that; with a different block. I just so happen to have what looks like another Evo.III block. Maybe I'm wrong but none-the-less it had spun the bearings in one of the rods and the crank walked so I made some art.
The block went into the oven today. Tomorrow will be a go in the wash, then a quick trip in the oven to dry, steel shot then a good tumble. After that tap, tap, tap some holes and onto a align hone. Let's see what I can get done in 9 hours.
Old 04-02-2015   #12
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Well as usual something happened. lol The crankwalked block gave me a huge runaround. First we had issues getting a straight bore out of our Rottler.
I measured the centering fingers and came up with a .022" difference. This was our issues; or so we thought. After ordering two new sets from Rottler but before closing the shop we found a new set of fingers.
I tested them in/on a virgin cylinder and had the exact same results. I also misread the boring fixture's mic/incorrectly set the bit. So I cut the top of the cylinder .030" down at about 3.453"" instead of 3.353". Not a huge deal but not exactly something I will allow to happen again!
My instructor and I moved the block to the Kwik-way. I had the same results there. I had my instructor come over and he tried centering the boring bar. It bored alright but something was still off. What we found had me more than upset. Looking back at it I was more happy; I took it as a sign this block wasn't meant to be used. Take a look at the odd cutting characteristics at the top and bottom of the cylinder.
So I jumped on the "line" hone with the Evo.III block. After a flat file, precision block and some sand paper I brought down the girdle. I bolted it up and seen where I needed to take more. I spent the rest of the day as well as the next honing and spinning the block. I moved all of the "caps" to within...I'd say .0003"-.0004" of each other. This is at the most as far as variation goes.
I had the mic set to the middle of the spec so 2.402". This left me with .0004" on each side to vary. None of the caps were over .0002"..if any were even at .0002". lol
Anyway, thanks for reading!
Old 04-03-2015   #13
What's the spot in the cylinder wall in that last pic ?
Old 04-03-2015   #14
DSMINMN
Mitsus for days!
DSMINMN's Avatar
That would be the hole that showed up on a .015" cut. Something was definitely off in this block. Very odd. Whoever C&S Engines was..idk man. Crankwalked, spun rod bearing, screwy cylinders & uneven deck surface. Messy stuff.
Old 04-07-2015   #15
DSMINMN
Mitsus for days!
DSMINMN's Avatar
As I'm waiting for our Sunnen hone to free up and my head bolt bottoming tap to arrive I decided to start work on the head. I then somehow ended up working on something I have been meaning to do for awhile. Haha Here it is.
I do not have quite the right angle yet and I believe I tapped a little too far. This is nothing a little more tapping and a grinder won't fix.
So there's my sad excuse for an update! lol
Old 04-07-2015   #16
^I'm interested to see how that mod works, seems no-one had any real feedback.
Old 04-07-2015   #17
1990GSX
Drives: 1975 corvette stingray, 2008 evo x gsr
I admire your dedication, under continued misfortune, to do things as right as possible. This thing should scream when you finish. The pics and progress are greatly appreciated.
1990GSX is offline   Reply With Quote
Old 04-07-2015   #18
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Thank you for the responses. I appreciate the...appreciation! lol Thanks for reading guys.
Old 04-08-2015   #19
blesi660r
blesi660r's Avatar
Any plans on a guard to keep oil out? Seen a few setups like this on tuners with a splash type guard in place.
Just couldn't stay away.
Old 04-08-2015   #20
DSMINMN
Mitsus for days!
DSMINMN's Avatar
I guess I haven't considered it. I haven't seen any examples yet to replicate so I guess I could do some looking.
