Old 05-09-2013   #221
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 2G auto S/A daily
Did you buy an SRT-4?
They run there's out the front of the rear tire. Mines gonna go out the front bumper. But I get what your saying.
Probably save 30lbs in exhaust though.
Old 05-09-2013   #222
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
The pro-tree is pretty gay with an auto though, I hope you are able to get up on that stall lightning quick!
I actually liked the pro tree for auto. I just let the other car go in first, light the first set of bulbs, build boost, then bump the car into the second beem and be ready to go. it also kinda messes with the other driver since they have to sit there and wait for you to fully stage.
This car is going to be a beast
11.35 @ 120mph
Old 05-09-2013   #223
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Thanks Carl. Definetly good advice forsure. Gotta see if your willing to help me setup the no lift to shift in the car. Ill even drive to ya
Also picked up speed density on the cheap. Thanks polarisamsoil!
Old 05-09-2013   #224
blackawdtsi
Drives: 2G DSM
Interesting.
The motor doesn't pull through the brakes after you built boost? Or are you pulling a ton of timing to be able to do this?
Old 05-09-2013   #225
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Question wasn't directed at me but this was my 16g auto experience.
Usually all you need is a good set of pads and the e brake to hold the car on a stock size turbo.
Old 05-09-2013   #226
blackawdtsi
Drives: 2G DSM
Carl's on an EF2, though. I figured that would be enough to overpower the brakes.
My 6266 pushes through Wilwoods at 9psi, curious what it would take for my car. I probably only make what he makes down low.
Old 05-09-2013   #227
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I don't think there's an ef2 on the market for Dsms yet. Think he's still on an ef1. Not that it matters ef1 to ef2 still bigger thank a 16G.
On my old white auto I could build 18 psi before the brakes even started to make a noise like they wanted to move.
Old 05-10-2013   #228
Hey another guy with an auto chimed in!!
Mine would push thru about 20psi, but I'd rather think about it in terms of TQ. That would be about 37x+ wheel TQ the brakes would get tough to push.
Get it running and we will get it figured out. Vacuum pump will make it easier.
Old 05-12-2013   #229
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
So this fat ass auto has now officially gone on a diet.
Things I did when I swapped the interior over to black
-sound detening
-removed some random stuff from behind the dash
Maybe 30-35lbs
Things I just picked up
-Corbeau seats (super light)
-aftermarket wheel (no airbag)
-pulled passenger airbag
-replacing glass in sunroof with carbon fiber
Those 4 items should be around 120-130lbs in weight saved
16x7 kosei k1 weigh 15.5 so that's a 6+lb savings over stock
20lb total rotating weight.
Not sure what stock starting weight (3400?) is but if I can get it closer to 3200 with me in it I'd be happy.
Ill add pics tomorrow
Old 05-12-2013   #230
99gsxjoel
Drives: 1999 GSX
I was 3170lbs on the scale at bir 2 years ago. I'm sure you are around 3k or under
99gsxjoel is offline   Reply With Quote
Old 05-12-2013   #231
Pull front and rear crash beams? A/C? Could maybe do the rear seat belts too since no one can really fit there anyways haha
Old 05-12-2013   #232
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Joel the autos start out more than the manuals. Not sure what but ill look it up
Goodhart
-front and rear crash beams are gone
-ac gone
-non abs car to start
-power steering deleted
-seatbelts in the rear are not installed
-no speakers or radio
Bet that stuff above is another 60-70lbs I forgot about.
Thanks!
Old 05-12-2013   #233
Don't forget the spare and jack, that is a good 30 lbs.
Old 05-12-2013   #234
Wow, you have a decent amount taken out already! Need some more carbon fiber now!
Otherwise, I'm not sure how much you want to leave in it, but floor mats, trunk carpet, privacy cover, lighter battery, blower motor, heater core, fog lights, electric windows for cranks, washer fluid reservoirs, fender well plastics, aluminum radiator, any extra left over wiring may all be possibilities.
Old 05-12-2013   #235
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
-Spare tire area stuff is all gone (tire,fluid,jack ect)
-aluminum radiator with pushers fans done
-fog lights
-floor mats
-trunk carpet
-rear seats (when I go to the track ill take out at home)
-privacy cover (track day)
Also gonna pull out the front and rear wiper assemblies
Smaller battery
More carbon to come come working with a guy on tuners now for a hood and hatch combo. Just gotta make sure he can have it here in time.
Old 05-12-2013   #236
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Ill be in SA/U now for sure. Time to beat up on some GTR's
Just ordered a SMIM
Almost ready to bolt up the trans so then I can drop it in.
Injectors will be here tomorrow
Rail will be here Wednesday
SMIM will be here Thursday
So can't see why it won't be running by the weekend.
Old 05-13-2013   #237
Looks like a solid list of weight reduction!
Old 05-13-2013   #238
Jason@DB
Sales Guy
Jason@DB's Avatar
Drives: like it's winter
Send a message via AIM to Jason@DB
This makes me want to put the Legacy on a diet, but I still like the idea of having seating for 4 in a sedan. lulz.
jason@dbptuning.com
763-428-9882
Jason@DB is offline   Reply With Quote
Old 05-13-2013   #239
4seasons69
4seasons69's Avatar
Nice! What smim did you get?
Old 05-13-2013   #240
Damn, I'm excited to see how this car runs now!
