Build the X 17 56.67%
Old 06-13-2012   #1
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Silly VD numbers...but 500whp on 93 at 24psi...yea...sweet...
Old 06-13-2012   #2
93gtpeater
Drives: cbr 1000rr repsol
Haha. Hope it makes it to pg this year.
Old 06-14-2012   #3
Murlo26
Murlo26's Avatar
So, battling fuel pressure problems right now. My AEM is adjusted for max fuel pressure and it won't go above 42ish at idle.
So as I believe Shane suspected, the car appears to be bleeding fuel back through the second pump. Doing some testing now, but might be getting a check valve for the second pump soon.
Need to bump fuel pressure so we can reduce load as I was hitting 330load and boost cut (319 load) on pump gas at like 24psi.
So we are making it so the load is hopefully 270ish around there by changing around a lot of stuff. (injector scaling, MAF/MAp tables etc)
Not going to lie, I doubt I am going to PG. Especially since work is really crazy. I am kinda bummed but frankly I don't want to go until the car is working fully. I will head out to RF or BIR at a test and tune day when its done if I don't make it.
Still going to try and make it but not looking good now.
Old 06-14-2012   #4
simulatedwood
Drives: 08 Evolution X
I am going to make you a liar! Your coming to PG, that thing is going down the track if we have to push it!
Plus..Don't think of the PG as just a event, think of it as a 3-day Mitsustyle cruise, with lots of nightly festivities, and driving with a hangover. 2 things we are good at.
Old 06-14-2012   #5
Tachyon
Tachyon's Avatar
Drives: Icarus
I'll help with the pushing!
Seriously, you need to just force yourself to have realistic goals, then focus on having fun, even if it's not at 10/10ths level.
Heck, I only managed to get about 60% of the things I wanted to do done on my heap before the PG, but that's not going to stop me from enjoying what a brought to the fullest!
Having slightly reduced fun > no fun.
-Sebastian Vettel
Old 06-14-2012   #6
cmspaz
Walls need hugs too
cmspaz's Avatar
LOL! It's so true.
Originally Posted by Trogdor
Old 06-14-2012   #7
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
You have 8 days left, that's plenty of time.
Old 06-14-2012   #8
Don't be like Chkmgnt...constant work in progress, then once it's finally done get fed-up and sell it. That's what happens when you don't stop and actually allow yourself to enjoy the car while it's in process.
Old 06-14-2012   #9
Murlo26
Murlo26's Avatar
It might be just as easy as getting a check valve for the 2nd pump...but I need to pull the pump out sometime to look at it to get an appropriate one.
I am trying to make it, I have been working on it tons lately, like every night for weeks. But I am starting to run out of steam a bit and work is getting really bad. But we shall see, I could always just run pump gas there instead of e85 just to make it there.
Old 06-14-2012   #10
Tachyon
Tachyon's Avatar
Drives: Icarus
Do it!
Working on cars is no fun when you're allready stressed and rundown... that's how mistakes get made.
-Sebastian Vettel
Old 06-14-2012   #11
Just run it at lower power, like 350-400, and run the road course instead.
Old 06-14-2012   #12
Murlo26
Murlo26's Avatar
Hmmm, interesting...I wouldn't mind doing that. But I still need to get my fuel pressure stuff sorted, then its just tuning.
The car/tune is all jacked up as it was looking for a higher base pressure so I need to do that first.
Old 06-14-2012   #13
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
It's so crazy how much time and money you've put into this car and it still has issues..
T-rev still #1 and lovin it!!!
t-revzr is offline   Reply With Quote
Old 06-14-2012   #14
What sort of check valve are you going to use? I have a -6 in/out one way fuel valve that I used on the V when I was having issues with the siphon letting fuel back into the tank.
Looks something like this but a little bigger:
Old 06-14-2012   #15
Murlo26
Murlo26's Avatar
Not sure yet, I need to pull the backseat and do some measuring. The two pumps meet at a Y outside the tank, so I am thinking of replacing part of the hose with a check valve.
The size I haven't figured out yet.
Old 06-14-2012   #16
Oh nice, if you have enough room outside the tank that would be a lot easier than trying to fit the check valve inside the tank.
Is the Y fitting AN or barbed?
Old 06-14-2012   #17
Murlo26
Murlo26's Avatar
Here just went and took a picture
From looking at this I assume these are barbed.
Old 06-14-2012   #18
Yea, and that's not much room to work with. Good luck with the fuel issues, I thought most pumps had check valves built into them?
Old 06-14-2012   #19
Murlo26
Murlo26's Avatar
Nah in boost I don't have an issue, my car has run over 80psi no problem at full boost.
Its at idle where the issue is, low load in general, before the 2nd pump kicks on. When the second pump runs, there isn't an issue.
I know, its not much room at all, not sure what to do now. I am not sure how big the check valves are, so I dunno.
I think the wally 255's do have a check valve built in. But the pump I am using from blaqops is like a GT500 pump or something strange.
Old 06-15-2012   #20
Murlo26
Murlo26's Avatar
Bought this...
http://www.jegs.com/i/JEGS+Performan...50011/10002/-1
And two of these...
http://www.jegs.com/i/JEGS+Performan...00845/10002/-1
They will be here in the morning. Can't afford to lose two days if I want to make PG, saturday delivery ouch! But MUST FIX EVO!
Normally I do all black/boring stuff as I like stock appearing shit, but they were out of stock until july, so I went balla blue
Tags
