Old 06-29-2014   #1
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Re: Meet GheyRay: Lower, Wider, Lighter!
Are your headlights smoked now too? Or is that just lighting and you using Instagram or something.
Old 06-29-2014   #2
All pics are unedited with no filters, only modification on the entire car at this point is the grille vinyl
The headlights are likely a result of lighting and reflections.
Old 07-15-2014   #3
First major roadtrip = DONE!
Dallas - St. Louis - Madison - Chicago - Dallas
Besides for some very heavy stop & go traffic getting to downtown Chicago, the trip went great! I kept the cruise control set at 85 MPH most the way. The car was comfortable enough with no complaints! The nav system did great with the traffic & weather updates as well, and the gas prices along the route was helpful too when deciding where to refuel (which luckily wasn't often due to the MPG and tank size).
Old 07-15-2014   #4
The awesomeness is overflowing with this one.
Old 07-15-2014   #5
Woowoo! Epic road trip dude! That is a lot of miles on that beast already; you're putting it through the paces!
Old 07-15-2014   #6
Yeah, not bad for only 3 months
Old 07-15-2014   #7
nice mpg
Old 07-21-2014   #8
Dealerships are retarded.
This is now time #2 the engine oil has been over-filled...once is unacceptable, twice is plain ridiculous. Chevy has a real problem on their hands because this is happening nationwide with the C7 Z51. Long story short, the dealership techs either don't know how to properly check the oil level in a dry sump system, or they aren't taking the time (per the owner's manual, its a 10 minute process) required. Numerous cars, including mine, are requiring return trips to the dealership and replacement parts under warranty due to this. Rather than fixing the problem myself I'm holding them responsible so it is all documented in case a problem ever arises in the future from it.
Old 07-21-2014   #9
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
hell, you have a warranty actually, use it I say!
It is a pain in the butt to keep driving back there and wasting time on morons but I think you have the right idea.
Sucks that they have dumb people working on this. Don't they let actual techs work on these? Or have c7 certified techs? I know mitsu had only 1 or 2 people at each dealer who were the only people qualified to work on evos.
Are they just letting lube tech high school kids do this or something?
Old 07-21-2014   #10
Only Stingray-certified techs are supposed to be touching C7's no matter how big or small the job; I plan to raise this question when I'm there later today.
With the dry sump, to check the oil level, the car needs to be warmed to full operating temp (175F+), shut off, wait 5 minutes, check level on dipstick, wait another 5 minutes, final check on dipstick. The goal with the dry sump is to be about halfway between the min & max marks.
Non-Z51 models have a traditional wet sump oil system that requires no special procedure.
Old 07-21-2014   #11
Full operating temp meaning coolant temp? I don't think oil is up to operating temp in 5 minutes.
Old 07-21-2014   #12
It needs to be shutoff for 5 min, not run for 5 min.
I take mine in to the dealership since I am under warranty too. Might as well!
Old 07-21-2014   #13
Coolant temp.
Exactly. My first 4 oil changes are provided by Chevy and I'm going to angle to get the 5th covered by the dealership due to this hassle. With ~10 qts of oil capacity, I'll take it...it's on them to get it right
Old 07-21-2014   #14
So did they fill past the max mark? How does one even screw that up.
Old 07-21-2014   #15
Yeah, it at least a quart over the max line. Not even close to being correct.
Old 07-21-2014   #16
What a pain. Interesting to see the out come of this.
Old 07-21-2014   #17
I'll tell you exactly the outcome, this non-trained non-professional garage DIYer will be watching over the shoulder of the supposed trained/certified technician requiring proof that it was properly filled. How degrading and embarrassing for them.
I will say, besides for this oil issue on my car I have been very happy with the service and work of this dealership. They did quite a bit to my dad's C6 before he flew down, they performed my alignment under warranty, they checked my rear diff fluid level at my request, and they did a very thorough job of cleaning up the mess the first time my car puked up oil due to over-fill.
Old 07-21-2014   #18
Drrrp, reading comprehension fails me again.
Old 07-23-2014   #19
The return visit was still a miserable failure...still over-full, but at least only by about 1/4 quart this time unlike the first attempt which was a full quart over. I've taken the problem directly to Chevrolet/GM, they've discussed with the dealership, and they will be getting their engineers involved to ensure it does not happen again. I just spoke with the service department manager and he will be having his shop foreman work with the engineers to ensure it's done correctly this time around, give me a loaner/rental, cover all gas & tolls, and refuel my car to help make up for the two return trips for a seemingly simple task.
I'm not thrilled, but at least they are making an effort to get it corrected and make me satisfied.
Old 07-23-2014   #20
Wow
