Old 02-21-2011   #1
Rmondoh
Minority of MitsuStyle
Rmondoh's Avatar
Drives: '08 OBP Evo X GSR SSS (Deadmau5X)
Send a message via AIM to Rmondoh Send a message via MSN to Rmondoh Send a message via Yahoo to Rmondoh
Re: Deadmau5X: MOAR Mods 'N Stuff
Pics look great of the porting; when you isntall, snap a pic of the gasket up to the head to get an idea of what the sections that don't quite line up (gasket matched) really mean. I'm trying to remember if my head was fully gasket matched or how this port job would line up on my car.
Can you bolt/zip tie the TB up to the manifold and then flip the butterfly open (and get a pic)? This porting is awesome, I'm jonesin to get it done on my car
Kracka and I will definitely take pictures during the installs. As for your request on the IM/TB, I'll see what I can do.
08 Evo X GSR - Octane Blue Pearl
Cobb Stg1 AMS 93 OTS: 305hp 291tq 20.6psi
Cobb Stg1 93 Pro: 317hp 322tq 24.5psi
Cobb Stg2 AMS 93 OTS: 315hp 323tq 23psi (LWG map)
Cobb Stg2 93 Pro: 343hp 358tq 26psi
Cobb Stg2 93 Pro: 355hp 361tq 26.4psi (ported stuff)
Rmondoh is offline   Reply With Quote
Old 02-21-2011   #2
Rmondoh
Rmondoh's Avatar
Ok Scheides...I did the best I could with this. It's not perfect. It's not too great a picture, but it's what you wanted. Hopefully it's good enough!
Old 02-20-2011   #3
DSM_421
It went from a soccer mom's lancer with no tints, stock rims, and stock ride height to an aggressive evo with the tints, rims, and drop.
Edit --
It looks good, even the rain guards aren't an eye sore.
On your front fender behind your wheel... there is what appears to be a vent but is probably just aesthetics. Is that after market? Looks less like a plastic piece as your first picture illustrates and more like a paint job with a clear coat on the second picture..., looks good non the less.
Old 02-21-2011   #4
Rmondoh
Rmondoh's Avatar
Thanks for the comments.
That fender vent actually has some purpose although I'm not sure what it is exactly. The fender has 2 holes in it which the vent sits on. In the first picture, this is what the vent looks like except black in the GSR's cases (it's color matched on the MRs).
The fender vents I have on the car are carbon fiber from Rexpeed and look like this:
Old 02-21-2011   #5
Mondo's new coated parts from SPC in Arlington, TX are done!
PPI Extreme ported exhaust manifold
Cobb 3" downpipe
Old 02-21-2011   #6
DSM_421
Sexy downpipe!
rexspeed CF fender vent is better than the stock non painted piece for sure too.
Old 02-21-2011   #7
they coated the inside too?
Old 02-21-2011   #8
DSM_421
I don't think that is too uncommon, especially on a piece AFTER the turbo.
Some people have had problems on their manifolds where the coating has flaked off from the inside due to a sub-par coat job and caused problems on the turbo.
Old 02-21-2011   #9
Thanks I had no clue.
Old 02-21-2011   #10
Rmondoh
Rmondoh's Avatar
It looks like they are even though we said not to. Kracka will have to reply since he has the parts.
Old 02-21-2011   #11
Lookin good. I prefer all my parts coated in and out
Old 02-21-2011   #12
mlomker
*Resting In Peace*
mlomker's Avatar
I have a set of the fender vents for this Spring as well. The GSR ones aren't much to look at.
Old 02-21-2011   #13
Owned
Drives: 2g
The vent install needs some more attention imo. Good look on parts and drop btw.
Owned is offline   Reply With Quote
Old 02-21-2011   #14
Do I need to ask about the *pink* pencils? facepalm....
On the flip side, looks hawt! Nice smooth opening and transition ...hrm, stock is 59mm? area=2732 sq mm....this is 64mm, area=3215 sq mm which is a 17% increase in area...nice
Old 02-21-2011   #15
Rmondoh
Rmondoh's Avatar
*Sigh* If you must...
All those pencils must be like 10 years old. Mom keeps pens, pencils, etc in a cup on the microwave. They are my sister's. I always used mechanical pencils.
Your math looks about right to me!
Old 02-21-2011   #16
Pink pencils and you just admitted to still living with your mom? Man points dude, man points...
Seriously though, when is this stuff going on?
Old 02-21-2011   #17
Rmondoh
Rmondoh's Avatar
Doesn't bother me!
We start on Kracka's car. Exhaust manifold goes on Saturday followed by a trip to Cobb for a dyno run.
Intake manifold and throttle body should go on next week followed by another trip to Cobb for a spin on the dyno and to get properly tuned (Kracka's car as well).
We'll probably start work on mine the week after that.
Old 02-22-2011   #18
For comparison: stock VIII = 59mm, IX TB = 61mm, X = 58mm
Coating inside and out is common practice; inside to prevent the metal from absorbing the heat and outside to prevent the metal from dissipating what heat it has absorbed.
Old 02-22-2011   #19
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Did thread clean up just happen or something?
Old 02-22-2011   #20
Moved some of the more general discussion here:
http://mitsustyle.com/forums/showthr...ewpost&t=29057
