Old 08-11-2012   #1
Mark Leasure
Mark Leasure's Avatar
Re: Mark's 1G Winter Projects
40lbs sounds like the diet is off to a good start.
The diet is in full progress!
- 40 for the fuel tank
- 30 for the front STM brakes alone
- I have the molded flex-a-lite rear windows. We will see how much they shave off, they are super light.
- Being conservative with 15 on the battery move
www.maperformance.com
Old 08-11-2012   #2
Mark Leasure
My father in-law cut up my rear rotors, he has a cnc in his garage. I need to weigh them to see how much came off.
Old 08-08-2012   #3
Very nice, also looking at the in car video again, I think you let off at the first cone for the final trap and ET, make sure you drive threw the markers to get a great pass.
Old 08-08-2012   #4
Hmm 40 lbs weight loss.
I wish i was fast enough to have people give me go-pros.
Old 08-08-2012   #5
Going to the track might be a better start.
Old 08-08-2012   #6
ouch, soon old timer. and I won't be stuck in the 12s, probably just damn low 11s.
Old 08-11-2012   #7
Mark Leasure
Made a new battery mount today, I’m going move the battery back to the front of the car. Currently I have a rear mounted PC680. The battery is on its way out so I picked up a PC545, It’s 4 pounds lighter. I will be removing a lot of 2AWG going to the back of the car, the sealed box and some other stuff. It should shave off 15 pounds, at a minimum. I’m also integrating a solid state relay up front for the shut down switch.
Old 08-11-2012   #8
Very nice.
Old 08-11-2012   #9
fuck that is awesome. I wish I could drop 300 lbs off my car total. Get it down to 2950 or less without me in it.
How much did your car weigh the last time you checked it?
Old 08-11-2012   #10
Mark Leasure
2870 with me in it. I weigh 195.
Old 08-12-2012   #11
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
So that was the weight before these last few weight reductions? Or is that as of today?
Rotors looks awesome. Cool that you made your own!
So 8's next yr? It's gonna be a long winter I hope you have no plans to change to an auto.
Old 08-12-2012   #12
Mark Leasure
That was the old weight before any weight reduction. Goal is to get it under 2500. It will remain a shifted car.
Old 08-12-2012   #13
That is light!
Badass, that thing will be crazy at 2500lbs.
Old 08-12-2012   #14
Those rear rotors look sweet! So those are just scalloped stockers?
Old 08-12-2012   #15
Mark Leasure
yep just scalloped stockers.
Old 08-15-2012   #16
Speedfreak
Drives: four tires
Couldn't you get some sort of bladder to put inside? Fuelsafe.com may have something for you.
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 08-19-2012   #17
Mark Leasure
I finished up the lexan rear window installation. I don't know the exact weight savings, but its a good amount. The diet is going good I'm estimating 110 pounds removed so far between the lexan, battery move, front and rear brakes, and new tank with much less fuel.
The next photo is all the stuff I removed for the battery relocation. It shaved off 19.5 pounds!
Old 08-19-2012   #18
Mark Leasure
I have a sealable fuel vent to seal the tank from air, to avoid moisture getting to the fuel. I also welded in a drain plug too, so I could drain the fuel for long term storage over the winter.
Old 08-19-2012   #19
Tachyon
Tachyon's Avatar
Drives: Icarus
It's amazing how much weight is tied up in a battery relocation to the trunk. I know I saved 12lbs just in wiring when I relocated back to the front!
-Sebastian Vettel
Old 08-19-2012   #20
Very Nice.
